Avionics -- superflags
Old November 28th 04, 05:22 PM
Michalk
Default Avionics -- superflags
What are the 400mA current sink superflags used for? I've got them on
my Apollo equipment, but they only show hookups to older equipment.
Old November 29th 04, 09:36 PM
Jerry J. Wass
Wot's a bloody Superflag???
Old November 29th 04, 08:56 PM
Michalk
That's what I would like to know.
Old November 30th 04, 04:43 AM
Gerry Caron
Some of the old electro-mechanical HSIs and Flight Directors had separate
flag inputs for LOC and GS (for those that had separate LOC and GS
receivers; or at least separate flag outputs), and another "Superflag" input
that controlled both flags simultaneously. Some have just a GS and a
Superflag. In that case, the GS flag input controls just the GS flag and
the Superflag controls both LOC and GS; the Superflag being tied to the LOC.
The theory being that if you lose GS, you can function in LOC-only mode; but
if you lose LOC, GS is meaningless and should be flagged as well.
It's called a superflag because it flags both LOC and GS. You need that
400mA current capability to handle all those solenoids.
Gerry
"Jerry J. Wass" wrote in message
Old December 4th 04, 07:59 PM
B2431
Date: 11/29/2004 22:43 Central Standard Time
Message-id:
Gerry
What are flag pull and rate of turn voltages? On the rate of turn is the
pointer deflection voltage curve linear?
Dan, U.S. Air Force, retired
Old December 6th 04, 06:20 AM
Dean Wilkinson
"Gerry Caron" wrote in message om...
Actually Gerry, its called a superflag because it operates at the bus
voltage (14VDC or 28VDC depending on the airplane). A standard flag
operates at around 0.5VDC and is current driven while a superflag is
driven by a signal at the bus voltage... I designed an avionics box
recently that converted VOR and LOC from analog to digital, and had to
deal with these flags.
Dean
Avionics -- superflags Michalk Home Built 0 November 28th 04 05:22 PM
Real World test bed for avionics - Megawatts at Delano MikeremlaP Home Built 0 June 2nd 04 04:24 AM
ARTHUR Avionics Henning DE Home Built 0 November 19th 03 08:51 PM
hardware to mount avionics trays Matthew M. Jurotich Home Built 1 November 17th 03 10:56 PM
Avionics Swap Group Jim Weir Home Built 3 July 7th 03 02:27 PM
