How Do You Evaluate an OLC Flight ?
Old April 24th 21, 11:29 PM posted to rec.aviation.soaring
Default How Do You Evaluate an OLC Flight ?
I would like to know how others evaluate an OLC flight and determine the difficulty factor involved? I will hold my opinion until this has been truly debated. Old Bob
Old April 25th 21, 06:47 PM posted to rec.aviation.soaring
Tony[_7_]
The file may have a declaration embedded, but I suppose you would have to download it to read it. Other than that, there's no comparison with committing to a task. Of course there's much to be said for skillful task-setting!
Old April 26th 21, 08:01 PM posted to rec.aviation.soaring
Jason Leonard
sub'd
Old April 27th 21, 12:07 AM posted to rec.aviation.soaring
Matthew Scutter
You won't believe it Bob, but the OLC does it for you and allocates points accordingly!
Old April 27th 21, 12:11 AM posted to rec.aviation.soaring
Matt, it must be a conspiracy! The question was how do you, not OLC, it flew right over your head.
Old April 27th 21, 10:42 PM posted to rec.aviation.soaring
Mike the Strike
Some years ago, OLC added bonus points for triangle flights after analyzing many cross-country flights - adding about 30% in points as I recall. Before that, points were based solely on distance and glider handicap.
This is a pretty rough guesstimate of evaluation - distance plus triangle bonus - but there are plenty of other variables left out.
Feel free to develop a new set of algorithms!
Mike
Old April 28th 21, 07:56 PM posted to rec.aviation.soaring
Mike
Mike, you are on the correct path. Old Bob
Old April 28th 21, 09:29 PM posted to rec.aviation.soaring
5Z
The folks at WeGlide.org appear to be open to scoring formula and data presentation suggestions. I just asked them to somehow identify declared fights. These are often more difficult that an ad-hoc choice once in the air.
5Z
Mike
Old April 28th 21, 09:30 PM posted to rec.aviation.soaring
Tony[_5_]
I usually look at the circling % to analyze how difficult a particular flight was.
Mike
Old April 29th 21, 04:12 AM posted to rec.aviation.soaring
2G
Bob, you would have to define "difficulty" to get a meaningful answer.
Tom
EA-6b a-flight-crew-sits-in-the-cockpit-of-an-ea-6b-prowler-aircraft-on-the-flight-e63638-1600.jpg 803 (1/1) J3[_2_] Aviation Photos 0 July 5th 19 08:28 PM
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
Army to evaluate existing airframes for Kiowa Replacement. vaughn[_3_] Piloting 4 October 14th 11 06:30 AM
Army to evaluate existing airframes for Kiowa Replacement. VOR-DME[_4_] Piloting 0 October 13th 11 05:36 PM
How to evaluate a respirator? Qualities? mhorowit Home Built 6 May 28th 06 07:27 PM
