When I turn on the alternator in my '79 TR-182 I hear a faint highpitched
squeal through the headsets. No squeal when I just run on battery. Is there a simple way to fix this? TIA, Michael |
All right, I did some Google searching (sorry - I should have started there)
and now suspect that my problem is in the grounding. But where in the system? Can I fix this, or is it back to the avionics shop? Thanks, Michael "Michael 182" wrote in message news:JkvTb.163152$sv6.893167@attbi_s52... When I turn on the alternator in my '79 TR-182 I hear a faint highpitched squeal through the headsets. No squeal when I just run on battery. Is there a simple way to fix this? TIA, Michael |
![]() Michael 182 wrote: All right, I did some Google searching (sorry - I should have started there) and now suspect that my problem is in the grounding. But where in the system? Can I fix this, or is it back to the avionics shop? One thing you can do yourself is to isolate the jacks. Buy special fiber washers that have a double-thickness cylinder in the center. Remove each jack from the panel, re-drill or ream the hole in the panel to fit the center section of the isolation washer, and re-install the jack with a plain fiber washer in the front. The two fiber washers keep any metal parts of the jack from touching the airframe, so the only way the jack is grounded is the ground wire to the intercom. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
A convert!
MikeM G.R. Patterson III wrote: One thing you can do yourself is to isolate the jacks. Buy special fiber washers that have a double-thickness cylinder in the center. Remove each jack from the panel, re-drill or ream the hole in the panel to fit the center section of the isolation washer, and re-install the jack with a plain fiber washer in the front. The two fiber washers keep any metal parts of the jack from touching the airframe, so the only way the jack is grounded is the ground wire to the intercom. |
![]() "G.R. Patterson III" wrote in message ... Michael 182 wrote: All right, I did some Google searching (sorry - I should have started there) and now suspect that my problem is in the grounding. But where in the system? Can I fix this, or is it back to the avionics shop? One thing you can do yourself is to isolate the jacks. Buy special fiber washers that have a double-thickness cylinder in the center. Remove each jack from the panel, re-drill or ream the hole in the panel to fit the center section of the isolation washer, and re-install the jack with a plain fiber washer in the front. The two fiber washers keep any metal parts of the jack from touching the airframe, so the only way the jack is grounded is the ground wire to the intercom. Hate to be dense (not that I have a choice) but does the "double-thickness cylinder in the center" mean something like a grommet? Something like this? http://www.marcorubber.com/grommets_commercial.htm Thanks, Michael George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
Michael 182 wrote:
"G.R. Patterson III" wrote in message ... Michael 182 wrote: All right, I did some Google searching (sorry - I should have started there) and now suspect that my problem is in the grounding. But where in the system? Can I fix this, or is it back to the avionics shop? One thing you can do yourself is to isolate the jacks. Buy special fiber washers that have a double-thickness cylinder in the center. Remove each jack from the panel, re-drill or ream the hole in the panel to fit the center section of the isolation washer, and re-install the jack with a plain fiber washer in the front. The two fiber washers keep any metal parts of the jack from touching the airframe, so the only way the jack is grounded is the ground wire to the intercom. Hate to be dense (not that I have a choice) but does the "double-thickness cylinder in the center" mean something like a grommet? Something like this? http://www.marcorubber.com/grommets_commercial.htm Thanks, Michael George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. They are called "shoulder washers", usally made of fiber or nylon. Tom Pappano, PP-ASEL-IA |
![]() "Tom Pappano" wrote in message y.com... They are called "shoulder washers", usally made of fiber or nylon. Tom Pappano, PP-ASEL-IA Got it. Thanks, Michael |
![]() Michael 182 wrote: Hate to be dense (not that I have a choice) but does the "double-thickness cylinder in the center" mean something like a grommet? Something like one side of a grommet. When used in conjunction with the mating flat washer, the two washers essentially form a grommet. IIRC, I bought the washers for the jacks in my aircraft at a local electronics store, but I may have had to order them. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
I have a UK military headset plugged into a flying lead which comes
from the back of the centre console. I have the whine, though it's not very noticeable until the alternator is switched off and it goes away and you then notice its absence. Paul "G.R. Patterson III" wrote in message ... One thing you can do yourself is to isolate the jacks. |
Odd alternator behavior | [email protected] | Home Built | 0 | August 8th 04 02:45 PM |
Alternator teststand | Nathan Young | Home Built | 8 | May 31st 04 04:15 PM |
Auto Alternator on an O-320-E2D | Ebby | Home Built | 8 | November 26th 03 02:46 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
Alternator failure modes (long) | mikem | Owning | 1 | September 21st 03 07:47 PM |
