Comparison of glider classes at Uvalde...
Old August 26th 12, 01:57 AM posted to rec.aviation.soaring
kirk.stant
Default Comparison of glider classes at Uvalde...
What is the optimum G for the pullup?
Or is it more a matter of pulling to ClMax - so an AOA gauge is really needed?
Let's say a generic 15 meter flapped ship, at 8psf and 145 knots - my gut feel is about a 3 g pull while simultaneously setting some flap (0 or +5) is close to optimum. Pull to about 40 degrees nose up, ease off to 1 g, then roll off to let the nose drop to level (no bunt).
How do the rest of you do it?
Kirk
66
  #32
Old August 26th 12, 04:30 AM posted to rec.aviation.soaring
Tom Claffey
Not like that.
If crosscountry speed is your aim reduce the pushing and pulling.
Tom
need=
ed?
f=
is=
then=
Kirk
66
  #33
Old August 26th 12, 06:40 AM posted to rec.aviation.soaring
kirk.stant
Not crosscountry gain - max height gain in a pullup; for example after a low pass.
Kirk
66
  #34
Old September 2nd 12, 02:38 PM posted to rec.aviation.soaring
KA6CR Driver
Kirk
66
I wonder; is the heigth loss the same in a push over? Would the energy exchange be the same as in a zoom?
DW
  #35
Old September 2nd 12, 04:07 PM posted to rec.aviation.soaring
Dan Marotta
Not remembering the entire thread, and just responding to this question, a
push over followed by a pull up will always result in an altitude loss (in
still air). We're talking conservation of energy here. Engineers and
scientists will understand. This is not a perfect system and there will be
friction losses (drag). Every time you deflect your control surfaces, you
incur a drag loss. I do this all the time...
"KA6CR Driver" wrote in message
low pass.
Kirk
66
DW
  #36
Old September 2nd 12, 05:27 PM posted to rec.aviation.soaring
John Cochrane[_3_]
still air). *We're talking conservation of energy here. *Engineers and
scientists will understand. *This is not a perfect system and there will be
friction losses (drag). *Every time you deflect your control surfaces, you
incur a drag loss. *I do this all the time... *
low pass.
Kirk
66
DW
Some basics in my view:
The first thing to get right is not the push or pull, you're doing
this to adjust airspeed. So the most basic issue is when do you want
to speed up and slow down to follow lift and sink. That is primarly a
question of whether the lift or sink will last. There isn't much point
in a huge pull up in east coast punchy isolated thermals, because by
the time you've got the glider slowed down, you're through the thermal
and in to the sink. If the lift is lined up in to the wind, under a
cloud, streeting, clumping, or otherwise giving signs that it will
still be there when you've slowed down, then a pull up and even a
sharp pull up works
The second issue is the dynamic soaring effect. Yes, a pull and push
in still air loses height. But pulling up in lifting air and pushing
over in sinking air gains energy. This is hard to do. Really, you want
to pull when the glider still has momentum from the previous air and
is now in new air. You want to pull when the net lift+drag vector is
pointing forward relative to the path of the glider. Then, increasing
lift+drag speeds up the glider. So a sharp pull when you run in to
sharply increasing lift can gain energy.
A lot of the art of squeezing good glides comes from doing this just
right.
Two good winter projects: Work out the dynamic program of how to
optimally extract energy from a sharp-edged gust, given you don't know
when it's going to come. And create the next generation of "dynamic
soaring" varios that indicates when adding gs adds energy. Its not
that hard to do -- is the lift+drag vector pointing forward relative
to the path of the glider?
John Cochrane
  #37
Old September 2nd 12, 08:05 PM posted to rec.aviation.soaring
Roel Baardman
Related read:
http://home.planet.nl/~kpt9/Hoogtewinst.htm
Should be pretty readable with Google Translate (from Dutch to English).
  #38
Old September 5th 12, 07:43 AM posted to rec.aviation.soaring
The Dutch study is fun but unrealistic - adopted time 3s means 150m lift diameter for a cruising speed.
For wider lifts and cumulus ways conclusion would be probably reverse
glider transport from europe to Uvalde Tony[_5_] Soaring 0 April 3rd 12 04:21 AM
Glider for Uvalde 2012 David Jansen Soaring 0 June 21st 11 04:05 AM
Pre Worlds Uvalde Glider Hire Martin RSA Soaring 4 February 15th 11 07:24 AM
IGC announces new glider classes Tim Taylor Soaring 7 March 10th 10 07:16 PM
Classes? XYZ Soaring 0 October 6th 08 05:52 PM
