The sense antenna on our Cardinal broke right at the crimp connector
that attaches to the feedthrough insulator at the top front of the airplane. This thing appears to be made of 18 gauge copperweld wire. Since I still have the antenna and can pull measurements from it, is there any reason I can't fabricate a replacement myself? Or does that crimp connection have to be made with an aircraft-rated crimp tool? Dave Reinhart |
asbestos britches on
The problem right from the getgo is that the copperweld (which is steel wire with a copper coating) broke where it was rigidly attached to a nonmoving bolt. When the wire flexed in the breeze, this became the pivot point and eventually work hardened and crystallized that point of the wire to failure. Let's think of some ways to keep that from happening on the next antenna... 1. How about some wire that is a little more resistant to work hardening than copper over steel? 2. How about some sort of a flex joint where the wire attaches to the insulator? 3. How about some sort of strain relief at this point? 4. How about a noncrimp connection; the main stress on the crimp is where the wire is already weakened by flattening inside the crimp.? 5. How about a spring mechanism to keep a relatively constant tension on the wire? I've got MY answers to these questions, but I'd like to hear from the rest of the gang first. asbestos britches off Jim "David Reinhart" wrote in message ... The sense antenna on our Cardinal broke right at the crimp connector that attaches to the feedthrough insulator at the top front of the airplane. This thing appears to be made of 18 gauge copperweld wire. Since I still have the antenna and can pull measurements from it, is there any reason I can't fabricate a replacement myself? Or does that crimp connection have to be made with an aircraft-rated crimp tool? Dave Reinhart |
Buy a KR-87 and dump the old garbage. No other ADF could possibly still be
worth keeping. Friendly as always, karl "RST Engineering" wrote in message ... asbestos britches on The problem right from the getgo is that the copperweld (which is steel wire with a copper coating) broke where it was rigidly attached to a nonmoving bolt. When the wire flexed in the breeze, this became the pivot point and eventually work hardened and crystallized that point of the wire to failure. Let's think of some ways to keep that from happening on the next antenna... 1. How about some wire that is a little more resistant to work hardening than copper over steel? 2. How about some sort of a flex joint where the wire attaches to the insulator? 3. How about some sort of strain relief at this point? 4. How about a noncrimp connection; the main stress on the crimp is where the wire is already weakened by flattening inside the crimp.? 5. How about a spring mechanism to keep a relatively constant tension on the wire? I've got MY answers to these questions, but I'd like to hear from the rest of the gang first. asbestos britches off Jim "David Reinhart" wrote in message ... The sense antenna on our Cardinal broke right at the crimp connector that attaches to the feedthrough insulator at the top front of the airplane. This thing appears to be made of 18 gauge copperweld wire. Since I still have the antenna and can pull measurements from it, is there any reason I can't fabricate a replacement myself? Or does that crimp connection have to be made with an aircraft-rated crimp tool? Dave Reinhart |
According to AOPA it has to be done by an authorized repair station.
Dave Reinhart David Reinhart wrote: The sense antenna on our Cardinal broke right at the crimp connector that attaches to the feedthrough insulator at the top front of the airplane. This thing appears to be made of 18 gauge copperweld wire. Since I still have the antenna and can pull measurements from it, is there any reason I can't fabricate a replacement myself? Or does that crimp connection have to be made with an aircraft-rated crimp tool? Dave Reinhart |
Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 06:59 PM |
ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 03:27 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
comm's RX antenna | acepilot | Home Built | 5 | March 3rd 04 05:34 PM |
LS-4 Transponder antenna location? | Matt Herron | Soaring | 3 | February 25th 04 03:45 PM |
