ASH-25 flutter
Old June 27th 15, 03:27 AM posted to rec.aviation.soaring
Default ASH-25 flutter
http://youtu.be/fUIidefCaA8
Wow, hope this isn't common!
Old June 27th 15, 04:40 AM posted to rec.aviation.soaring
Dave Nadler
Not flutter...
Old June 27th 15, 09:07 AM posted to rec.aviation.soaring
Ross[_3_]
That actually has a more technical name.
It is more commonly known as the Delore Shuffle
Old June 27th 15, 12:50 PM posted to rec.aviation.soaring
Joe
Dave Nadler explained:
Not flutter...
Not helpful.
Old June 27th 15, 04:07 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Time for another JJ story. We were finishing at Ephrata at 50 feet and 140 knots in our ASH-25 (with 2 meter wing extensions). As I crossed the finish line, I pulled up and rolled left,. At about 45 degree left bank, I applied right stick to stop the left roll............IT KEPT ROLLING LEFT................I then applied full right stick and rudder and the left roll stopped, but by then we were in a 75 degree left turn. The nose was up, so as airspeed slowed, the ship slowly responder to right stick commands.
After landing, I talked to the guy running the finish gate who was looking right down our wing as we flew through the gate...........He said it was the scariest thing he had ever seen! The wing tip leading edge, twisted down and doug-in, resulting in the un-commanded left turn, the rest of the wing looked like a sign wave. The wing extension had been somewhat blessed by Schleicher who had us install some 12# of lead in the outboard leading edge. I believe it was to prevent flutter, but probably aided the twist problem. Any aerodynamic experts explain why the lead was placed in the leading edge? Didn't it help twist the wing leading edge down?
Not too long after that, I sold the ship and retired to the peace and tranquility of the finish cylinder in sports class.
JJ
Old June 27th 15, 05:52 PM posted to rec.aviation.soaring
Andrew[_14_]
Sounds like a aileron control reversal issue. It's both an aerodynamic and structural issue just like flutter. Although, unlike flutter it doesn't excite a natural frequency but rather a divergence of the structure. A term for it is aeroelastic divergence. The torsional load produced by the deflected aileron twists the wing which changes the angle of attack of the wing enough to reverse the rolling direction.
This is not my area of expertise, but I have been educated on it. The fix is usually to increase torsional stiffness or limit control effectiveness or lower the redline speed. The divergence speed can be different than the flutter speed. Wish I could comment about the leading edge lead... I can't think of an explanation for now.
After landing, I talked to the guy running the finish gate who was looking right down our wing as we flew through the gate...........He said it was the scariest thing he had ever seen! The wing tip leading edge, twisted down and doug-in, resulting in the un-commanded left turn, the rest of the wing looked like a sign wave. The wing extension had been somewhat blessed by Schleicher who had us install some 12# of lead in the outboard leading edge.. I believe it was to prevent flutter, but probably aided the twist problem.. Any aerodynamic experts explain why the lead was placed in the leading edge? Didn't it help twist the wing leading edge down?
JJ
Old June 27th 15, 07:04 PM posted to rec.aviation.soaring
I've seen it in power planes and regardless of what you call it
it WILL take the wing off and send you to the morgue.
Old June 27th 15, 09:09 PM posted to rec.aviation.soaring
Bruce Hoult
At a speed where the engine is out and not over revving? That's not flutter, that's wiggling the controls...
Old June 28th 15, 12:55 AM posted to rec.aviation.soaring
You've got to be kidding.
Old June 28th 15, 01:35 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
If you want to see real flutter, take a look at this:
https://www.youtube.com/watch?v=kQI3AWpTWhM
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
High altitude flutter - Vne bildan Soaring 58 January 8th 09 09:04 PM
Question - rudder flutter ? Bravo Two Zero Piloting 47 December 27th 07 02:31 PM
Can Washout Cause Flutter?? DonMorrisey Home Built 12 January 19th 07 03:32 AM
Counterweighting to prevent flutter [email protected] Home Built 11 June 10th 05 04:51 AM
Tail flutter! I Can Computer Services Home Built 3 November 24th 03 01:56 AM
