#21
Burt Compton - Marfa wrote: Casual or "know it all" glider pilots are refused a tow unless our procedures are completed. I assume you never tow at contests. Andy |
BT wrote: how many instructors coordinate with their tow pilot to give a rudder wag at 200ft AGL.. and then watch what happens.. after appropriate ground school in a previous lesson of course.. and then.. on another lesson day.. coordinates for a wave off at 300ft? and a good tow pilot might reduce power with the wave off or maybe start a gradual descent? so many times.. I've had the tow pilot pull a close in down wind turn.. briefed of course.. never get above 500ft AGL and then start the wave off.. the student or rated pilot on a flight review does not realize that the pattern IS NOT NORMAL... what's going on.. and then... ohh.. he wants me to get off.. and then takes his sweet time doing it.. granted.. if all appears well.. make sure you are in a safe place to get off tow.. but if things did not look normal before.. that should have been the earlier clue to be ready for something. BT BT, I couldn't agree with you more - many instructors let students get all the way to their rating without the above sorts of "dirty tricks". This is unacceptable. Three that I always do: - Towpilot begins to slowly throttle back (simulating loss of power due to any number of reasons) at a pre-arranged altitude of about 500-700 AGL without a waveoff. In real-life, this is exactly what might happen in the event of a non-catastrophic towplane problem while the towpilot tries to figure out "what the ***". What does the student do? Most will watch as the inevitable slack line develops and we begin to transition from positive rate of climb to descent. About 20% figure out something is wrong and release while they still have time to make a reasonable pattern and landing. When towpilot finally gives the wave off MOST of the remainder are already on a high enough alert level that they release immediately. A few freeze. - Towpilot gives the rudder waggle at altitude (always above a safe glide to the airport). Most do the right thing. A few either a) release or b) ask me "what's he doing." - This last one is "fun", though it isn't really a tow signal per se. I admit that it's a hassle, but it can be a great learning tool. I will have the towpilot plan on a particularly slow acceleration and a marginal liftoff well down the field. All the while, I'll be asking the student "does this feel right"? I will then pull the release (if student hasn't already) and land straight ahead. The discussion that ensues is along the lines of : a) Hey, it's your neck on the line. b) Don't trust the towpilot blindly - maybe he's got a problem and has forgotten about you. c) The trees at the end of the runway won't care whose fault it was when you impact them 20 feet below the tops. Caution: This requires careful coordination and briefing with the towpilot, an ample length of remaining runway, coordination with other traffic, etc. etc. I'll admit that not every student of mine has been through this, though we do have the discussion. Anyway, I think a lot of people get through training without these and other dirty tricks, and it's a shame. Erik Mann LS8-18 (P3) |
Papa3 wrote: BT wrote: how many instructors coordinate with their tow pilot to give a rudder wag at 200ft AGL.. and then watch what happens.. after appropriate ground school in a previous lesson of course.. and then.. on another lesson day.. coordinates for a wave off at 300ft? and a good tow pilot might reduce power with the wave off or maybe start a gradual descent? so many times.. I've had the tow pilot pull a close in down wind turn.. briefed of course.. never get above 500ft AGL and then start the wave off.. the student or rated pilot on a flight review does not realize that the pattern IS NOT NORMAL... what's going on.. and then... ohh.. he wants me to get off.. and then takes his sweet time doing it.. granted.. if all appears well.. make sure you are in a safe place to get off tow.. but if things did not look normal before.. that should have been the earlier clue to be ready for something. BT BT, I couldn't agree with you more - many instructors let students get all the way to their rating without the above sorts of "dirty tricks". This is unacceptable. Three that I always do: - Towpilot begins to slowly throttle back (simulating loss of power due to any number of reasons) at a pre-arranged altitude of about 500-700 AGL without a waveoff. In real-life, this is exactly what might happen in the event of a non-catastrophic towplane problem while the towpilot tries to figure out "what the ***". What does the student do? Most will watch as the inevitable slack line develops and we begin to transition from positive rate of climb to descent. About 20% figure out something is wrong and release while they still have time to make a reasonable pattern and landing. When towpilot finally gives the wave off MOST of the remainder are already on a high enough alert level that they