Folks, I've been lurking and reading your group for a good while. I admire
	the talent it takes to fly, with or without power, and those who do this. Looking at the craft at the fields and in the online directories, one sees hi-dollar, high performance craft everywhere. Is anyone home-building gliders? Entry-level craft? If so, what are they, and where are the plans obtained? I'd possibly be interested in something slightly more capable than the "Primary" of the 30's, if such were available. Thanks Flash  |
Have a look at teh Experimental Soaring Association (used to be called
	Sailplane Homebuilders Association) website. http://www.esoaring.com/  |
On Jul 5, 9:32*pm, JS  wrote:
	Have a look at teh Experimental Soaring Association (used to be called Sailplane Homebuilders Association) website.http://www.esoaring.com/ There's a Windrose for sale on Ebay currently.  |
At 03:50 06 July 2008, Flash wrote:
	Looking at the craft at the fields and in the online directories, one sees hi-dollar, high performance craft everywhere. Is anyone home-building gliders? Entry-level craft? If so, what are they, and where are the plans obtained? I'd possibly be interested in something slightly more capable than the "Primary" of the 30's, if such were available. If what you are *really* looking for is a project, then homebuilding may be for you. But if what you want to do is to *fly*, then maybe you should think again. The ratio of completed projects to finished projects is pretty small. Certainly less than half. The Windrose is intended to be a self-launcher. That may be important to you. It is also made of wood, so you'd want to store it out of the elements. Nothing wrong with wooden gliders, though. There *can* be a problem with selling an aircraft you built yourself, once you're ready to move on. The obvious alternative (assuming you're in the US) is a 1-26. Readily available on the market, it's metal so you can leave it outside, you can get one in good shape, with a trailer, reasonably equipped, for under $10K. And yes, it performs better than a Primary. Not by much, but still it will get you in the air right away. It's also dead simple to fly, and you sort of sound like you're just starting out with your dream. But it's good to get started! Jim Beckman  |
Here's an alternative DIY project.
	If you build a sailplane, you'll have to apply some sort of paint or finish which is about the same amount of work and cost as refinishing an existing glider. Why not buy an old glider with bad gelcoat and refinish it? I'd guess it's actually cheaper than building from scratch and you have a known quantity in terms of structure and aerodynamics. For sure, the refinished glider will be worth more at resale than a homebuilt. Bill D "JS" wrote in message ... Have a look at teh Experimental Soaring Association (used to be called Sailplane Homebuilders Association) website. http://www.esoaring.com/  |
I started off in primaries; the Schweizer 1-26 is a WHOLE LOT BETTER than a
	primary glider. The 1-26 will soar and a primary won't in any ordinary circumstances. You can't build even a primary and try to fly it alone without instruction. Maybe you should take a few lessons somewhere before starting to build anything or buy something. At 11:57 06 July 2008, Jim Beckman wrote: At 03:50 06 July 2008, Flash wrote: Looking at the craft at the fields and in the online directories, one sees hi-dollar, high performance craft everywhere. Is anyone home-building gliders? Entry-level craft? If so, what are they, and where are the plans obtained? I'd possibly be interested in something slightly more capable than the "Primary" of the 30's, if such were available. If what you are *really* looking for is a project, then homebuilding may be for you. But if what you want to do is to *fly*, then maybe you should think again. The ratio of completed projects to finished projects is pretty small. Certainly less than half. The Windrose is intended to be a self-launcher. That may be important to you. It is also made of wood, so you'd want to store it out of the elements. Nothing wrong with wooden gliders, though. There *can* be a problem with selling an aircraft you built yourself, once you're ready to move on. The obvious alternative (assuming you're in the US) is a 1-26. Readily available on the market, it's metal so you can leave it outside, you can get one in good shape, with a trailer, reasonably equipped, for under $10K. And yes, it performs better than a Primary. Not by much, but still it will get you in the air right away. It's also dead simple to fly, and you sort of sound like you're just starting out with your dream. But it's good to get started! Jim Beckman  |
Re : Do it youself!
