Back to the thread on pilots setting QNH for local acro work.
I was in the trusty Pawnee this weekend and checked the altimeter, I can only select settings from 28.10 to 31.50, so.. following the others advice of setting QNH. I could not. I attempted to find this information in my personal library but could not readily find a source.. so the best source available was to "go to the instrument". The lowest I could set at 28.10 still gave me 750ft MSL on the dial, and obviously 2077 feet below the current terra firma, no way to set ZERO. So, fly with the correct QFE and do the mental math, precompute your altitudes required to give the terrain clearance you need. BT |
Sure you got that the right way around. QFE for ground level and QNH for
airfield elevation sg "BTIZ" wrote in message news:nlK2c.16184$id3.9654@fed1read01... Back to the thread on pilots setting QNH for local acro work. I was in the trusty Pawnee this weekend and checked the altimeter, I can only select settings from 28.10 to 31.50, so.. following the others advice of setting QNH. I could not. I attempted to find this information in my personal library but could not readily find a source.. so the best source available was to "go to the instrument". The lowest I could set at 28.10 still gave me 750ft MSL on the dial, and obviously 2077 feet below the current terra firma, no way to set ZERO. So, fly with the correct QFE and do the mental math, precompute your altitudes required to give the terrain clearance you need. BT |
ok.. I may be backwards... I don't normally define the use of Q settings..
The bottom line is, the discussion was brought up with the AF T-Bird doing acro and not computing the altitude needed at the top of a maneuver to safely pull out above ground level. Some argue to set the altimeter to zero elevation before takeoff. It just can't be done in many places out west. Many glider pilots along the coast use the same tactic, always knowing their height above the local airport they departed from, but not the local ridges. And if they are going cross country.. they are really going to be doing some mental math. Bottom Line? set the altimeter to local field elevation, not sea level BT "S Green" wrote in message ... Sure you got that the right way around. QFE for ground level and QNH for airfield elevation sg "BTIZ" wrote in message news:nlK2c.16184$id3.9654@fed1read01... Back to the thread on pilots setting QNH for local acro work. I was in the trusty Pawnee this weekend and checked the altimeter, I can only select settings from 28.10 to 31.50, so.. following the others advice of setting QNH. I could not. I attempted to find this information in my personal library but could not readily find a source.. so the best source available was to "go to the instrument". The lowest I could set at 28.10 still gave me 750ft MSL on the dial, and obviously 2077 feet below the current terra firma, no way to set ZERO. So, fly with the correct QFE and do the mental math, precompute your altitudes required to give the terrain clearance you need. BT |
BTIZ wrote:
The bottom line is, the discussion was brought up with the AF T-Bird doing acro and not computing the altitude needed at the top of a maneuver to safely pull out above ground level. Some argue to set the altimeter to zero elevation before takeoff. It just can't be done in many places out west. The problem is, you usually trainig acro at your home base. So you get used to the "floor" altitude needed in that place. Chances are that you get so accostomed to that altitude that you fall back to it even when you fly at another place. Y This is eliminated by settinig the altimeter to zero (i.e. QFE). And, btw, I've yet to see an altimeter that can't be set to QFE even at 5000 ft elevation, but what do I know. Stefan |
news:srO2c.16250$id3.4338@fed1read01... ok.. I may be backwards... I don't normally define the use of Q settings.. The bottom line is, the discussion was brought up with the AF T-Bird doing acro and not computing the altitude needed at the top of a maneuver to safely pull out above ground level. Some argue to set the altimeter to zero elevation before takeoff. It just can't be done in many places out west. IIRC, this discussion earlier revealed that the T-bird pilots have super-wizzo-thingummy altimeters that can indeed set QFE at high elevations. Granted, yours and mine can't. -- David Brooks |
"David Brooks" wrote in message ... "BTIZ" wrote in message news:srO2c.16250$id3.4338@fed1read01... ok.. I may be backwards... I don't normally define the use of Q settings.. The bottom line is, the discussion was brought up with the AF T-Bird doing acro and not computing the altitude needed at the top of a maneuver to safely pull out above ground level. Some argue to set the altimeter to zero elevation before takeoff. It just can't be done in many places out west. IIRC, this discussion earlier revealed that the T-bird pilots have super-wizzo-thingummy altimeters that can indeed set QFE at high elevations. Granted, yours and mine can't. -- David Brooks Hi David; The Thunderbirds use a standard altimeter setting for the point of demonstration and do not use a 0 altimeter set. Their maneuver profiles are corrected to MSL altitudes. Stricklin unfortunately on the way up the front side of his maneuver mentally "corrected" his reverse top target gate to Nellis' elevation instead of where he was. This put the Viper way low of where it should have been at the top side commit. He missed his visual cues as well. The airplane simply didn't have the g available vs the altitude under it to cut the corner. Dudley |
"Dudley Henriques" wrote in message link.net...
