Is there any reason, or regulation, that states that a pilot, flying
VFR, is prohibited in flying a GPS approach to an uncontrolled field (assuming VFR conditions at the field), or must the pilot fly the usual pattern to land? Thanks. Bob |
BobKK47 wrote:
Is there any reason, or regulation, that states that a pilot, flying VFR, is prohibited in flying a GPS approach to an uncontrolled field (assuming VFR conditions at the field), or must the pilot fly the usual pattern to land? FAR 91.113, 91.126, 91.127, and AC 90-66A seem to be the FAA's guidance on the subject. |
Dave has provided the regulatory info, but the bottom line is that you can
do pretty much whatever you want to do at an uncontrolled field in VFR conditions...and sometimes people do some really weird and unexpected things. If a pilot wants to shoot a practice instrument approach of any kind to such an airport, the result will be a straight-in, which is covered by the Advisory Circular he cites. Part 91 contains all of the operational regulations you will ever need as a Part 91 pilot. Anything that is not specifically prohibited is allowed. Bob Gardner "BobKK47" wrote in message oups.com... Is there any reason, or regulation, that states that a pilot, flying VFR, is prohibited in flying a GPS approach to an uncontrolled field (assuming VFR conditions at the field), or must the pilot fly the usual pattern to land? Thanks. Bob |
Courtesy and regulations both apply. Regulations do not
prohibit straight-in approaches, they say "if turns are made." Courtesy says you should not fly an approach against the traffic flow into the pattern, as well as regulations about right of way. Courtesy requires you announce and listen on the CTAF. If all you want is practice, fly the approach 2 or 3,000 feet high. Have all your lights ON. Use two safety pilots who can see well. "Bob Gardner" wrote in message . .. | Dave has provided the regulatory info, but the bottom line is that you can | do pretty much whatever you want to do at an uncontrolled field in VFR | conditions...and sometimes people do some really weird and unexpected | things. If a pilot wants to shoot a practice instrument approach of any kind | to such an airport, the result will be a straight-in, which is covered by | the Advisory Circular he cites. | | Part 91 contains all of the operational regulations you will ever need as a | Part 91 pilot. Anything that is not specifically prohibited is allowed. | | Bob Gardner | "BobKK47" wrote in message | oups.com... | Is there any reason, or regulation, that states that a pilot, flying | VFR, is prohibited in flying a GPS approach to an uncontrolled field | (assuming VFR conditions at the field), or must the pilot fly the | usual pattern to land? | | Thanks. | | Bob | | | |
No argument, Jim, but AC 90-66A clearly shows a straight-in segment to both
single and parallel runways. Bob Gardner "Jim Macklin" wrote in message ... Courtesy and regulations both apply. Regulations do not prohibit straight-in approaches, they say "if turns are made." Courtesy says you should not fly an approach against the traffic flow into the pattern, as well as regulations about right of way. Courtesy requires you announce and listen on the CTAF. If all you want is practice, fly the approach 2 or 3,000 feet high. Have all your lights ON. Use two safety pilots who can see well. "Bob Gardner" wrote in message . .. | Dave has provided the regulatory info, but the bottom line is that you can | do pretty much whatever you want to do at an uncontrolled field in VFR | conditions...and sometimes people do some really weird and unexpected | things. If a pilot wants to shoot a practice instrument approach of any kind | to such an airport, the result will be a straight-in, which is covered by | the Advisory Circular he cites. | | Part 91 contains all of the operational regulations you will ever need as a | Part 91 pilot. Anything that is not specifically prohibited is allowed. | | Bob Gardner | "BobKK47" wrote in message | oups.com... | Is there any reason, or regulation, that states that a pilot, flying | VFR, is prohibited in flying a GPS approach to an uncontrolled field | (assuming VFR conditions at the field), or must the pilot fly the | usual pattern to land? | | Thanks. | | Bob | | | |
I did not mention parallel runways, but in VFR the
bottom-line is you can do almost anything as long as it is safe and doesn't cause a collision hazard. "Bob Gardner" wrote in message . .. | No argument, Jim, but AC 90-66A clearly shows a straight-in segment to both | single and parallel runways. | | Bob Gardner | | "Jim Macklin" wrote in message | ... | Courtesy and regulations both apply. Regulations do not | prohibit straight-in approaches, they say "if turns are | made." Courtesy says you should not fly an approach against | the traffic flow into the pattern, as well as regulations | about right of way. | Courtesy requires you announce and listen on the CTAF. | If all you want is practice, fly the approach 2 or 3,000 | feet high. | | Have all your lights ON. | | Use two safety pilots who can see well. | | | "Bob Gardner" wrote in message | . .. | | Dave has provided the regulatory info, but the bottom line | is that you can | | do pretty much whatever you want to do at an uncontrolled | field in VFR | | conditions...and sometimes people do some really weird and | unexpected | | things. If a pilot wants to shoot a practice instrument | approach of any kind | | to such an airport, the result will be a straight-in, | which is covered by | | the Advisory Circular he cites. | | | | Part 91 contains all of the operational regulations you | will ever need as a | | Part 91 pilot. Anything that is not specifically | prohibited is allowed. | | | | Bob Gardner | | "BobKK47" wrote in message | | | oups.com... | | Is there any reason, or regulation, that states that a | pilot, flying | | VFR, is prohibited in flying a GPS approach to an | uncontrolled field | | (assuming VFR conditions at the field), or must the | pilot fly the | | usual pattern to land? | | | | Thanks. | | | | Bob | | | | | | | | | | | |