release immediately. A few freeze. - Towpilot gives the rudder waggle at altitude (always above a safe glide to the airport). Most do the right thing. A few either a) release or b) ask me "what's he doing." - This last one is "fun", though it isn't really a tow signal per se. I admit that it's a hassle, but it can be a great learning tool. I will have the towpilot plan on a particularly slow acceleration and a marginal liftoff well down the field. All the while, I'll be asking the student "does this feel right"? I will then pull the release (if student hasn't already) and land straight ahead. The discussion that ensues is along the lines of : a) Hey, it's your neck on the line. b) Don't trust the towpilot blindly - maybe he's got a problem and has forgotten about you. c) The trees at the end of the runway won't care whose fault it was when you impact them 20 feet below the tops. Caution: This requires careful coordination and briefing with the towpilot, an ample length of remaining runway, coordination with other traffic, etc. etc. I'll admit that not every student of mine has been through this, though we do have the discussion. Anyway, I think a lot of people get through training without these and other dirty tricks, and it's a shame. Erik Mann LS8-18 (P3) This is very interesting subject....preflight check? Brakes closed and locked? Now, this leads me to another point of this subject...how many pilots are taking off with their brakes open because it "helps them achieve faster aileron response" ? And then how many pilots are taking off in flapped gliders with negative flaps? Now imagine combination of negative flaps and open brakes right on the take off. Isn't that a recipe for disaster? How often ? I don't know exact number but I see it very frequently. And the most amazing part of that is that the instructors are teaching it this way. When I asked about it, I never got a straight answer but everybody is saying "it must be done that way". O really? Jacek CFI-G Washington State |
#24
Burt Compton - Marfa wrote: Us a pretakeoff checklist - just like you did once on your FAA Checkride! CBSIFTCBE works - or any checklist that includes "airbrakes (spoilers) closed and locked." Burt, If I may jump in here.I think what Ramy had in mind on this thread was the misinterpretation of tow signals and not the use of checklists.Are you sugesting that if a pilot uses a checklist he or she will never have a tow emergency?The "airbrakes closed and locked" runs contrary to some sailplane P.O.H.s that suggest starting the take off roll in something other than the final take off configuration.I will readily admit that it works great when towing trainers though. Our procedure at Marfa, TX USA (developed from the towpilot's point of view): Obviously the tow pilot doesnt have to worry about aileron authority. Ground crew refuses to hook up towrope until pilot closes and locks airbrakes. IF glider pilot wishes to use airbrakes open on takeoff for better aileron control with water ballast, then ground crew confirms the towpilot is aware of this. Glider pilot radios towpilot "canopy and airbrakes closed and locked". Towpilot (just before takeoff) repeats back to glider pilot "understand your canopy and airbrakes are closed and locked." If you do not follow our procedures - we don't launch. This is a good idea but you fail to mention how the procedure differs when a pilot uses spoilers (Or negative flap).One of the three local tow operations used this procedure but then altered it by using the phraseology of "Canopy locked, controls checked" meaning 1;a positive control check has been acomplished by the line person who hooked you up, and 2; The controls are in the proper configuration for initiating the take off (incuding the trim). This way a pilot does not have to anounce something over the radio that isnt right.I think it sets up a much better habit pattern. Sorry but as your towpilot we gotta do it my way. No problem here, lets just not do it in a maner that conflicts with the POH.Getting back to Ramy's post, I think it is an excellent idea to look at the spoiler handle if there is any confusion what so ever with the tow planes signals. Burt CFIG / DPE Marfa Gliders west Texas K Urban |
#25
Now, this leads me to another point of this subject...how many pilots are taking off with their brakes open because it "helps them achieve faster aileron response" ? And then how many pilots are taking off in flapped gliders with negative flaps? Jacek, you have to make a distinction here between "taking off" and starting the take off roll.To answer your question, I would say that most pilots, when operating an older ship with a CG hook in a crosswind will use spoilers or negative flap until they get some roll authority.Another thing to consider is with ships like the ASW20 the ailerons droop and rise with the flaps.This makes a HUGE difference on the roll control at slow speeds.It is spelled out in the P.O.H. and therefore it is considered normal operating procedure. Isn't that a recipe for disaster? How often ? I don't know exact number but I see it very frequently. And the most amazing part of that is that the instructors are teaching it this way. Instructors are required to teach compliance with the POH, so I would say this is perfectly normal. When I asked about it, I never got a straight answer but everybody is saying "it must be done that way". O really? Jacek CFI-G Washington State |
