OOPS! Got contact cement on the windshield
Old November 13th 04, 05:57 AM
Mike Rapoport
Default OOPS! Got contact cement on the windshield
I managed to get some 1300L contact cement on the windshield of my Helio
Courier while reattaching the vinyl to the glareshield. Does anyone know if
I can use "adhesive remover" on an acrylic windshield without causing
crazing? Any other suggestions? Thanks!
Mike
MU-2
Old November 13th 04, 01:59 PM
Kyle Boatright
The best product I've found for removing glue, paint, and other stuff from
plexi is one of the citrus based cleaners. No solvents, and the stuff does a
fairly good job attacking a surprising number of things. Personally, I
wouldn't want to use any solvent near that expensive windscreen.
KB
"Mike Rapoport" wrote in message
hlink.net...
if I can use "adhesive remover" on an acrylic windshield without causing
Mike
MU-2
Old November 13th 04, 02:40 PM
Jim Burns
Mineral spirits??? Rubbing alcohol? Brake Parts cleaner? If there is a
mechanic on your field, ask him for a scrap piece of glareshield and give it
a try.
hlink.net...
if
Mike
MU-2
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004
Old November 13th 04, 02:45 PM
Roger Long
I have the old windshield from our 172 in the back yard serving as a
basement window shelter. If you would like me to try anything on it for a
final check, email me directly. I'll even put some contact cement on it.
Roger Long
hlink.net...
Mike
MU-2
Old November 13th 04, 04:43 PM
zatatime
On Sat, 13 Nov 2004 04:57:20 GMT, "Mike Rapoport"
Mike
MU-2
Can you keep the area very wet for a long period of time? I'm
thinking covered with wet paper towels, and wait a while for the
adhesive to soften up so you can use your finger to pick it off.
If that won't work, I know either Sporty's or Spruce sells a
"Windshield Compounding" kit. It comes with different "grit" sponges
and 3 or 5 separate compounds. You'll probably have to do the whole
windshield, but at least it should get the junk off it.
HTH.
z
Old November 13th 04, 05:31 PM
Rutger
"Mike Rapoport" wrote in message thlink.net...
Mike
MU-2
Any adhesive remover probably has solvent in it that will cause even
more damage. The contact cement has solvent in it too, that probably
melted the plexiglas underneath the glue. Best bet would be to simply
wait for it to completely dry and then pick it off with your
fingernail (tedious frustrating process) and then repair the
underlying damage with a MicroMesh polishing kit.
Old November 13th 04, 07:27 PM
Ron Natalie
Many contact cements after they set up can just be rubbed off the window
with a thumb or thumbnail (or a plastic scraper like an old credit card).
Old November 13th 04, 08:39 PM
Scott Skylane
Mike
MU-2
Mike,
This product:
http://makeashorterlink.com/?J505216C9
works great, and will not damage your windshield. I have used it many
times for similar purposes. It is also a great product to have around
the shop/house for various cleanup jobs. It dissolves anything MEK
will, without the noxious fumes, or damaging properties.
p.s. So your MU2 doesn't have glass windshields???
Happy Flying!
Scott Skylane
N92054
Old November 14th 04, 12:10 AM
Mike Rapoport
"Scott Skylane" wrote in message
Mike
MU-2
Mike,
This product:
times for similar purposes. It is also a great product to have around the
shop/house for various cleanup jobs. It dissolves anything MEK will,
Happy Flying!
Scott Skylane
N92054
Thanks. Yes the MU-2 has heated glass windshields. I got the contact
cement on the Helio windshield.
Mike
MU-2
Mike Rapoport
Thanks. I will try rubbing it off tomorrow.
Mike
MU-2
m...
windshield wipers tony roberts Owning 8 June 1st 04 03:45 AM
Arrgh! I may have scratched my windshield! Peter R. Owning 7 April 28th 04 08:58 AM
Radar contact before squawk David Brooks Instrument Flight Rules 20 March 25th 04 02:34 AM
Contact myplane Marvin B. Schumer Owning 1 January 26th 04 06:13 AM
Windshield sealant Mike Noel Owning 10 October 2nd 03 02:04 AM
