Edwards air show B-1 speed record attempt
Old October 19th 03, 12:32 AM
Paul Hirose
Default Edwards air show B-1 speed record attempt
The Edwards AFB air show on October 25 and 26 will feature attempts to
set numerous world speed records with a B-1B. The speed runs will
include low altitude passes over the show area. A release of 84 inert
500-lb bombs in view of the crowd will conclude the B-1 flying on both
days.
http://www.edwards.af.mil/oh_2003/do...vent-info.html
Paul Hirose
Old October 19th 03, 08:08 PM
Alan Minyard
On Sat, 18 Oct 2003 22:32:00 GMT, Paul Hirose
days.
How in the world is a B-1B going to set *any* speed records?
Al Minyard
Old October 19th 03, 08:56 PM
Thomas Schoene
"Alan Minyard" wrote in message
Not absolute records. It already has a bunch in its weight class for speed
over particular courses, speed with certain payloads, etc. I expect the
plan to improve on those and add some more.
The B-1's current records are listed here, along with records by other
aircraft in the same general categories. I imagine they'll be trying to
take some away from the Tu-160.
http://www.b1b.wpafb.af.mil/pages/pdf/b1_records.pdf
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old October 19th 03, 09:57 PM
Guy Alcala
days.
Probably the same way it set the numerous speed records it has held since
1987 and later; for closed circuits of 1,000km, 2,000km (both in class
C-1q, 150,000 to 200,000 kg. t/o wgt.) and 5,000km (unlimited wgt. class)
with payloads varying from zero to 30,000 kg., for 10,000km with zero
payload (unlimited wgt.) , and for around the world eastbound (refueled in
flight, unlimited wgt.). They might be looking to take a few more of the
10,000km records with payload from the B-52H which currently holds them, or
else boost some of the 5,000km records or the around the world records they
already hold. See
http://records.fai.org/general_aviat...p?id1=21&id2=4
for the current records. The other option, which sounds more like what
they're talking about with the "speed runs," would be to try and set a low
altitude speed record in its weight class; although AFAIK the FAI no longer
recognizes low altitude speed records per se owing to the danger.
Guy
Old October 20th 03, 01:52 AM
Paul Hirose
The local civilian newspaper has an article about the upcoming B-1
speed record attempts. The runs will be in two weight classes (on
different days), each day including 100-, 500-, and 1000-km closed
course runs, apparently at 500 feet. "The bomber will maintain speeds
of 0.9 to 0.95 Mach, or nearly 700 mph, while skimming along at 500
feet above the ground."
There will also be speed runs on 3- and 15-km straight line courses.
The 3-km pass will be at 400 feet and .95 Mach. The 15-km pass will be
at 15,000 and 1.2 Mach.
Each day will conclude with the bomb load being dropped on the range
about four miles from the air show grounds.
http://www.avpress.com/n/susty1.hts
Paul Hirose
Old October 20th 03, 01:58 AM
BUFDRVR
Lots of luck, those records maxed out the B-52H unrefueled range, unless
they've installed new engines in that Bone making it 50% more efficient I don't
think they've got a chance.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old October 20th 03, 02:16 AM
Scott Ferrin
On Sun, 19 Oct 2003 18:56:42 GMT, "Thomas Schoene"
I wish they'd get the fire to break more records these days like they
did back in the fifties and sixties. Hell some of the "records" out
there are ones that any line aircraft could break easily if not
actually performing *beyond* them regularly.
Old October 20th 03, 09:18 AM
Regnirps
Oh, crap! The table uses that French system with the km/hour I can never make
sense of!
-- Charlie Springer
Old October 20th 03, 09:44 AM
PosterBoy
"Regnirps" wrote in message
make
sense of!
-- Charlie Springer
I think you mean that nearly universal system with the km/hour. Try:
http://www.teaching-english-in-japan...ion/kilometers
or, if you don't wish to learn anything, just want to convert:
http://www.escapeartist.com/Miles_Ki...Converter.html
Cheers.
Old October 21st 03, 12:24 AM
Guy Alcala
From Paul Hirose's post it appears that they aren't going for the 10,000 km
records. Personally, I'd think that capturing the record for 10,000km at 1 and
maybe 2,000 kg. payloads might be doable, given ideal conditions and very precise
flying rather than any improvement in engine sfc. But maybe the 10,000km/no
payload record was already on the edge of what could be physically achieved, and
there's no room for improvement.
Guy
Bush's guard record JDKAHN Home Built 13 October 3rd 04 10:38 PM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
U.S. Troops, Aircraft a Hit at Moscow Air Show Otis Willie Military Aviation 0 August 28th 03 11:04 PM
