Airport Radial/Distance/Fix on Jepp Airport Chart
Old May 1st 04, 02:38 AM
Dave Johnson
Default Airport Radial/Distance/Fix on Jepp Airport Chart
I "discovered" Jepp has decided to remove the radial/distance/from fix info
on the airport plan view that defined the ARP.
Am I the only one that uses the info .. loaded into the RNAV .. so, for
example, when ATC says 'radar contact 6 NE of the xyz airport' I can look at
the RNAV and verify that I am that far from it? Until I had RNAV I
basically just agreed with ATC.
Well anyway, they decided to drop the info off the charts and it appears
didn't notify any of their subscribers.
Dave
Seneca III driver
Old May 1st 04, 01:51 PM
Dave
Seneca III driver
What's the problem? With RNAV, the airport identifier is the position of the
ARP. That could either be the active waypoint or referred to on the "NRST"
airports reference page.
Old May 2nd 04, 12:08 AM
Dave Johnson
wrote in message ...
info
look at
Dave
Seneca III driver
"NRST"
The PROBLEM is .... my King RNAV unit requires me to enter the
aforementioned data manually into one of four storage slots and I don't
carry it around in my head. It was on the Jepp Airport chart.
Old May 2nd 04, 12:52 AM
Roy Smith
In article 46Wkc.10279$Ik.844723@attbi_s53,
info
look at
Dave
Seneca III driver
"NRST"
Have you tried talking to Jepp and expressing your desire that the
information stay on the charts? I've known them to be pretty responsive
to user input.
Old May 2nd 04, 10:41 AM
Aeroplanner and other database web sites have all those ARPs. The system is at
the point now where 99.999% of RNAV systems have full databases. Roy thinks
Jeppesen might put the information back on the chart if you ask. I don't share
that view.
Old May 2nd 04, 12:55 PM
Dave Johnson
is at
thinks
share
that view.
Well, since I have asked Jepp .. which is how I found out they just did it
without notification of their customers .. and received the response that my
issue will be passed on to those who control such things, we will see what
the outcome is.
It is a far cry from obtaining the data from the airport plan view page
while in flight to having to obtain it on the ground before flight,
especially if you were to have to look up each and every airport over a
large area. Isn't ease of obtaining data in the cockpit what the original
Captain Jeppesen had in mind?
Let me clarify my use of "RNAV". I am not talking about a system with
internal data bases, which seems to be what you are thinking about. I guess
today RNAV equals GPS and other modern processor based systems. I am
talking about the original use of RNAV which was a displaced VOR/DME system
where the unit required you to enter the freq, radial, and distance. King
made at least two versions of this and there were a lot of these units
placed in new and used aircraft over the years. There are probably still a
goodly number of these units in use. I would hope that those who fly with
them have be instructed how to use them for ARP's which is a handy
application of that eras equipment. Even when I fly aircraft equipped with
both the old RNAV and a GPS unit I carry RNAV flight plan data as a backup
in case the GPS system drops out .. which it did one night on an IFR flight
due to Rockwell-Collins testing in the area I was flying through.
Dave
Old May 2nd 04, 06:52 PM
Indeed that is what he had in mind. He didn't know, however, about electronic
databases coming along many years later that would replace some of the
information on the chart. Note for instance, no RNAV (GPS) IAPs have LAT/LONs
on the chart because they are in the database and automatic.
There are always exceptional situations, of course.
Old May 2nd 04, 11:03 PM
Richard Kaplan
"Dave Johnson" wrote in message
news:bl5lc.13925$0H1.1351096@attbi_s54...
I agree the information would be helpful to put back on the charts.
In the interim, it might be helpful for you to know that the
Airport/Facility Directory lists Radial/Distance to a nearby VOR for every
airport. So that could be an easy way for you to ge this information in
flight, albeit not as easy as having the info on the approach plate.
Richard Kaplan, CFII
www.flyimc.com
Old May 2nd 04, 04:32 PM
Stan Prevost
KNS-80
info
look at
Dave
Seneca III driver
"NRST"
Old May 2nd 04, 06:53 PM
Stan Prevost wrote:
KNS-80
I know, sort of like computed ADF.
SWRFI update... Moving again (argghh!!)... Dave S Home Built 14 October 15th 04 03:34 AM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 30th 04 11:41 PM
JEPP Chart Users Ross Richardson Instrument Flight Rules 6 March 29th 04 10:58 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
