Locating device mounting
Old June 23rd 18, 05:08 PM posted to rec.aviation.soaring
Default Locating device mounting
Recent descriptions of the Nephi accident are driving me to rethink my decision about location of my Spot in the ship.
I have had it mounted on the canopy frame to try to get the best view of the sky for tracking. It kind of gets in the way a little when on the chute harness.
My assumption has been that in the event of a bad thing happening both the glider and I will be in close proximity.
I got it wrong.
My Spot will go back on the harness.
1- It stays with me.
2- Assuming I'm capable I can orient it and activate emergency even if I have bailed out.
FWIW
UH
Old June 23rd 18, 05:49 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
I got it wrong.
FWIW
UH
Anything you expect to help folks find you needs to be attached to the front of your chute. Otherwise it is camping gear.
I have my SPOT3 on chest strap (works fine). SMAK PAK Survival Kit on right shoulder caries cellphone, whistle, mirror, strobe and space blanket.
Old June 23rd 18, 05:57 PM posted to rec.aviation.soaring
Ramy[_2_]
Absolutely. Your spot or inreach should be with you. They both work very well even if they have limited view of the sky.
Same goes to your cell phone (and a spare external battery) should be in your pocket, preferrebly a zipped pocket.
Ramy
Old June 23rd 18, 06:03 PM posted to rec.aviation.soaring
I got it wrong.
FWIW
UH
Might consider adding a spare pair of spectacles (as needed) to the SMAK Pak or somewhere secure on your person.
Old July 15th 18, 05:11 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Godfrey (QT) wrote on 6/23/2018 8:49 AM:
I got it wrong.
FWIW
UH
You have the parachute to keep you warm and provide some shelter. What is the
purpose of the space blanket?
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old July 15th 18, 02:10 PM posted to rec.aviation.soaring
I got it wrong.
FWIW
UH
Parachute may get hung up on landing (trees, rocks) and not be useable (see YO pictures). Takes up very little volume.
Old July 15th 18, 03:20 PM posted to rec.aviation.soaring
Dan Daly[_2_]
I got it wrong.
FWIW
UH
Also waterproof (and can be used as a field expedient water container), and glints in sunlight, which is very handy for a SAR crew looking for you.
Old July 15th 18, 05:32 PM posted to rec.aviation.soaring
Dan Marotta
A space blanket staked out on the ground can be a good signaling device.
And, for those of us who want a cushion between our lower backs and
parachutes, consider a rolled up blanket.Â* Your rigger should be able to
sew on some soft straps or cords with which to tie it securely in place.
I got it wrong.
FWIW
UH
the front of your chute.Â* Otherwise it is camping gear.
I have my SPOT3 on chest strap (works fine).Â* SMAK PAK Survival Kit
blanket.
is the purpose of the space blanket?
Dan, 5J
Old July 15th 18, 10:41 PM posted to rec.aviation.soaring
Blanket is better than nothing.
"Space foam" (various names) is better, although sucks when cold until it warms up a bit.
Trust me, I know.
I have now broken my back twice (non aviation related), spinal comfort is good.
Yes, I have done sorta long flights in a 1-26, no good way to fit there. Kudos to those that do 10hrs or so in the seat....sheesh......thus, "Iron Butt" comment.......
Old July 24th 18, 05:06 AM posted to rec.aviation.soaring
2G
On Sunday, July 15, 2018 at 1:41:58 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
Trust me, I know.
A signalling mirror is also a good idea. Here is how to use one:
https://www.youtube.com/watch?v=6lvMD7u2jOI
Tom
EE help please - - locating Schottky diode [email protected] Soaring 9 April 30th 13 12:26 AM
PowerFlarm mounting question, and an idea for mounting devices brianDG303[_2_] Soaring 2 October 23rd 11 07:51 PM
Need Help Locating a Camloc Latch. Ebby Home Built 1 October 20th 06 03:36 AM
Need Help Locating Owner Ross Owning 2 April 3rd 06 06:30 PM
locating Jiran Paul Gaines Soaring 0 December 10th 05 12:57 AM
