EE help please - - locating Schottky diode
Old April 29th 13, 10:00 PM posted to rec.aviation.soaring
Default EE help please - - locating Schottky diode
Want to install Schottky diode Mouser part# 844-95SQ015 http://www.mouser.com/ds/2/427/95sq015-27345.pdf in all 3 of my battery supply lines.
Setup is spar-shelf batteries "+" side through 5 amp flat auto fuse Anderson PowerPole connectors + and - wire under seat-pan all 3 "+" through panel mounted on/off switch positive terminal block with entire input side "jumped". All 3 "-" battery leads go to negative terminal block with entire input side "jumped".
Where is the proper place to locate the diodes? Which way will the diode ring orientate?
On the negative terminal block, should there also be a ground wire run to the elevator/aileron yoke?
Thanks.
Ben
Need Help Locating a Camloc Latch. Ebby Home Built 1 October 20th 06 03:36 AM
Battery Contactor Diode? Skrud Home Built 25 September 11th 06 07:17 PM
Need Help Locating Owner Ross Owning 2 April 3rd 06 06:30 PM
locating Jiran Paul Gaines Soaring 0 December 10th 05 12:57 AM
Locating Gas Pumps at Airports FS2004 Arthur Alspector Simulators 5 March 13th 04 11:32 PM
