#61
In a GA aircraft the aircraft dangles 5 feet below eye level.
Are you seriously suggesting that you can't see objects 5 feet below the aircraft, with visibility good enough to see distant runway lights? Yep. That's exactly what I'm saying. And in five seconds the aircraft can easily go five hundred feet. Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
#62
#63
#64
#65
On Sat, 08 Jan 2005 22:35:52 GMT, Jose
wrote: Yep. That's exactly what I'm saying. And in five seconds the aircraft can easily go five hundred feet. And about 40-80 feet vertically, which can be regained in about 2-4 seconds |
#66
On Sat, 08 Jan 2005 18:13:33 -0600, J Haggerty
wrote: NTSB reports are full of stories about pilots that had the runway in sight and still hit the ground. NTSB reports are chuck full of bad piloting stories. |
#67
On Sat, 08 Jan 2005 15:16:17 -0900, Scott Skylane
wrote: wrote: On Sat, 08 Jan 2005 21:31:33 GMT, Jose wrote: In that time you are moving forward. The object that caused you to lose sight of the target may well be wrapped around you by then. In 5 seconds? With visibility good enough to see the runway? Give me a break. You've never actually flown at night, in a remote location, have you? Happy Flying! Scott Skylane Actually, I have. In hilly country at that. It's where I learned that when making a visual approach to an airport at night, and the runway threshold lights start to disappear, that one needs to get some altitude back in a hurry and keep visual contact with the approach end of the runway at all times. Obviously, many pilots have some other way of avoiding terrain, although I haven't quite figured out what it is, exacty. (except to keep the gear up so you don't drag them in the trees which are 5 feet below the aircraft but for some reason not visible, which is a phenomenon I must say I find highly interesting. 5 feet ain't that far, when you really stop and think about it.) Then of course, there's the even more interesting question of how you know something is 5 feet away if you can'tsee it.. |
#68
According to the local automobile association here, it takes (on average)
0.75 seconds to perceive a need to brake, and (on average) 0.75 seconds to figure out what action is needed and execute it. (Geek that I am, I still have my old driver's training manual...) Assuming these stats can be applied to this problem, it will take 1.5 seconds from the moment you perceive the terrain for you to take corrective action. Assuming 500 fpm, that's about 12.5 feet of descent, not 5. Now add to that the altitude you lose if you happen to be watching some other traffic, tuning a radio, setting an OBS, consulting a chart, etc - even if it just takes you one second, the safety margin's now up past 20 feet. Also take into account that you're not seeing a big red danger sign flashing in front of you; rather, you need to react to dark shapes in your peripheral vision. Add to this a moonless night, or a failed landing light, or a steeper-than-usual descent, or whatever... -Rob wrote in message ... On Sat, 08 Jan 2005 22:35:52 GMT, Jose wrote: Yep. That's exactly what I'm saying. And in five seconds the aircraft can easily go five hundred feet. And about 40-80 feet vertically, which can be regained in about 2-4 seconds |
#69
I must confess, however, I don't know how you would know for sure
that they were only 5 feet away since you admittedly wouldn't have been able to have seen them. When you drag your landing gear through them, they are five feet away. Yep. That's exactly what I'm saying. And in five seconds the aircraft can easily go five hundred feet. And about 40-80 feet vertically, which can be regained in about 2-4 seconds 2-4 seconds is another 200-400 feet forward We're up to almost a thousand feet horizontally and maybe 80 feet vertically. NTSB reports are chuck full of bad piloting stories. .... like descending the plane into trees while your eyeball has the lights in sight. ...I learned that when making a visual approach to an airport at night, and the runway threshold lights start to disappear, that one needs to get some altitude back in a hurry and keep visual contact with the approach end of the runway at all times. .... from which it does =not= follow that keeping the threshold lights in sight prevents CFIG. Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
#70
On Sun, 09 Jan 2005 06:02:27 GMT, Jose
wrote: ... from which it does =not= follow that keeping the threshold lights in sight prevents CFIG. Well, please, share your technique with the rest of us. |
| Are pilots really good or just lucky??? | Icebound | Instrument Flight Rules | 68 | December 9th 04 02:53 PM |
| Canadian departure minimums? | Derrick Early | Instrument Flight Rules | 3 | August 9th 04 02:43 PM |
| Can ATC assign an airway if filed direct? | Andrew Sarangan | Instrument Flight Rules | 26 | March 4th 04 01:23 AM |
| Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 04:22 PM |
| CAT II Minimums on a CAT I Approach | Giwi | Instrument Flight Rules | 11 | July 24th 03 08:46 AM |