#26
Yes, this is exactly my point. All posters have good advises, but
still, the only way to prevent this kind of confusion, which keeps happening over and over again and occasionly cost life, it to amend the standard procedure for tow signals to first glimpse at the spoiler handle, or better yet, at the spoiler itself, in most cases it will be easier and quicker then looking at the exact handle position. No need to look at both spoilers. If only one is open then it is another serious problem. Ramy KM wrote: Burt Compton - Marfa wrote: Us a pretakeoff checklist - just like you did once on your FAA Checkride! CBSIFTCBE works - or any checklist that includes "airbrakes (spoilers) closed and locked." Burt, If I may jump in here.I think what Ramy had in mind on this thread was the misinterpretation of tow signals and not the use of checklists.Are you sugesting that if a pilot uses a checklist he or she will never have a tow emergency?The "airbrakes closed and locked" runs contrary to some sailplane P.O.H.s that suggest starting the take off roll in something other than the final take off configuration.I will readily admit that it works great when towing trainers though. Our procedure at Marfa, TX USA (developed from the towpilot's point of view): Obviously the tow pilot doesnt have to worry about aileron authority. Ground crew refuses to hook up towrope until pilot closes and locks airbrakes. IF glider pilot wishes to use airbrakes open on takeoff for better aileron control with water ballast, then ground crew confirms the towpilot is aware of this. Glider pilot radios towpilot "canopy and airbrakes closed and locked". Towpilot (just before takeoff) repeats back to glider pilot "understand your canopy and airbrakes are closed and locked." If you do not follow our procedures - we don't launch. This is a good idea but you fail to mention how the procedure differs when a pilot uses spoilers (Or negative flap).One of the three local tow operations used this procedure but then altered it by using the phraseology of "Canopy locked, controls checked" meaning 1;a positive control check has been acomplished by the line person who hooked you up, and 2; The controls are in the proper configuration for initiating the take off (incuding the trim). This way a pilot does not have to anounce something over the radio that isnt right.I think it sets up a much better habit pattern. Sorry but as your towpilot we gotta do it my way. No problem here, lets just not do it in a maner that conflicts with the POH.Getting back to Ramy's post, I think it is an excellent idea to look at the spoiler handle if there is any confusion what so ever with the tow planes signals. Burt CFIG / DPE Marfa Gliders west Texas K Urban |
#27
Nothing will take the place of really learning and
understanding the signals, reviewing them regularly and testing for them on every BFR. If every tow pilot gave the rudder wag on every tenth tow, pilots would begin to recognize this signal for what it is. At 19:31 12 October 2006, Ramy wrote: Yes, this is exactly my point. All posters have good advises, but still, the only way to prevent this kind of confusion, which keeps happening over and over again and occasionly cost life, it to amend the standard procedure for tow signals to first glimpse at the spoiler handle, or better yet, at the spoiler itself, in most cases it will be easier and quicker then looking at the exact handle position. No need to look at both spoilers. If only one is open then it is another serious problem. Ramy KM wrote: Burt Compton - Marfa wrote: Us a pretakeoff checklist - just like you did once on your FAA Checkride! CBSIFTCBE works - or any checklist that includes 'airbrakes (spoilers) closed and locked.' Burt, If I may jump in here.I think what Ramy had in mind on this thread was the misinterpretation of tow signals and not the use of checklists.Are you sugesting that if a pilot uses a checklist he or she will never have a tow emergency?The 'airbrakes closed and locked' runs contrary to some sailplane P.O.H.s that suggest starting the take off roll in something other than the final take off configuration.I will readily admit that it works great when towing trainers though. Our procedure at Marfa, TX USA (developed from the towpilot's point of view): Obviously the tow pilot doesnt have to worry about aileron authority. Ground crew refuses to hook up towrope until pilot closes and locks airbrakes. IF glider pilot wishes to use airbrakes open on takeoff for better aileron control with water ballast, then ground crew confirms the towpilot is aware of this. Glider pilot radios