Ok, I just stepped up to a better plane with a certified GPS and am about
to go on a cross country (likely IFR). The Direct path takes me across a couple of Restricted Airspace. Should I plan to avoid or file direct and let ATC handle it with the clearance ? Larry. |
![]() "Larry Richardson" wrote in message ... The Direct path takes me across a couple of Restricted Airspace. Should I plan to avoid or file direct and let ATC handle it with the clearance ? A lot of people do the latter. I prefer to avoid if I can reasonably do so and avoid the vectors. Usually filing airways through that area will keep you clear, or direct to a nearby VOR and then direct to your destination. Several times I have filed an avoidance route, then received an amended clearance enroute, direct to destination. First, check the SUA altitude limits, you may can fly over or under it. Also, some are activated by NOTAM and you can determine the need to avoid by checking NOTAMs. Stan |
![]() "Stan Prevost" wrote: A lot of people do the latter. I prefer to avoid if I can reasonably do so and avoid the vectors. Usually filing airways through that area will keep you clear, or direct to a nearby VOR and then direct to your destination. Stan's right, but don't cut it too close or you may get vectored anyway. Your GPS may show you missing some SUA by 3 or 4 miles, but that's often not far enough for the controller's comfort. -- Dan C-172RG at BFM |
![]() "Dan Luke" wrote in message ... "Stan Prevost" wrote: A lot of people do the latter. I prefer to avoid if I can reasonably do so and avoid the vectors. Usually filing airways through that area will keep you clear, or direct to a nearby VOR and then direct to your destination. Stan's right, but don't cut it too close or you may get vectored anyway. Your GPS may show you missing some SUA by 3 or 4 miles, but that's often not far enough for the controller's comfort. Yes, I have noticed the same thing. I have filed a route that cleared the area by 3 miles (per chart) but got vectored anyway. Not often, though. Stan |
Larry Richardson wrote:
The Direct path takes me across a couple of Restricted Airspace. Should I plan to avoid or file direct and let ATC handle it with the clearance ? File direct. If you have to go around it, they'll tell you. If you don't have to, that's all the better. |
![]() "Brien K. Meehan" wrote in message ... If you have to go around it, they'll tell you. If you don't have to, that's all the better. Note that Restricted, Warnings, and MOA's you'll get routing around IFR. IFR doesn't save you against TFR's universally. |
In article , "Ron Natalie"
writes: Note that Restricted, Warnings, and MOA's you'll get routing around IFR. IFR doesn't save you against TFR's universally. Are you saying that the controllers don't know the TFR's? That prts the burden back on the pilot that can't have the info available once in the air. What a system!! :-( Chuck |
![]() "PaulaJay1" wrote in message ... Are you saying that the controllers don't know the TFR's? That prts the burden back on the pilot that can't have the info available once in the air. What a system!! :-( Welcome to life in these United States. |
I file around SUA that is likely to be active since it shortens the route
compared to getting routed around ir when you are close. Mike MU-2 "Larry Richardson" wrote in message ... Ok, I just stepped up to a better plane with a certified GPS and am about to go on a cross country (likely IFR). The Direct path takes me across a couple of Restricted Airspace. Should I plan to avoid or file direct and let ATC handle it with the clearance ? Larry. |
