Fly wrote:
Expensive. My set up costs: Bottle of Nitrogen is about $100 A set of victor guages that the refirgeration guys use is about $110. 0-600 PSI on the low side. $13 for the gooseneck to fit the schrader valve and $25 to have a long hi-pressure hose made. Keep in mind that it a takes high pressure to force the schrader's needle valve open. Kent Felkins Tulsa Ok, today I got the nitrogen bottle, it was about $100 for 40 (liters?). The regulator is high side is 0-4000 psi, low side 0-200 PSI. Is this enough, or do I need to exchange that, and what pressure is required? Standard pressure hoses, as I am sure you are aware, are only good up to 200psi. Thanks for all the hints. Scott Moore |
Ok, today I got the nitrogen bottle, it was about $100 for 40 (liters?). The regulator is high side is 0-4000 psi, low side 0-200 PSI. Is this enough, or do I need to exchange that, and what pressure is required? Standard pressure hoses, as I am sure you are aware, are only good up to 200psi. Seems it takes 200-300 psi. to open the schrader... What plane you have? Kent |
Fly wrote:
Ok, today I got the nitrogen bottle, it was about $100 for 40 (liters?). The regulator is high side is 0-4000 psi, low side 0-200 PSI. Is this enough, or do I need to exchange that, and what pressure is required? Standard pressure hoses, as I am sure you are aware, are only good up to 200psi. Seems it takes 200-300 psi. to open the schrader... What plane you have? Kent C-172. Scott Moore |
-----Original Message----- From: Fly [mailto:fly at Tulsaconnect.com] Posted At: Monday, December 04, 2006 5:28 PM Posted To: rec.aviation.owning Conversation: Filling with nitrogen Subject: Filling with nitrogen .... Keep in mind that it a takes high pressure to force the schrader's needle valve open. The needle on the Schrader valve is opened with the center post of the hose end, not from high-pressure in the hose. The fill adapter depresses the valve stem. Kent Felkins Tulsa |
The needle on the Schrader valve is opened with the center post of the hose end, not from high-pressure in the hose. The fill adapter depresses the valve stem. You have one of those fancy $30 adaptors that the turbine guys use. Most common for GA lights planes is just the gooseneck by itself. I started to explain about the tee-post adaptor but left it alone. I think Aircraft tool supply carries them... Kent |
Ok, I'm showing in the $400's to get that high. The regulator I got, a
victor 0871-0044, 5-125 psig is $146. http://www.toolfetch.com/Brand/Victo...ng/Regulators/ What I am going to use this for is to fill tires and service the strut at my powerless tiedown location. The price difference covers that the strut pump costs: http://www.aircraft-tool.com/shop/de...x%3fPageNo%3d1 Besides I assume also having the correct fittings I need for the scheader valve. So it seems the way to go is stay with the low pressure system I have for tires, then use the strut pump to multiply pressure to get that done, which is a less frequent event. Have I missed anything? Scott Moore Fly wrote: Expensive. My set up costs: Bottle of Nitrogen is about $100 A set of victor guages that the refirgeration guys use is about $110. 0-600 PSI on the low side. $13 for the gooseneck to fit the schrader valve and $25 to have a long hi-pressure hose made. Keep in mind that it a takes high pressure to force the schrader's needle valve open. Kent Felkins Tulsa |
http://www.aircraft-tool.com/shop/flyer.aspx
Shows a strut pump coupler. My regulator says Victor Medalist P250-500 Kent |
I was thinking about this kit for my struts. The hand pumps are nice for an emergency fill with air or H if you have a tank sitting around, but this kit isn't too much more money and stowes nicely away. http://www.polyperformance.com/shop/...&cat=11&page=1 On Mon, 4 Dec 2006 17:28:07 -0600, "Fly" fly at Tulsaconnect.com wrote: Expensive. My set up costs: Bottle of Nitrogen is about $100 A set of victor guages that the refirgeration guys use is about $110. 0-600 PSI on the low side. $13 for the gooseneck to fit the schrader valve and $25 to have a long hi-pressure hose made. Keep in mind that it a takes high pressure to force the schrader's needle valve open. Kent Felkins Tulsa "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message ... "scott moore" wrote in message . .. Hi, I am considering purchase of a nitrogen fill system. I don't have power at my tiedown, and filling the tires with a 12 volt portable compressor is a pain due to having to park the car near the tire, move to the other side, etc. I figgured a nice nitrogen tank system would give me a power free solution and fill the tire with the best possible kind of gas. I found a fill system online: http://www.aircraftspruce.com/catalo...trogenTire.php My only question is why it says "no struts". That would seem to me to be one of the best uses of this system, that I can top off my strut, which is forever going low (on a Cessna). Is there a reason for this restriction, and is there a system that can do struts? Thank you. Scott Moore A $40 ten gallon air tank is way more than enough for tires. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Capt. Geoffrey Thorpe wrote:
A $40 ten gallon air tank is way more than enough for tires. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Agreed. I have a 5 Gallon tank (purchased for about $20 at Kragen) which I take home to fill using my compressor about once or twice a year. With no power in the hangar, this little tank works great to top off the tires. It works well enough that I haven't bothered to keep track, but I'd guess that I can put 2-5 lbs in all three tires for some 5 to 10 occasions before I'd need to refill the tank. Steve |
. .. Hi, I am considering purchase of a nitrogen fill system. I don't have power at my tiedown, and filling the tires with a 12 volt portable compressor is a pain due to having to park the car near the tire, move to the other side, etc. I figgured a nice nitrogen tank system would give me a power free solution and fill the tire with the best possible kind of gas. I found a fill system online: http://www.aircraftspruce.com/catalo...trogenTire.php My only question is why it says "no struts". That would seem to me to be one of the best uses of this system, that I can top off my strut, which is forever going low (on a Cessna). Is there a reason for this restriction, and is there a system that can do struts? Thank you. Scott Moore Nitrogen for tires? Isn't that kindof expensive? I have a cordless air compressor. Rechargeable. Has a built in light. Clearly designed for emergency car use. I love it. I think I bought it at K-Mart and I have no idea how much I paid. I just Googled and saw prices ranging from $40 to $60. Mine has been pumping away for about 6 years now. I use it for the airplane, the car, the boat trailer, bicycles, no name it. It has A/C charger and a cigarette lighter adapter for recharging. ------------------------------- Travis Lake N3094P PWK |
| Thread Tools | |
| Display Modes | |
| Military falls on hard times in filling key jobs, report says | Otis Willie | Naval Aviation | 1 | November 26th 05 03:00 PM |
| Filling Holes | AKperson | Owning | 1 | July 20th 05 04:54 PM |
| filling Oxygen tanks | Bruce McFadden | Piloting | 40 | January 3rd 05 04:25 AM |
| Filling oxygen tanks | Bruce McFadden | Owning | 49 | December 29th 04 12:41 AM |
| 172 Nosewheel Struts Leak Nitrogen | jls | Owning | 4 | April 9th 04 07:28 PM |
