Last weekend I flew IFR Paine to Eugene. I filed V23, but was cleared
to the west along OLM V165 UBG V495 CVO EUG. Similar routing for the return flight. I asked each controller (except Seattle Approach) for vectors EUG direct when able, but each controller said they needed to keep me on the airway through either Portland or Cascade Approach's airspace. Question: is this a typical routing? TIA, Ethan |
Yes. You will get V-27 southbound and V-23 northbound, whether you like it
or not. I used to run packages between Boeing and Oakland every night and I learned this lesson early. Bob Gardner wrote in message oups.com... Last weekend I flew IFR Paine to Eugene. I filed V23, but was cleared to the west along OLM V165 UBG V495 CVO EUG. Similar routing for the return flight. I asked each controller (except Seattle Approach) for vectors EUG direct when able, but each controller said they needed to keep me on the airway through either Portland or Cascade Approach's airspace. Question: is this a typical routing? TIA, Ethan |
![]() From Seattle area going south bound (or northbound into Seattle area from Oregon/CA) you almost always have to funnel over Olympia. South of OLM Seattle center will let you cut corners as long as you're above 5-6000 or so. wrote: Last weekend I flew IFR Paine to Eugene. I filed V23, but was cleared to the west along OLM V165 UBG V495 CVO EUG. Similar routing for the return flight. I asked each controller (except Seattle Approach) for vectors EUG direct when able, but each controller said they needed to keep me on the airway through either Portland or Cascade Approach's airspace. Question: is this a typical routing? TIA, Ethan |
Jeppesen flitepro=no sound | Angelo Campanella | Simulators | 0 | March 27th 06 09:54 PM |
The price of gas | C J Campbell | Piloting | 167 | June 4th 04 06:06 PM |
How Aircraft Stay In The Air | Sarah Hotdesking | Military Aviation | 145 | March 25th 04 05:13 PM |
Puget Sound TFRs reduced in size - charted here | David H | Owning | 3 | January 10th 04 06:01 AM |
Puget Sound TFRs reduced in size, turned into National Security Areas | C J Campbell | Piloting | 4 | January 10th 04 06:01 AM |