	Hi Flash, I would definitely concur will Bill, in that rather than trying to start building a wooden glider from scratch I would consider buying one of the older glass ships and either refinish the surfaces yourself, as a project, or even pay to get it done as the whole exercise would not be overly expensive. A contact of mine at another club recently bought an old 1970's flapped Vega 17 metre glider at something like £6k (However, this particular model is an advanced glider to fly!). He sent me an email saying that he is so 'over the moon' with it's handling and performance that for his personal style of flying he will never need anything else. sSo he is driving it to Poland for a gel coat re-finishing (which is the cheapest way to get it done in Europe!) Another 1970's glider (not so advanced but I understand has been very popular in the USA) is the'Libelle'. This is a delightful little 15 metre glider that is about the easiest of all to rig. A man and his son or wife alone could rig it quite easily! It's only downside is limited power airbrakes, which means a pilot needs to be fairly experienced to ensure landing it safely in a small field in the event of an outlanding. In the UK a good Libelle, including trailer, can be bought for under £6k. Even though 1970's design and manufacture, these gliders have the advantage over a wooden glider in that they are 'slippery' and have a good penetration ability - so you can 'go places'. A home build or vintage 'wooden' ship would almost certainy not have much penetration, and although they climb well, it's difficult to go anywhere one you're up at cloudbase. Isn't it better to spend your spare time learing how to fly a glider and the skills of soaring, rather than spending hundreds of hours in your workshop! Additionally, although GRP 'glass' ships should not be kept out in the sun for more hours than are necessary, they are arguebly far more resilient than wooden aircraft regarding, rain, humidity, heat, etc. and normally require not much maintenance (apart from a gel coat re-finishing every couple of decades or so). The best of luck whatever road you decide to take!  |
At 14:27 06 July 2008, Nyal Williams wrote:
	I started off in primaries; the Schweizer 1-26 is a WHOLE LOT BETTER than a primary glider. The 1-26 will soar and a primary won't in any ordinary circumstances. Certainly - just my little joke at a glider that I truly enjoy flying. (Although I would jump at the chance to fly a primary glider just for the fun of it.) And let me correct my words when my brain slipped out of gear with my fingers: The ratio of completed projects to *started* projects is pretty small. The suggestion to buy a production glider in ratty shape and do the restoration work yourself is an excellent idea. You can get an early model 1-26 with ragged fabric for practically nothing, and you'll get all kinds of experience, including the art of applying aircraft fabric. Note that you would have to work with an aircraft mechanic during the project to keep it all safe and legal. I think we're back to the basic questions that we've all been guessing at. What is your current situation, and what is it that you really want? Is low cost the primary concern? Is being able to say that *you* built the glider you're flying very attractive to you? The important thing is to end up with the glider that fits *you*, not what the rest of us think is the best idea. Jim Beckman  |
You may be a candidate to build one of Mike Sandlin's "Airchairs".
	They're soarable, Floyd Fronius has flown one about 60 miles or so. They're car toppable. They're a pretty quick build. If you want "slightly better than primary glider performance", you might consider putting a fairing on a GOAT, and reinventing the secondary glider. Mike's documentation of what he has done (he does not call them plans) are very complete, and available for free on his website. Take a look at http://home.att.net/~m--sandlin/bug.htm and see if that meets your criteria. If you don't already fly, you'll still need instruction in something with three-axis controls. Tim Ward  |
			 "Flash" wrote in message ... Folks, I've been lurking and reading your group for a good while. I admire the talent it takes to fly, with or without power, and those who do this. Thanks, all, for the reasoned and reasonable response. I guess I've got to go to the gliderport and mooch a ride or two, and listen a lot. I have flight experience in T-34, T-37, a half a century ago, courtesy the USAF. And 10 hrs dual in a Cessna 150, a decade ago. Now, I'm sort-of *retired*, and wondering if the urge to fly is as strong as it was in the past. There was a homebuilder in my area, a few years ago. He still had the record for the largest single-engine all-wood personally designed and built - and it was still in his hangar when he went west. Two others of his homebuilts were there, then, too. His record was five, he was building #6. He was my impetus to consider homebuilding. I even bought the plans and material to build a Bounsall Super Prospector, but in moving to smaller quarters three years ago, I donated it all to the local EAA chapter. But the option of buy ratty and restore might work best, and I hadn't given that any thought, before. It just might be time to go shopping, and the gliderport might be the first, best stop. Again, thank you all for the sound responses. Flash  |