![]() "Jim Macklin" wrote in message ... I did not mention parallel runways, but in VFR the bottom-line is you can do almost anything as long as it is safe and doesn't cause a collision hazard. "Bob Gardner" wrote in message . .. | No argument, Jim, but AC 90-66A clearly shows a straight-in segment to both | single and parallel runways. | | Bob Gardner | | "Jim Macklin" wrote in message | ... | Courtesy and regulations both apply. Regulations do not | prohibit straight-in approaches, they say "if turns are | made." Courtesy says you should not fly an approach against | the traffic flow into the pattern, as well as regulations | about right of way. | Courtesy requires you announce and listen on the CTAF. | If all you want is practice, fly the approach 2 or 3,000 | feet high. | | Have all your lights ON. | | Use two safety pilots who can see well. | | | "Bob Gardner" wrote in message | . .. | | Dave has provided the regulatory info, but the bottom line | is that you can | | do pretty much whatever you want to do at an uncontrolled | field in VFR | | conditions...and sometimes people do some really weird and | unexpected | | things. If a pilot wants to shoot a practice instrument | approach of any kind | | to such an airport, the result will be a straight-in, | which is covered by | | the Advisory Circular he cites. | | | | Part 91 contains all of the operational regulations you | will ever need as a | | Part 91 pilot. Anything that is not specifically | prohibited is allowed. | | | | Bob Gardner | | "BobKK47" wrote in message | | | oups.com... | | Is there any reason, or regulation, that states that a | pilot, flying | | VFR, is prohibited in flying a GPS approach to an | uncontrolled field | | (assuming VFR conditions at the field), or must the | pilot fly the | | usual pattern to land? | | | | Thanks. | | | | Bob I was looking at this the other day and ran across this from the AOPA website. An airline pilot was approaching to land using a right hand turn to final. He was far enough out that he argued he actually entered the traffic pattern as a straight-in approach. Another aircraft in the pattern already had to alter course to avoid the airliner. The Alaska Airlines captain of this flight had his ATP certificate suspended for 20 days for making a right turn onto final approach to Runway 8 at Kotzebue. He maintained that the approach he had made qualified as a straight-in approach. He had set up a right base for the runway and told flight service that he intended to make a "right turn into" that runway. He said that he was relying on instructions in the Alaska Airlines flight operations manual, which provide that straight-in approaches at uncontrolled airports "shall be planned so that the aircraft is aligned not less than four nautical miles from the approach end of the runway." Actually, the airplane was not completely aligned until it was about 3.1 miles out, because the turn was begun earlier than anticipated in order to avoid another aircraft in the area. The Board held that even if this was a straight-in approach, it would still be a violation of the regulation because the approach interfered with another aircraft approaching the airport. The evidence showed that the airliner conflicted with a Cessna 402, causing the Cessna to abort a practice VOR/DME approach to the airport. It was the same aircraft that the Boeing captain maintained he altered his course to avoid. The Board said: "Aircraft making valid straight-in approaches at uncontrolled airports would, nevertheless, be deemed in violation of FAR section 91.89(a) [now 91.126 and 91.127] if they interfered with other aircraft operating in the standard left-hand pattern." So, while a straight-in approach to an uncontrolled airport is legal under the FARs, the straight-in approach must be started some considerable (but undefined) distance from the runway and the traffic pattern, and it must not interfere with aircraft in the traffic pattern or on an instrument approach. |
On Mar 5, 11:11 am, "BobKK47" wrote:
Is there any reason, or regulation, that states that a pilot, flying VFR, is prohibited in flying a GPS approach to an uncontrolled field (assuming VFR conditions at the field), or must the pilot fly the usual pattern to land? The only part of the approach that actually happens in the traffic pattern is the very last couple of miles. Usually you can fly the approach and then work into the pattern with traffic. While you are out there doing your procedure turns, etc you are not anywhere near the traffic pattern. -Robert, CFII |
On 03/12/07 15:10, Robert M. Gary wrote:
On Mar 5, 11:11 am, "BobKK47" wrote: Is there any reason, or regulation, that states that a pilot, flying VFR, is prohibited in flying a GPS approach to an uncontrolled field (assuming VFR conditions at the field), or must the pilot fly the usual pattern to land? The only part of the approach that actually happens in the traffic pattern is the very last couple of miles. Usually you can fly the approach and then work into the pattern with traffic. While you are out there doing your procedure turns, etc you are not anywhere near the traffic pattern. -Robert, CFII .... and as was pointed out here recently, if you wish to do a straight-in approach to landing, you must not interfere with any airplanes in the traffic pattern. You must break-off your approach and join the traffic pattern at the appropriate altitude, etc. |
![]() "Mark Hansen" wrote in message ... ... and as was pointed out here recently, if you wish to do a straight-in approach to landing, you must not interfere with any airplanes in the traffic pattern. You must break-off your approach and join the traffic pattern at the appropriate altitude, etc. A straight-in has the right of way. |
Straight-ins at uncontrolled airports? | Danny Deger | Piloting | 188 | February 21st 07 01:39 AM |
Uncontrolled fun | Roy Smith | Piloting | 7 | July 19th 06 10:29 PM |
Closing IFR flight plan at uncontrolled field | paul kgyy | Instrument Flight Rules | 18 | February 9th 06 02:27 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
Position and Hold at uncontrolled field | dave | Piloting | 42 | February 26th 04 01:25 AM |