This put the Viper way low of where it should have been at the top side commit. He missed his visual cues as well. The airplane simply didn't have the g available vs the altitude under it to cut the corner. Hey Dudley, I've notice that in several posts over the last few months regarding the T-Birds, you refer to the planes as Vipers. Is there something different about these F-16s that they have a different name? Just wondering, John Galban=====N4BQ (PA28-180) |
"John Galban" wrote in message om... "Dudley Henriques" wrote in message link.net... This put the Viper way low of where it should have been at the top side commit. He missed his visual cues as well. The airplane simply didn't have the g available vs the altitude under it to cut the corner. Hey Dudley, I've notice that in several posts over the last few months regarding the T-Birds, you refer to the planes as Vipers. Is there something different about these F-16s that they have a different name? Just wondering, John Galban=====N4BQ (PA28-180) Viper is the nickname that stuck for the F16 in the fighter community. Thank God !!!!!!.....the girls weren't really all that impressed with "Lawn Dart" :-)) And somehow, the name "Fighting Falcon" just never caught on either. It's usually this way with our birds. The manufacturers' sales department has a meeting one day and picks some terrible idiotic name that they think is in character with the product......you know, the same way some people with dogs like to name them. I can't remember the last time I ran into a two hundred and ten pound Rotweiler named "Muffin" :-))))) It's usually something like "Ripper! " Then, when the airplane makes it out into the general fighter community, we get a hold of it and rename it to suit ourselves. That's the name that sticks. Hence the "Viper" tag! Dudley |
well... I've not seen an altimeter in US aircraft that can dial out 5000ft
of altitude.. that would mean the altimeter would have to be adjustable from 29.92 to 24.92, and mine only goes to 28.10 BT "Stefan" wrote in message ... BTIZ wrote: The bottom line is, the discussion was brought up with the AF T-Bird doing acro and not computing the altitude needed at the top of a maneuver to safely pull out above ground level. Some argue to set the altimeter to zero elevation before takeoff. It just can't be done in many places out west. The problem is, you usually trainig acro at your home base. So you get used to the "floor" altitude needed in that place. Chances are that you get so accostomed to that altitude that you fall back to it even when you fly at another place. Y This is eliminated by settinig the altimeter to zero (i.e. QFE). And, btw, I've yet to see an altimeter that can't be set to QFE even at 5000 ft elevation, but what do I know. Stefan |
In 20yrs AF, I've never called an F-16 anything other than a Viper..
and don't go calling my plane by it's "official name" either... you'll be targeted as a non-knowing person... it's a Bone... that's it.. BT "John Galban" wrote in message om... "Dudley Henriques" wrote in message link.net... This put the Viper way low of where it should have been at the top side commit. He missed his visual cues as well. The airplane simply didn't have the g available vs the altitude under it to cut the corner. Hey Dudley, I've notice that in several posts over the last few months regarding the T-Birds, you refer to the planes as Vipers. Is there something different about these F-16s that they have a different name? Just wondering, John Galban=====N4BQ (PA28-180) |
| Setting Up An Airport Trust Fund? | Jay Honeck | Piloting | 4 | February 24th 04 11:54 PM |
| low altimeter and FL180 | Michael 182 | Piloting | 26 | October 31st 03 05:29 AM |
| KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 03:01 AM |
| Prop bolt torque setting | Whunicut | Home Built | 2 | September 4th 03 01:12 PM |
| WOT in cruise? | Roger Long | Owning | 10 | July 28th 03 09:00 AM |
