TIM'S ABCS
Old February 15th 04, 04:29 PM
epsalant
Default TIM'S ABCS
Once upon a time I used the pneumonic TIM'S ABCS to set up for an
approach. I have forgotten what everything stands for (I believe it
begins Tune, Identify, Markers...).
Does anyone remember the rest? And do you know what book it's from?
Thanks!
Evan
Old February 15th 04, 07:43 PM
Rick Glasser
Thanks!
Evan
These are what my instructor taught:
AWOS/Weather
Brief the Approach
Checklist
DG check
Rick/JYO
PP-ASEL-IA
remove 'nospam' to reply
Old February 15th 04, 11:41 PM
Doug
West Coast Rail Road
Weather
Clearance
Radios
Review (the approach)
and for the missed its 5 C's
Cram it
Clean it
Cool it (carb heat and cowl flaps)
Climb it
Comunicate it
Old February 16th 04, 12:08 AM
Andrew Sarangan
This is exactly the pitfall of memorizing acronyms. If you can't
remember what it stands for from the comfort of your home, do you
think you will recall it when flying in a dark and bumpy cockpit? It
is for this reason that I don't teach acronyms.
(epsalant) wrote in message . com...
Thanks!
Evan
Old February 16th 04, 03:05 AM
Teacherjh
Well, an acronym helps one remember something that is being refreshed at a
medium frequency. If the task is refreshed at a high frequency, the mnemonic
is unnecessary, if it is refreshed at too low a frequency, the task itself
becomes unfamiliar.
Acronyms have their place. However they are not everything at all times.
Jose
Old February 18th 04, 02:19 PM
Teacherjh
It would be nice if it worked out that the letters always stood for
the same thing, but it doesn't. Like "G". What does "G" stand for?
Gyro? Gear? Gust?
We'd need as many letters as words. Spelling would be easy, but I'd neverl
earn the alphabet!
G - Gear.
U - Umm, something about gear.
M - Main landing gear.
P - Please tell me the gear is down.
S - Static landing gear is always down.
Gas, Undercarriage, Mixture, Pitch, Seatbelts.
Pitch refers to propeller pitch.
G does refer to Gas.
Another acronym I have - in the piper archer and dakota I fly, the row of
identical switches (awful design, but all too common) are labeled, but in the
dark, in a rush, in a blur, one can't read the labels. So I use FLAP
In order, left to right (after the master) is
Fuel pump
Landing light
Anticollision (strobe) lights
Pitot heat.
So now it's not gas, it's fuel. But it works.
I once played with a device which was cobbled together from old parts of this
and that (it set up and ran Conway's game of Life on the TV screen), and it had
about four switches, but they were all different. It was a cinch to operate
because each function was assigned to a different KIND of switch. I could tell
by feel what everything did. Smart aircraft designers should do the same. (in
fact, all aircraft designers should take a lesson from this - it's not limited
to throttle, mixture, pitch, flap, and wheel)
Jose
Old February 18th 04, 05:15 PM
Henry A. Spellman
I had the same problem on my Comanche with a long row of identical
switches at the bottom of the instrument panel. Two switches in the
middle of the row controlled the left and right wing tip landing
lights. At night, one could not see which switch controlled what. I
slid a short piece of clear plastic tube over the toggle of those two
switches so they feel different from all the others. I have not had a
problem since.
Hank
Henry A. Spellman
Comanche N5903P
Fuel pump
Landing light
Pitot heat.
Jose
Old February 18th 04, 09:33 PM
Ben Jackson
Not only that, different Comanches I've flown have them in *different
orders*. I thought I had mine memorized, but I turned off the runway
the other night and turned off the landing light instead of the fuel
pump.
You've got a good idea there, I think I'll try it.
Ben Jackson
http://www.ben.com/
