Hearing the alternator
Old February 2nd 04, 04:58 PM
Michael 182
Default Hearing the alternator
When I turn on the alternator in my '79 TR-182 I hear a faint highpitched
squeal through the headsets. No squeal when I just run on battery. Is there
a simple way to fix this?
TIA,
Michael
Old February 2nd 04, 05:41 PM
Michael 182
All right, I did some Google searching (sorry - I should have started there)
and now suspect that my problem is in the grounding. But where in the
system? Can I fix this, or is it back to the avionics shop?
Thanks,
Michael
"Michael 182" wrote in message
news:JkvTb.163152$sv6.893167@attbi_s52...
there
TIA,
Michael
Old February 2nd 04, 05:51 PM
G.R. Patterson III
One thing you can do yourself is to isolate the jacks. Buy special fiber washers
that have a double-thickness cylinder in the center. Remove each jack from the
panel, re-drill or ream the hole in the panel to fit the center section of the
isolation washer, and re-install the jack with a plain fiber washer in the front.
The two fiber washers keep any metal parts of the jack from touching the airframe,
so the only way the jack is grounded is the ground wire to the intercom.
George Patterson
Love, n.: A form of temporary insanity afflicting the young. It is curable
either by marriage or by removal of the afflicted from the circumstances
under which he incurred the condition. It is sometimes fatal, but more
often to the physician than to the patient.
Old February 3rd 04, 01:08 AM
mikem
A convert!
MikeM
Old February 3rd 04, 04:54 AM
Michael 182
"G.R. Patterson III" wrote in message
there)
washers
front.
airframe,
Hate to be dense (not that I have a choice) but does the "double-thickness
cylinder in the center" mean something like a grommet?
Something like this?
http://www.marcorubber.com/grommets_commercial.htm
Thanks,
Michael
George Patterson
curable
circumstances
more
Old February 3rd 04, 06:41 AM
Tom Pappano
there)
washers
front.
airframe,
Thanks,
Michael
George Patterson
curable
circumstances
more
They are called "shoulder washers", usally made of fiber or nylon.
Tom Pappano, PP-ASEL-IA
Old February 3rd 04, 06:52 AM
Michael 182
"Tom Pappano" wrote in message
y.com...
Got it. Thanks,
Michael
Old February 3rd 04, 02:20 PM
G.R. Patterson III
Something like one side of a grommet. When used in conjunction with the mating
flat washer, the two washers essentially form a grommet. IIRC, I bought the washers
for the jacks in my aircraft at a local electronics store, but I may have had to
order them.
George Patterson
Old February 4th 04, 06:31 PM
Paul Sengupta
I have a UK military headset plugged into a flying lead which comes
from the back of the centre console.
I have the whine, though it's not very noticeable until the alternator
is switched off and it goes away and you then notice its absence.
Paul
Odd alternator behavior [email protected] Home Built 0 August 8th 04 02:45 PM
Alternator teststand Nathan Young Home Built 8 May 31st 04 04:15 PM
Auto Alternator on an O-320-E2D Ebby Home Built 8 November 26th 03 02:46 PM
Anyone have experience with InterAv alternator flyer Home Built 6 October 19th 03 03:24 AM
Alternator failure modes (long) mikem Owning 1 September 21st 03 07:47 PM