towpilot 'canopy and airbrakes closed and locked'. Towpilot (just before takeoff) repeats back to glider pilot 'understand your canopy and airbrakes are closed and locked.' If you do not follow our procedures - we don't launch. This is a good idea but you fail to mention how the procedure differs when a pilot uses spoilers (Or negative flap).One of the three local tow operations used this procedure but then altered it by using the phraseology of 'Canopy locked, controls checked' meaning 1;a positive control check has been acomplished by the line person who hooked you up, and 2; The controls are in the proper configuration for initiating the take off (incuding the trim). This way a pilot does not have to anounce something over the radio that isnt right.I think it sets up a much better habit pattern. Sorry but as your towpilot we gotta do it my way. No problem here, lets just not do it in a maner that conflicts with the POH.Getting back to Ramy's post, I think it is an excellent idea to look at the spoiler handle if there is any confusion what so ever with the tow planes signals. Burt CFIG / DPE Marfa Gliders west Texas K Urban |
#28
But what if the tow pilot give the wrong signal? Or what if the tow
pilot had difficult climbing, did not realize the glider spoilers are open (no mirrors) and rocked the wings instead of wigeling the rudder? My suggestion to take a quick glimpse at the spoiler before releasing will solve this scenario as well. Tow pilots can make mistakes as well, especially if they did not practice the signal often. I had quiet a few cases where I radioed to the tow pilots to turn towards 1 or 2 o'clock and instead they turned towards 11 or 10 o'clock... (I know we all wear digital watches these days ;-) One quick glimpse at the spoiler before pulling the release will not hurt anyone and only can save lives. The pilot in the accident mentioned may have cleared the wires if he closed the spoilers first. Ramy Nyal Williams wrote: Nothing will take the place of really learning and understanding the signals, reviewing them regularly and testing for them on every BFR. If every tow pilot gave the rudder wag on every tenth tow, pilots would begin to recognize this signal for what it is. At 19:31 12 October 2006, Ramy wrote: Yes, this is exactly my point. All posters have good advises, but still, the only way to prevent this kind of confusion, which keeps happening over and over again and occasionly cost life, it to amend the standard procedure for tow signals to first glimpse at the spoiler handle, or better yet, at the spoiler itself, in most cases it will be easier and quicker then looking at the exact handle position. No need to look at both spoilers. If only one is open then it is another serious problem. Ramy KM wrote: Burt Compton - Marfa wrote: Us a pretakeoff checklist - just like you did once on your FAA Checkride! CBSIFTCBE works - or any checklist that includes 'airbrakes (spoilers) closed and locked.' Burt, If I may jump in here.I think what Ramy had in mind on this thread was the misinterpretation of tow signals and not the use of checklists.Are you sugesting that if a pilot uses a checklist he or she will never have a tow emergency?The 'airbrakes closed and locked' runs contrary to some sailplane P.O.H.s that suggest starting the take off roll in something other than the final take off configuration.I will readily admit that it works great when towing trainers though. Our procedure at Marfa, TX USA (developed from the towpilot's point of view): Obviously the tow pilot doesnt have to worry about aileron authority. Ground crew refuses to hook up towrope until pilot closes and locks airbrakes. IF glider pilot wishes to use airbrakes open on takeoff for better aileron control with water ballast, then ground crew confirms the towpilot is aware of this. Glider pilot radios towpilot 'canopy and airbrakes closed and locked'. Towpilot (just before takeoff) repeats back to glider pilot 'understand your canopy and airbrakes are closed and locked.' If you do not follow our procedures - we don't launch. This is a good idea but you fail to mention how the procedure differs when a pilot uses spoilers (Or negative flap).One of the three local tow operations used this procedure but then altered it by using the phraseology of 'Canopy locked, controls checked' meaning 1;a positive control check has been acomplished by the line person who hooked you up, and 2; The controls are in the proper configuration for initiating the take off (incuding the trim). This way a pilot does not have to anounce something over the radio that isnt right.I think it sets up a much better habit pattern. Sorry but as your towpilot we gotta do it my way. No problem here, lets just not do it in a maner that conflicts with the POH.Getting back to Ramy's post, I think it is an excellent idea to look at the spoiler handle if there is any confusion what so ever with the tow planes signals. Burt CFIG / DPE Marfa Gliders west Texas K Urban |
#29
Papa3.. I like your third one..
