Does anyone know if any of the major tire companies are still making
the 2.80/2.50-4 tailwheel tire? We've been getting tires from several vendors, all coming under different part numbers and names, but they're all by STA, US made, and they just don't last very long. They seem more plastic than rubber and the centre tread is very shallow and is gone in 30 hours or less. Shimmy isn't a factor in the wear. We used to get much better tires but now I can't find anything other than these. Anybody buying GOOD tires? Dan |
Dan Thomas wrote: Does anyone know if any of the major tire companies are still making the 2.80/2.50-4 tailwheel tire? McCreary makes one. I've been using them on my Maule. I got over 300 hours out of the first one and probably could have run it for a while longer. The one on the plane now has nearly 200 hours and still has excellent tread. I usually buy from Desser. George Patterson A man who carries a cat by the tail learns something that can be learned no other way. |
Dan:
Im use this tire on my 170 and it gets a lot of landings. I have only gone through 2 or 3 in about 700 hours and one was premature due to my stupidity and reluctance to fill the tire when it was cold. The biggest cause for premature wear is under inflation. I run mine at 34 lbs/sq in and check it regularly. If you let them get even a bit low, you will destroy the tire and the tube in no at all time. BTDT. Pete Dan Thomas wrote: Does anyone know if any of the major tire companies are still making the 2.80/2.50-4 tailwheel tire? We've been getting tires from several vendors, all coming under different part numbers and names, but they're all by STA, US made, and they just don't last very long. They seem more plastic than rubber and the centre tread is very shallow and is gone in 30 hours or less. Shimmy isn't a factor in the wear. We used to get much better tires but now I can't find anything other than these. Anybody buying GOOD tires? Dan -- Peter D. Brown http://home.gci.net/~pdb/ http://groups.yahoo.com/group/akmtnsoaring/ |
McCreary makes one. I've been using them on my Maule. I got over 300 hours out of the first one and probably could have run it for a while longer. The one on the plane now has nearly 200 hours and still has excellent tread. Do you think the airport will give me a discount, given that I never make stall-down landings unless I have to salvage a bounce? I've been renting Cubs for five years, and there have been lots of moans and complaints about replacement stuff. But oddly enough I don't ever recall anyone jawing about the need to replace tailwheel tires on a regular basis. These planes surely go over 300 hours in the course of a summer. Shimmying -- now, that was a problem for a long time. Once a broken spring. Locking up. But maybe I only notice the things that affect me. I'll ask around. all the best -- Dan Ford email: (put CUB in subject line) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"REMOVE TO REPLY.pdb" "REMOVE TO wrote in message ...
Dan: Im use this tire on my 170 and it gets a lot of landings. I have only gone through 2 or 3 in about 700 hours and one was premature due to my stupidity and reluctance to fill the tire when it was cold. The biggest cause for premature wear is under inflation. I run mine at 34 lbs/sq in and check it regularly. If you let them get even a bit low, you will destroy the tire and the tube in no at all time. BTDT. Pete The pressure is well up, right at spec at 35 psi, in the tailwheel. It's a Citabria used for flight training, and since it gets a lot of landings we expect more-than-normal wear. However, we used to get much longer service before this current crop of tires showed up under everyone else's part numbers, even under Scott's. It's even more disappointing to see this in a US-made tire; I could understand it in some imported POJ. I'll keep looking, and take Patterson's advice and see if McCreary still has one. Dan (POJ = Piece of Junk. Similar to another, more vulgar term.) |
Dan Thomas wrote: I'll keep looking, and take Patterson's advice and see if McCreary still has one. Might not be a good idea. I checked around a bit, and, according to the Chief Aircraft web site, McCreary has changed names to "Specialty Tires of America". This sounds suspiciously like the "STA" you're buying now. They do stock that size, however. Aircraft Spruce still lists them as "McCreary" and stocks the 2.80/250 x 4. Goodyear, Condor, and Michelin have no listing for that size. Desser Tire stocks the size but doesn't say who makes it. Sorry to mislead you. George Patterson A man who carries a cat by the tail learns something that can be learned no other way. |
"G.R. Patterson III" wrote in message ...
Might not be a good idea. I checked around a bit, and, according to the Chief Aircraft web site, McCreary has changed names to "Specialty Tires of America". This sounds suspiciously like the "STA" you're buying now. That's them, all right. See what I mean? Everyone selling the same tire under their own part numbers. Going to have find out if the Kenda is actually Kenda or just STA again. And whether it's certified or just for homebuilts. I bet I could get just as good service out of a handcart tire as I do from these things we have now. Dan |
| Sources for retread tires?? | Jim Burns | Aviation Marketplace | 15 | November 24th 04 04:48 AM |
| Sources for retread tires?? | Jim Burns | Owning | 15 | November 24th 04 04:48 AM |
| WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Owning | 0 | March 20th 04 05:48 AM |
| Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 11:18 PM |
| Tailwheel tires | Dan Thomas | Owning | 10 | November 26th 03 03:53 PM |
