Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
Sources for retread tires??
Old November 5th 04, 03:24 PM
Jim Burns
Default Sources for retread tires??
We're looking for sources to buy a set of retread 700 x 6 8 ply tires from.
The guy we bought our Aztec from only had 6 ply tires on the main gear. 6
plys aren't rated high enough for our gross weight and the POH clearly calls
for 8 plys.
There seems to be a shortage of 8 ply cases in this particular size. Desser
and Wilkerson are both out. If anybody has any good sources for retreads,
I'd appreciate hearing from the group. OR if anybody has any name brand
used tires I'd be interested in buying them to have them retreaded. Aztecs
seem to be one of the only airplanes running this particular size/ply
combination.
Also, if anybody with a Bonanza, Maule, Rockwell Commander, Citabria, or
Apache needs some 700 x 6 6 plys, I've got 3 that have about 75% tread on
them.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (
http://www.grisoft.com).
Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004
Old November 5th 04, 03:25 PM
Louis L. Perley III
"Jim Burns" wrote in message
from.
calls
for 8 plys.
Desser
Aztecs
combination.
them.
Well Jim, I'll ask my mechanic, because they just ordered me a pair and
while they did have some difficulty, they did find them (didn't ask if they
are retreads or not). Both my mains were ruined because someone forgot a
shim in the brake system or something like that, so they were rubbing a
groove on the inside of the tire. I'll post/email you details after I speak
with my A & P this morning.
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old November 5th 04, 03:49 PM
Jim Burns
Thanks Louis, new tires are easy enough to find, but retreads seem to be
impossible.
I'm also interested in how your annual went!
Thanks again,
"Louis L. Perley III" wrote in message
from.
6
calls
for 8 plys.
Desser
retreads,
Aztecs
combination.
on
them.
they
speak
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old November 8th 04, 08:19 PM
William Boelte
Had the same problem with retreads for the Stearman- we have BT-13 wheels-
so we sent the tires off to Desser to be re-treaded. The airplane was down
for about two weeks. Since it was December and too cold to fly this wasn't a
problem. We paid less than half compared to new tires.
Bill
Thanks Louis, new tires are easyenough to find, but retreads seem to be
impossible.
Thanks again,
from.
6
calls
for 8 plys.
Desser
retreads,
brand
Aztecs
combination.
or
on
them.
they
speak
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old November 10th 04, 04:32 AM
Louis L. Perley III
impossible.
Thanks again,
Annual report is coming soon. I was told by my mechanic that retread tires
are not allowed in my Aztec according to the manual. They actually thought
that this was generally the case with all retractable gear aircraft. In
light of this, I am putting new tires on the mains. My aircraft also allows
for either 7.00 x 6 in 6 or 8 ply, which I thought was interesting. I'll be
putting on the 8 ply just to be safe (and the price isn't all that much
different either)
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old November 10th 04, 03:19 PM
Jim Burns
allows
be
different either)
I see you've got a 1965 Aztec, I don't know what the gross weight is, but
our '66 can't use the 6 plys because they are only rated at 1900 lbs each,
or 3800 lbs total, the 8 plys are rated at 2250 each, 4500 lbs total. As
far as all retractable gear aircraft not being able to use retreads, that's
a myth as most retractable gear airplanes actually do use retreads ie. the
airlines. There is an FAA AC that advises when installing retreads on
retractable gear planes to do a gear swing and make sure they fit in the
wells and to be carefull that the sidewalls do not overswell do to heat
build up on take off runs. There is no mention of retread tires in our POH
or in the manual for the Cessna R182 we flew.
We still haven't found any retreads and have ordered new tires which will
provide us with good cases for future retreading.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004
Old November 10th 04, 05:24 PM
Louis L. Perley III
that's
POH
It's in the service manual that I have for the airplane, but then again,
that service manual was written 30 some years ago, so maybe retreads weren't
as good back then as they are now so there were more problems with the tires
getting stuck in the wheel wells, etc. The Goodyear tires that I ordered are
rated at 2550 Lbs for the 8 ply. I noticed that the Goodyear speed rating is
higher than those made by others, then again, I doubt I'll ever land the
Aztec at 160 MPH which is what they're rated for. If I land that fast, the
tires would be the least of my worries
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old November 10th 04, 09:34 PM
Jim Burns
Thanks, I'm going to check the service manual for ours tonight to see if it
mentions retreads. I ended up with Michelin tires, and like yours, the 8
plys were rated to 2550. My earlier post stating 2250 was slightly
dyslexic.
Old November 11th 04, 06:22 AM
Louis L. Perley III
it
dyslexic.
Any idea how to determine what the Gross Weight on the aircraft is? I
know that Piper made 4400, 4800, and 5200 pound models, and they aren't in
any specific serial number ranges as far as I can tell. It would appear that
it depended on what was ordered at the time, and I've not seen any list of
what the various differences were so that I could make some sort of
determination that way. I've been searching, but have not yet been able to
determine anywhere what the gross weight is on my airframe.
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old November 11th 04, 11:04 AM
Bushy
But you might also want to check the skid rating for those wild croswind
landings!
Pete
Longest wearing 5.50 tires Doug Home Built 7 September 8th 04 05:19 AM
Time to change the air in your tires Rich S. Home Built 18 March 22nd 04 07:47 PM
500 x5 Wheels, Tires and Brakes HankL Home Built 0 February 26th 04 02:13 PM
WTB: Pair 500x5 Tires, Wheels, Brakes Spar Home Built 0 February 16th 04 11:13 PM
WTB: Pair 500x5 Tires, Wheels, Brakes Spar Aviation Marketplace 0 February 16th 04 11:13 PM
