Can a single GPS antenna be used for more than one GPS? For example,
is there a splitter available that allows both a panel mount GPS and a handheld to use an installed GPS antenna? |
150flivver wrote:
: Can a single GPS antenna be used for more than one GPS? For example, : is there a splitter available that allows both a panel mount GPS and a : handheld to use an installed GPS antenna? Although I haven't done so, I'd imagine it's possible. A few things to consider, however. External GPS antennas for aircraft are usually amplified. The radio puts 5VDC on the coax and the antenna has a LNA inside it. Also, to keep impedances correct, the splitter will likely either have to be lossy, or active. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
google "Wilkinson" "hybrid power divider" and "IRE Transactions" before
saying stuff like this. The answer to the OP's question is that yes, it is possible, fairly easy, and needs an active antenna to do the job right. Jim Also, to keep impedances correct, the splitter will likely either have to be lossy, or active. -Cory |
RST Engineering wrote:
Also, to keep impedances correct, the splitter will likely either have to be lossy, or active. google "Wilkinson" "hybrid power divider" and "IRE Transactions" before saying stuff like this. What's the matter? To divide the antenna power to several receivers always means some loss to a single receiver. In an ideal case, a passive divider to two branches will show a loss of 3 dB to both branches, and this means no power loss in the divider. An active divider can compensate for the losses with an amplifier. The division losses always exceed zero if the impedances are not properly matched, which will show more than 3 dB in divide to two. -- Tauno Voipio, avionics engineer tauno voipio (at) iki fi |
![]() "Tauno Voipio" wrote in message ... RST Engineering wrote: Also, to keep impedances correct, the splitter will likely either have to be lossy, or active. google "Wilkinson" "hybrid power divider" and "IRE Transactions" before saying stuff like this. What's the matter? The "matter" is defining "loss". In general, we do not say that a device is lossy unless the incoming power is greater than the outgoing power. In the case of the Wilkinson (or any variety of hybrid) splitter, the "loss" (if any) is measured in tenths of a dB for any decent design. There are a series of truly "lossy" resistive splitters that are not acceptable for this particular application. To divide the antenna power to several receivers always means some loss to a single receiver. In an ideal case, a passive divider to two branches will show a loss of 3 dB to both branches, and this means no power loss in the divider. An active divider can compensate for the losses with an amplifier. With something on the order of 26 dB active gain in the typical external GPS antenna, and with a loss of something on the order of 8 to 10 dB in the normal run of coax from antenna to receiver, you are still something like 16-18 dB ahead of the game over a stock passive antenna. A 3 dB reduction in signal level (30% in voltage) will not be noticeable. Why would you go to the hassle of an active splitter at 1.7 GHz. when it is not necessary? Remember, a good engineer can build a bridge that will stand up to maximum design loads plus safety factor. An EXCELLENT engineer can build a bridge that will stand up to maximum design loads plus safety factor JUST BARELY. The division losses always exceed zero if the impedances are not properly matched, which will show more than 3 dB in divide to two. Like I said, in a properly designed hybrid, losses are measured in feathers, not bricks. -- Tauno Voipio, avionics engineer tauno voipio (at) iki fi Jim Weir Avionics Technician at 16 Avionics Engineer at 22 Avionics Engineer Emeritus after 40 years in the 'biz with any kind of luck at all in a couple more years. (Emeritus = "on the shelf") |
not necessary? Remember, a good engineer can build a bridge that will stand up to maximum design loads plus safety factor. An EXCELLENT engineer can build a bridge that will stand up to maximum design loads plus safety factor JUST BARELY. Oh what the heck!!! Let's make this real world... A good engineer can build a levy that will stand up to a Level 5 hurricane plus safety factor. An EXCELLENT engineer can build a levy that will stand up to a Level 5 hurricane plus safety factor JUST BARELY. And let's add the corillary... for tens of billions of dollars less. |
{Splitting a GPS Antenna}
I'll say the same thing I said comm/nav antennas. You'd adding to your single point of failures. If GPS is important to you; get separate antennas.. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
As pointed out earlier, you have to determine if the two GPS receivers
supply 5V to the antenna, and if the antenna requires 5V (active antenna). After determining this, the divider must supply both the RF division and pass through the 5V from one of the GPS (if the antenna is active and gets its power from the coax) This is not quite as simple as just hybrid or resistive RF power divider because of the 5V for the LNA inside of many GPS antennae. More info is needed on the receivers and the antenna. Peace, John Severyn EE @KLVK "Tauno Voipio" wrote in message ... RST Engineering wrote: Also, to keep impedances correct, the splitter will likely either have to be lossy, or active. google "Wilkinson" "hybrid power divider" and "IRE Transactions" before saying stuff like this. What's the matter? To divide the antenna power to several receivers always means some loss to a single receiver. In an ideal case, a passive divider to two branches will show a loss of 3 dB to both branches, and this means no power loss in the divider. An active divider can compensate for the losses with an amplifier. The division losses always exceed zero if the impedances are not properly matched, which will show more than 3 dB in divide to two. -- Tauno Voipio, avionics engineer tauno voipio (at) iki fi |
It is trivial. You let the one side of the hybrid direct couple the signal
and let the other side of the hybrid capacitively couple the signal. THe downside is that the DC receiver has to be on and working to let the AC receiver work. A bit more work with diodes and chokes can be done as a work-around to let either of the receivers power the active antenna. Jim "J. Severyn" wrote in message news:QsOdncAU7pUX6gbeRVn- This is not quite as simple as just hybrid or resistive RF power divider because of the 5V for the LNA inside of many GPS antennae. More info is needed on the receivers and the antenna. |
Gyrocopter VHF antenna length | Lew | Home Built | 2 | August 18th 05 01:52 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 03:27 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
comm's RX antenna | acepilot | Home Built | 5 | March 3rd 04 05:34 PM |
