Normal voltage drop
Old December 28th 04, 12:53 AM
Robert M. Gary
Default Normal voltage drop
When I turn on a lot of accessories on my Mooney F '76 I can drop the
bus voltage down to around 13.6. My A&P says 13.6 is normal with
accessories on. Does this sound right?
-Robert
Old December 28th 04, 01:20 AM
Morgans
-Robert
At cruise RPM? Sounds like you may have 1 or 2 of the three diodes burnt
out in your alternator. Another possibility is that your voltmeter is off.
Try checking it with a digital voltmeter, and comparing the two.
Jim in NC
Old December 28th 04, 03:13 AM
Robert M. Gary
burnt
is off.
Any RPM between 800 and 2700 gives the same voltage, no change. I
normally read the voltage in 4 ways
1) My EDM shows it on the screen
2) My regulator flashes a voltage light on my panel when low
3) My voice annunicator says, "Check bus voltage" and
4) My A&P has been putting his probe all over the place
Since I can reproduce this at idle on the ground its easy for the A&P
to hook up under the panel. I should also note that...
1) Have a new battery, new master switch, and new regulator
2) I took my regulator and alternator to an aviation electrical
overhaul shop. They bench tested the combo at 14v up to 100amp draw.
They didn't find any diode issues, but I'm willing to believe they
could be wrong.
-Robert, M20F '76
Old December 28th 04, 03:15 AM
Robert M. Gary
I guess my question is; do all planes generate about 13.6v with
accessories on? I also teach in a large variety of planes, but none
have a volt reader in the panel.
Old December 28th 04, 04:06 AM
zatatime
On 27 Dec 2004 19:15:04 -0800, "Robert M. Gary"
I'm not a mechanic, but 13.8 volts comes to mind as what I've read on
my battery while the engine was running. I'd think .2 volts less
under load would be acceptable. You still have 1.6 volts of excess
power to charge the battery with so I really wouldn't worry about it.
I think sometimes, with the new digital equipment, readings can be
more accurate than the tolerances of the old stuff used to build it in
the first place.
What's the tolerance of your voltage regulator? If it's +/- .5 volts,
you've got your answer.
My .02.
z
Old December 28th 04, 04:18 AM
Morgans
Actually, the voltage for a lead acid battery should be 12.8 volts, at full
charge, not 12 volts.
Jim in NC
Old December 28th 04, 04:07 AM
G.R. Patterson III
According to AC 43.13-1A -- "The voltage drop in the main power wires from the
generation source or the battery to the bus should not exceed 2 percent of the
regulated voltage, when the generator is carrying rated current or the battery
is being charged at the 5-minute rate. The following tabulation shows the
maximum acceptable voltage drop in the load circuits between the bus and the
utilization equipment."
The table indicates that 1/2 volt is acceptable for a steady load and 1 volt for
an intermittent load. This passage is intended to be used to determine whether
wiring is properly sized.
According to that, you should be seeing at least 13.72 volts at the bus, but as
little as 12.72 is acceptable at an appliance that produces a temporary load.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old December 28th 04, 04:50 AM
Robert M. Gary
from the
percent of the
the battery
and the
It's interesting that if I take the alternator and regulator to the
bench I can hold 100amp without dropping below 14v. I guess the
in-airplane application is a lot different than the bench environement.
-Robert
Old December 28th 04, 11:04 PM
G.R. Patterson III
What I posted are the minimal requirements for minimizing voltage drop in the
wiring from the regulator to the bus and from the bus to appliances (such as the
NAV/COM). The voltage at the regulator on the bench will certainly be different
than that measured at the bus.
George Patterson
Old January 3rd 05, 04:12 AM
Robert M. Gary
from the
percent of the
the battery
and the
-Robert
C182 - Intermittent Alternator WinstonCup Owning 9 November 12th 04 12:22 AM
no RPM drop on mag check Dave Butler Owning 19 November 2nd 04 02:55 AM
Cessna 210 charging problem John Clonts Owning 9 July 14th 04 03:08 PM
Normal EGT - Very Low CHT markjen Owning 7 March 4th 04 01:54 PM
Anyone have experience with InterAv alternator flyer Home Built 6 October 19th 03 03:24 AM