now another... how many instructors pull the rope at about 20-30ft AGL.. just as the climb starts.. and watch the student try to go every which way but straight ahead and land. Remember the mantra.. below 200ft land straight ahead. We have a long 3500ft runway, we stage about 500ft down the runway, the tow is normally airborn with 1500ft remaining.. we have 600ft of gravel beyond the paved portion, that is 2100ft to land on from 40ft AGL. I can pull the rope at 20-40ft at the 1500ft remaining marker.. (cross taxi way).. a good student will get it down and I'll have to coax him to let it roll to the end so we can just turn around and tow out the opposite direction. I've had other students looking for a place to go and I've had to take over. Tow pilot may be briefed ahead.. but we have a standing rule.. if the tow is airborne and feels a release.. the tow keeps going.. do not try to land... your blocking the runway for the glider.. we also have about 150ft of good landable grading beside the runway, whole length. BT "Papa3" wrote in message ups.com... BT wrote: how many instructors coordinate with their tow pilot to give a rudder wag at 200ft AGL.. and then watch what happens.. after appropriate ground school in a previous lesson of course.. and then.. on another lesson day.. coordinates for a wave off at 300ft? and a good tow pilot might reduce power with the wave off or maybe start a gradual descent? so many times.. I've had the tow pilot pull a close in down wind turn.. briefed of course.. never get above 500ft AGL and then start the wave off.. the student or rated pilot on a flight review does not realize that the pattern IS NOT NORMAL... what's going on.. and then... ohh.. he wants me to get off.. and then takes his sweet time doing it.. granted.. if all appears well.. make sure you are in a safe place to get off tow.. but if things did not look normal before.. that should have been the earlier clue to be ready for something. BT BT, I couldn't agree with you more - many instructors let students get all the way to their rating without the above sorts of "dirty tricks". This is unacceptable. Three that I always do: - Towpilot begins to slowly throttle back (simulating loss of power due to any number of reasons) at a pre-arranged altitude of about 500-700 AGL without a waveoff. In real-life, this is exactly what might happen in the event of a non-catastrophic towplane problem while the towpilot tries to figure out "what the ***". What does the student do? Most will watch as the inevitable slack line develops and we begin to transition from positive rate of climb to descent. About 20% figure out something is wrong and release while they still have time to make a reasonable pattern and landing. When towpilot finally gives the wave off MOST of the remainder are already on a high enough alert level that they release immediately. A few freeze. - Towpilot gives the rudder waggle at altitude (always above a safe glide to the airport). Most do the right thing. A few either a) release or b) ask me "what's he doing." - This last one is "fun", though it isn't really a tow signal per se. I admit that it's a hassle, but it can be a great learning tool. I will have the towpilot plan on a particularly slow acceleration and a marginal liftoff well down the field. All the while, I'll be asking the student "does this feel right"? I will then pull the release (if student hasn't already) and land straight ahead. The discussion that ensues is along the lines of : a) Hey, it's your neck on the line. b) Don't trust the towpilot blindly - maybe he's got a problem and has forgotten about you. c) The trees at the end of the runway won't care whose fault it was when you impact them 20 feet below the tops. Caution: This requires careful coordination and briefing with the towpilot, an ample length of remaining runway, coordination with other traffic, etc. etc. I'll admit that not every student of mine has been through this, though we do have the discussion. Anyway, I think a lot of people get through training without these and other dirty tricks, and it's a shame. Erik Mann LS8-18 (P3) |
#30
What about tow plane aborts on the runway?
