Schumanized Wing?
Old November 20th 11, 07:36 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Default Schumanized Wing?
I might be spelling this wrong but could someone fill me in as to the advantages and disadvantages to the Schumanized Wing?
Thanks,
Walt
Old November 20th 11, 03:21 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Nov 19, 10:36*pm, Walt Connelly Walt.Connelly.
Thanks,
Walt
Walt Connelly
Schueman did extensive tests and detirmined the lower wing surface was
all turbulent at speeds above 70 knots on the H-301 Libelle. He
modified the Huter (sp?) airfoil to make it more like a wortman with
pointed, rather than round leading edge. He also changed the flap
drive to make the ailerons follow the flaps throughout all flap
movements. I did all this + wing fairings and Kestral canopy on my
H-301. She would keep up with the ASW-20's. They'd outrun me, but then
mark the next thermal, where I'd outclimb them because they had 40
gallons of water vs. my 25 gallons. Sweet ship right up till the day
the SSA said we couldn't race above the manufactures published maximum
weight......................and the H-301 is 660 max!
Good by Libelle, you were a good old bird right up till the bureacrats
gave us the Spring Surprise in 1981?
Cheers,
JJ
Old November 22nd 11, 12:06 AM posted to rec.aviation.soaring
On Nov 20, 1:36*am, Walt Connelly Walt.Connelly.
Thanks,
Walt
Walt Connelly
See http://www.betsybyars.com/guy/soarin.../72-modif.html for Wil
Schuemann's description of the many modifications he made to his
H-301. The biggest advantage of the Schuemannized wing is its
drastically improved performance at high cruising speeds while giving
up none of its climbing abilities. Disadvantages? The wings are a
little heavier. And of course re-contouring the wings is no walk in
the park, but if you like going faster than the other guy...
Jack Wyman
(Former owner of the "Schuebelle": it's now in the National Soaring
Museum).
Old November 22nd 11, 03:10 AM posted to rec.aviation.soaring
John Cochrane[_2_]
Cheers,
JJ
Speaking as a bureacrat, JJ, do you seriously think we should get rid
of weight restrictions? I can't wait to see what the FAA says when
some guy crashes while flying at 15 lbs/ft2...
John Cochrane
Old November 22nd 11, 03:02 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
John Cochrane
I objected to the way it was done, 2 months before the nats I was told
my ship would not be allowed to compete. Carl Herold said there would
be a "grandfather" provision to allow the H-301 to fly and then did
nothing to implement it.
Water under the bridge,
JJ
Old November 23rd 11, 04:50 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
JJ
Or, out of the bags, right JJ?
Steve Leonard
ASW-20A Left Wing or Inboard Wing Skin Needed Coucked Soaring 0 August 29th 10 03:43 PM
Low wing landing, high wing taking off...oops [email protected] Piloting 1 May 16th 08 10:41 PM
Soft field landings - low wing vs high wing aircraft Justin Gombos Piloting 19 May 23rd 07 06:21 AM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 04:23 AM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 04:46 PM
