Holding
Old December 13th 11, 11:35 AM posted to rec.aviation.ifr
___P:Sir
Default Holding
The 1 min timing (or 1½ min above 14.000 feet) - is that in Your opinion
inbound or outbound leg? Doc 8168 says "outbound no wind" - but that might
be a matter of definition, because all pro`s I asked, says Inbound...?
regards..
P.sir
Old December 13th 11, 12:25 PM posted to rec.aviation.ifr
Ron Rosenfeld[_2_]
Default Holding
regards..
P.sir
In the US, the timing is for the inbound leg. The timing for the outbound leg gets adjusted to achieve the 1 minute or 1 1/2 minute inbound leg timing:
Here is what the AIM says:
The initial outbound leg should be flown for 1 minute or
1 1/2 minutes (appropriate to altitude). Timing for
subsequent outbound legs should be adjusted, as
necessary, to achieve proper inbound leg time.
Old December 13th 11, 01:15 PM posted to rec.aviation.ifr
___P:Sir
Default Holding
"Ron Rosenfeld" skrev i en meddelelse
regards..
P.sir
timing:
Thanks - if it is like that in the US, it surely must be in Europe as well?
P.Sir
Old December 13th 11, 10:32 PM posted to rec.aviation.ifr
Ron Rosenfeld[_2_]
Default Holding
P.Sir
I have no way of knowing that. I have not trained in Europe and my only experience flying in Europe has been VFR.
However, my brief perusal of some documentation I have from Jepp which references the ICAO document 8168 leads me to believe that such may NOT be the case in Europe.
Corrections for wind effect paragraph seems to state that the adjustment required on the outbound leg, for heading and timing, is only such as to ensure the aircraft is established on the inbound track before passing the holding fix. This is quite different from the wording in the US AIM and implies that the inbound timing can be much less than the "still-air" 1 or 1 1/2 minutes.
Holding Pattern Question Dennis Johnson Instrument Flight Rules 60 September 29th 07 07:52 AM
While Holding for a Briefing Today... Kyle Boatright Piloting 28 May 21st 07 04:42 AM
Bose X - $995 and holding... [email protected] Piloting 23 November 30th 05 01:57 AM
Holding at CHS Stuart King Instrument Flight Rules 3 November 10th 03 08:52 PM
Holding Pattern Entries Dan Luke Instrument Flight Rules 17 July 11th 03 06:18 AM