I had a tug pilot shut down and brake sharply to a stop right on the centerline just after I had lifted off. It took some trick flying to avoid hitting him. I thought this was one in a million until I saw it happen to another glider pilot only a year later. In my case the tuggie suddenly decided he didn't want to fly right then. In the other case, the tuggie left the fuel cap off the Pawnee and gas was streaming onto the canopy. Part of the "Emergency" pre-takeoff planning has to be about where to go if the tug slams on the brakes. I'd think the tuggie should move as far to the left as possible - even departing the runway to the left during an abort if that is possible. AFAIK, runway aborts aren't addresed in tow pilot training. Bill Daniels "BT" wrote in message news:LhAXg.4029$gM1.2379@fed1read12... Papa3.. I like your third one.. now another... how many instructors pull the rope at about 20-30ft AGL.. just as the climb starts.. and watch the student try to go every which way but straight ahead and land. Remember the mantra.. below 200ft land straight ahead. We have a long 3500ft runway, we stage about 500ft down the runway, the tow is normally airborn with 1500ft remaining.. we have 600ft of gravel beyond the paved portion, that is 2100ft to land on from 40ft AGL. I can pull the rope at 20-40ft at the 1500ft remaining marker.. (cross taxi way).. a good student will get it down and I'll have to coax him to let it roll to the end so we can just turn around and tow out the opposite direction. I've had other students looking for a place to go and I've had to take over. Tow pilot may be briefed ahead.. but we have a standing rule.. if the tow is airborne and feels a release.. the tow keeps going.. do not try to land... your blocking the runway for the glider.. we also have about 150ft of good landable grading beside the runway, whole length. BT "Papa3" wrote in message ups.com... BT wrote: how many instructors coordinate with their tow pilot to give a rudder wag at 200ft AGL.. and then watch what happens.. after appropriate ground school in a previous lesson of course.. and then.. on another lesson day.. coordinates for a wave off at 300ft? and a good tow pilot might reduce power with the wave off or maybe start a gradual descent? so many times.. I've had the tow pilot pull a close in down wind turn.. briefed of course.. never get above 500ft AGL and then start the wave off.. the student or rated pilot on a flight review does not realize that the pattern IS NOT NORMAL... what's going on.. and then... ohh.. he wants me to get off.. and then takes his sweet time doing it.. granted.. if all appears well.. make sure you are in a safe place to get off tow.. but if things did not look normal before.. that should have been the earlier clue to be ready for something. BT BT, I couldn't agree with you more - many instructors let students get all the way to their rating without the above sorts of "dirty tricks". This is unacceptable. Three that I always do: - Towpilot begins to slowly throttle back (simulating loss of power due to any number of reasons) at a pre-arranged altitude of about 500-700 AGL without a waveoff. In real-life, this is exactly what might happen in the event of a non-catastrophic towplane problem while the towpilot tries to figure out "what the ***". What does the student do? Most will watch as the inevitable slack line develops and we begin to transition from positive rate of climb to descent. About 20% figure out something is wrong and release while they still have time to make a reasonable pattern and landing. When towpilot finally gives the wave off MOST of the remainder are already on a high enough alert level that they release immediately. A few freeze. - Towpilot gives the rudder waggle at altitude (always above a safe glide to the airport). Most do the right thing. A few either a) release or b) ask me "what's he doing." - This last one is "fun", though it isn't really a tow signal per se. I admit that it's a hassle, but it can be a great learning tool. I will have the towpilot plan on a particularly slow acceleration and a marginal liftoff well down the field. All the while, I'll be asking the student "does this feel right"? I will then pull the release (if student hasn't already) and land straight ahead. The discussion that ensues is along the lines of : a) Hey, it's your neck on the line. b) Don't trust the towpilot blindly - maybe he's got a problem and has forgotten about you. c) The trees at the end of the runway won't care whose fault it was when you impact them 20 feet below the tops. Caution: This requires careful coordination and briefing with the towpilot, an ample length of remaining runway, coordination with other traffic, etc. etc. I'll admit that not every student of mine has been through this, though we do have the discussion. Anyway, I think a lot of people get through training without these and other dirty tricks, and it's a shame. Erik Mann LS8-18 (P3) |
| "Signal jamming a factor in future wars, general says" | Mike | Military Aviation | 23 | August 24th 11 03:17 AM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Glider - Towplane Signals | Mike the Strike | Soaring | 24 | March 26th 05 10:33 PM |
| The wrong signals to send to young visitors. | Larry Dighera | Piloting | 57 | November 26th 03 08:05 AM |
