Lining fuselage dolly
Old April 23rd 14, 07:00 PM posted to rec.aviation.soaring
Colin Roney
Default Lining fuselage dolly
Any ideas regarding the best material to line the inside of a fuselage
dolly which will allow the glider to be slid in or out.
Old April 23rd 14, 08:32 PM posted to rec.aviation.soaring
Bob Kuykendall
Old sawzall blades.
Or the stuff they call "German Felt." That's what I use.
Thanks, Bob K.
Old April 23rd 14, 09:50 PM posted to rec.aviation.soaring
Bill D
You probably have a local supplier of industrial gasket materials. One of those materials is "gasket felt" - a very firm, smooth material available in thickness's up to 1/2" which works great with contact cement. The one I visited had enough scrap around to do a whole trailer - it cost me $5 IIRC.
Old April 23rd 14, 11:48 PM posted to rec.aviation.soaring
Peter Higgs
Some people use axminster carpet, or an old mat., glued in place.
Old April 24th 14, 03:42 AM posted to rec.aviation.soaring
jfitch
Depending on the trailer and glider, you may not want to use all felt. It will slip around pretty easily. That's why Cobra, at least on many of their dollies, uses a band of foam rubber like material in the middle - to give it enough friction to stay put.
Old April 25th 14, 12:26 AM posted to rec.aviation.soaring
Pete Smith[_4_]
their
Perfect material,buy a roll mat out of outdoors shop will do dolly and
trailer and enough over for kneeling pads and lots of things,
Old April 25th 14, 02:44 AM posted to rec.aviation.soaring
Tim Taylor
I found indoor/outdoor carpet with the rubber backing (used on boats) to work well. I found some on sale at the big box stores.
Old April 24th 14, 01:43 PM posted to rec.aviation.soaring
Mark628CA
I second what jfitch posted about the non-slip liner. A friend had just waxed his newly refinished Discus to within an inch of its life (including the belly), and when it was placed in the cradle without the wings and the canopy open, a gust of wind was enough to hit the rudder and tip it to the right until the canopy struck the ground. Result? A new canopy to go with the refinish and an "adjustment" in his insurance premium.
I recommend the cheap knobby toolbox or shelf liner. Get the white color. Just lay a 12 inch wide strip in the bottom of the cradle. Remember that you don't really want to let the fuse slip at all- it is a bad idea to load the glider by sliding it into the cradle. If it is that frictionless, remember that the fuselage needs very good restraints in the trailer.
Old April 24th 14, 04:35 PM posted to rec.aviation.soaring
Bob Kuykendall
On Thursday, April 24, 2014 5:43:43 AM UTC-7, Mark628CA wrote:
I second what jfitch posted about the non-slip liner...
Another vote for the used sawzall blades, then.
Fuselage dolly with over center jack - looking for picture Tim Taylor Soaring 4 July 17th 12 03:21 AM
fuselage dolly caster Brad[_2_] Soaring 9 September 10th 11 02:48 AM
ASK-21 fuselage dolly bildan Soaring 8 August 1st 10 05:43 PM
EA-6B lining up for final approach at Pensacola NAS Tom Callahan Aviation Photos 0 February 23rd 07 05:00 PM
el nino's silver lining bagmaker Soaring 0 October 23rd 06 07:08 AM
