Water Injection Question
Old July 9th 04, 05:45 PM
DeltaDeltaDelta
Default Water Injection Question
A couple of days ago, I saw a picture of a DC-8, i think, taking off,
trailing thick black smoke from the engines (they weren't on fire). The
description of the picture said that it was using water injection to give
more power for takeoff. I also came across this when reading about the P-47.
How does that system work? I presume it's different for pistons and jets.
Triple Delta
Old July 9th 04, 06:05 PM
Darkwing Duck \(The Duck, The Myth, The Legend\)
"DeltaDeltaDelta" wrote in message
P-47.
Triple Delta
Doesn't this have something to do with methanol fuels and water? Supposedly
water increases HP in methanol.
Old July 9th 04, 07:17 PM
Scott Skylane
Triple Delta
Triple,
I am not sure about the jet physics. In the piston (large radial) world,
a water/alcohol mix is injected just downstream of the carburettor for
hight power operation. This has the effect of reducing combustion
chamber temperatures, thus allowing higher manifold pressures (i.e. HP)
without detonation. If you didn't inject water at these power settings,
the amount of excess fuel needed to keep the temps down would actually
flood the mixture, causing power loss.
The alcohol in the mix does virtually nothing to contribute to the power
output, it is there merely to keep the water fromm freezing at altitude.
Interestingly, Pratt & Whitney apparently stumbled upon this effect
while doing heavy rain water injestion tests in the early days.
Happy Flying!
Scott Skylane
Old July 9th 04, 07:24 PM
Scott Skylane
while doing heavy rain water *injestion* tests in the early days.
Happy Flying!
Scott Skylane
Woops! Make that *ingestion*
Old July 9th 04, 08:31 PM
DeltaDeltaDelta
Hmm...interesting. I always wondered about that MW50 (nethanol-water)
mixture used on some Luftwaffe WW2 fighters (most notably on the FW-190 and
derivatives)...Thanks for the info
Triple Delta
"Scott Skylane" wrote in message
Happy Flying!
Scott Skylane
Old July 10th 04, 04:06 AM
steve
Geez Scott,
I've got 5 textbooks that cover water injection and they dont even come
close to explainin git as well as you did..way to go
give
P-47.
jets.
Triple Delta
Triple,
Happy Flying!
Scott Skylane
Old July 10th 04, 10:00 AM
Dale
without detonation.
Scott,
Are you guys using ADI on the -6?
And congrats on making First Officer!!
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old July 12th 04, 06:39 AM
Scott Skylane
Dale wrote:
/snip/
Scott,
Dale,
Yes, we use it, generally for takeoffs above about 85,000 lbs. If
anyone's interested the fuel burn for an R2800 CB-16 is as follows:
Max Dry power (53" M.P. 2800 RPM 1950 HP) 1850 lbs/hr
Max Wet power (59.5" 2800 RPM 2400 HP) 1550 lbs/hr
And thanks for the congrats!! It sure beats working for a living
Happy Flying!
Scott Skylane
Old July 9th 04, 08:36 PM
Mike Rapoport
Water injection cools the air both before and after combustion. The lower
temperatures allow more fuel to be burned (turbine) or allow more MP or
compression to be used without detonation (piston).
Mike
MU-2
P-47.
Triple Delta
Old July 10th 04, 01:42 AM
Jim Baker
P-47.
Triple Delta
3D.....See Rapoports answer for the technical explanation. Aircraft such as
the B-52 models prior to the G and the KC-135A used water injection takeoff
thrust if the weight and weather demanded it. It was a tremendous boost in
thrust in the B-52G and when the water ran out, a big deacceleration. As
you noticed, water injected takeoffs caused a lot of smoke.
JB
Induction System Water Problem Mike Spera Owning 1 January 30th 05 06:29 AM
Questions regarding Air/Oil Separators Doodybutch Owning 6 April 20th 04 06:56 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 10:41 AM
C-17s as water bombers Ross Oliver Piloting 11 November 12th 03 03:22 AM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 10:47 PM
