Compass Questions ?
Old July 14th 15, 12:36 AM posted to rec.aviation.piloting
Bob
Default Compass Questions ?
Hello,
Not a Pilot, but always interested in the engineering aspects.
This question came up, and I realize that I am not sure of a correct answer.
Regarding the compass heading that shows in the glass displays:
How is it derived ?
GPS ?
If not GPS, what ?
Is it then Magnetic or True ?
Does the Pilot have to correct for variation/declination changes during
a flight ?
Does aviation use True or Magnetic when discussing or flying ?
etc. ?
Thanks,
Bob
Old July 14th 15, 01:20 AM posted to rec.aviation.piloting
Larry Dighera
Hello Bob,
I'm unable to provide the answer as to the technology employed by
computer-generated displays to display magnetic information, but I would expect
something like a Hall device might be employed. As you implied, it could as
easily be derived from GPS data corrected for magnetic variation at the
particular location.
Magnetic/compass headings are not true, but magnetic. Navigation Sectional
charts http://skyvector.com/ are depicted in True coordinates, and the
pilot/navigator must correct for magnetic variation in drafting his flight
plan. ATC expects all course/heading numbers to be magnetic.
You'll find more information he
http://www.faa.gov/regulations_policies/handbooks_manuals/, and he
http://www.faa.gov/regulations_policies/handbooks_manuals/aviation/pilot_handbook/media/PHAK%20-%20Chapter%2015.pdf.
Hope that helps.
Best regards,
Larry Dighera
On Mon, 13 Jul 2015 18:36:54 -0400, Bob wrote:
Hello,
How is it derived ?
GPS ?
If not GPS, what ?
a flight ?
etc. ?
Thanks,
Bob
Old July 14th 15, 12:47 PM posted to rec.aviation.piloting
Bob
Hi,
Thanks for replies and help.
What I was referring to are the new, modern, "glass" displays where most
everything shown is derived
from transducers located elsewhere.
e.g. when a display shows a Heading of, e.g., 075, it is of course
getting this info. from some kind of transducer, located elsewhere.
Is it derived directly from GPS ?
A Hall effect compass ?
or,... ?
Thanks again; interesting subject.
Bob
On 7/13/2015 6:36 PM, Bob wrote:
Hello,
answer.
How is it derived ?
GPS ?
If not GPS, what ?
a flight ?
etc. ?
Thanks,
Bob
Old July 14th 15, 07:01 PM posted to rec.aviation.piloting
Don Poitras
Dave Doe wrote:
, Dave Doe says...
lid, Bob
says...
Hi,
or,... ?
Well I'm not sure on that - perhaps others will reply. However,
cellphones usually use one or more magnetometers (hope I spelt that
right ). A GPS can't get a magnetic heading, only True.
I play with Arduino's a bit - and Googling 'arduino magentometer' gives
a few results, eg...
http://bildr.org/2011/01/hmc6352/
http://bildr.org/2012/02/hmc5883l_arduino/
http://eclecti.cc/hardware/hmc5843-m...ry-for-arduino
I *assume* that the compass in a glass display uses the same sort of
technology.
Apologies to the apostrophe police - that's terrible!
Duncan.
The display in a glass panel is GPS course. You need a magnetic compass to know
your heading. The difference between the two is wind correction, magnetic
variation and compass deviation.
While I don't doubt that someone could create a device that would send
magnetic heading info to a glass panel, it would have to be some obvious
secondary display. You want to be looking at your true course if you want
to get from A to B.
Don Poitras
Old July 15th 15, 12:36 PM posted to rec.aviation.piloting
Dave Doe
In article , , Don
Poitras says...
Dave Doe wrote:
, Dave Doe says...
lid, Bob
says...
Hi,
or,... ?
technology.
Duncan.
to get from A to B.
The OP is asking about just about such a device. And it's clear they do
exist in a glass display (a compass that is).
Take for example, the Cessna website. If you navigate to say the Cessna
TTx - and check out the glass Avionics section, and look at Equipment
Details (rather than Standard Features), it specifies a Magnetometer ...
"GMU-44 Magnetometer (dual)"
Albiet a compass is almost obsolete and uncessary with todays navigation
equipment, but let's not forget runways - still lined up and named
magnetic. Makes me wonder when that will change.
Duncan.
Old July 15th 15, 04:39 PM posted to rec.aviation.piloting
Dallas
The heading information from the PFD comes from a directional gyro. The
directional gyro's drift is constantly corrected (slaved) by a magnetic
compass located in the tailcone on the airplane. The output of this compass
is electrically "enhanced" and amplified through a "flux gate".
Bottom line: A very accurate, stable, compass reading that never needs
adjustment.
Dallas
Old July 15th 15, 10:56 PM posted to rec.aviation.piloting
Skywise
Dallas wrote in
september.org:
adjustment.
And to expand on that a bit...
https://en.wikipedia.org/wiki/Attitu...ference_system
Brian
http://www.earthwaves.org/forum/index.php - Earth Sciences discussion
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Sed quis custodiet ipsos Custodes?
WTB: PZL KI-13 Compass Romeo Delta Soaring 1 October 30th 17 08:47 AM
Still have a compass? [email protected] Soaring 19 November 22nd 13 11:33 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 08:39 AM
Looking for a PZL compass Kirk Stant Soaring 8 February 12th 04 10:27 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 07:06 AM
