This past Monday, a couple of my friends took off in a Bonanza with a
3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. It apparently made a lot of racket and bad vibrations right away; they were able to make a 180 and land downwind safely. They even had a hard time taxiing, but all are safe. Both McCauley and the FAA are really interested in this one -- to make sure that proper overhaul procedures were followed and to ascertain whether or not bogus parts were used. The insurance company is paying for the engine teardown/rebuild, as there is a possibility that the front bearing was damaged, due to asymmetric thrust. The fortunate thing is that it happened at 1000 feet, after takeoff from a 4800 ft runway, lightly loaded. Watch this space for possible AD and other stuff hitting the fan. |
3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. Wow -- I can't imagine how a blade could come detached. Those are some pretty beefy mechanisms. Glad they're all safe. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article haapc.2474$qA.269328@attbi_s51,
"Jay Honeck" wrote: This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. Wow -- I can't imagine how a blade could come detached. Those are some pretty beefy mechanisms. Glad they're all safe. I saw the prop in a friend's hangar -- you could rotate one blade freely about its longitudinal axis, while the other two were normal. |
What I find hard to believe, is that the insurance co. is willing to pay for
the tear-down. Don't they only normally pay for incidental damage - i.e., a tear-down after a prop-strike? "Orval Fairbairn" wrote in message news ![]() This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. It apparently made a lot of racket and bad vibrations right away; they were able to make a 180 and land downwind safely. They even had a hard time taxiing, but all are safe. Both McCauley and the FAA are really interested in this one -- to make sure that proper overhaul procedures were followed and to ascertain whether or not bogus parts were used. The insurance company is paying for the engine teardown/rebuild, as there is a possibility that the front bearing was damaged, due to asymmetric thrust. The fortunate thing is that it happened at 1000 feet, after takeoff from a 4800 ft runway, lightly loaded. Watch this space for possible AD and other stuff hitting the fan. |
On Sat, 15 May 2004 01:47:29 GMT, "Tom Jackson"
wrote: What I find hard to believe, is that the insurance co. is willing to pay for the tear-down. Don't they only normally pay for incidental damage - i.e., a tear-down after a prop-strike? In the cases that I have been exposed to, the insurance company will pay for a sudden-stoppage inspection "by-the-book", i.e. they will pay the mandatory replacement parts and labor to perform the manufacturer's required inspection. They will also typically pay to repair internal damage that has directly resulted from the incident. But any other issues discovered during the inspection (parts worn beyond limits from normal usage) are on the owner's dime. I would expect it would be the same in this case. TC |
If the insurance company finds that the prop was improperly overhauled, they
might sue the shop that did it to get their money back. "Tom Jackson" wrote in message news:REepc.94896$Ik.7314393@attbi_s53... What I find hard to believe, is that the insurance co. is willing to pay for the tear-down. Don't they only normally pay for incidental damage - i.e., a tear-down after a prop-strike? |
In article
, Orval Fairbairn wrote: This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. It apparently made a lot of racket and bad vibrations right away; they were able to make a 180 and land downwind safely. They even had a hard time taxiing, but all are safe. Both McCauley and the FAA are really interested in this one -- to make sure that proper overhaul procedures were followed and to ascertain whether or not bogus parts were used. The insurance company is paying for the engine teardown/rebuild, as there is a possibility that the front bearing was damaged, due to asymmetric thrust. The fortunate thing is that it happened at 1000 feet, after takeoff from a 4800 ft runway, lightly loaded. Watch this space for possible AD and other stuff hitting the fan. Followup: I talked to the owner of the plane today -- he was present when they opened up the prop hub. The pin at the base of the blade had sheared off. This is about 1/2" diameter and keeps the blade synchronized with the other blades. The pin went off for metallurgical analysis -- it was either too brittle or had improper heat treatment done, so there may be no joy in Mudville after this one is done. I wonder how many accidents have happened where the pin had broken and was dismissed as accident damage, rather than accident cause. |
Why do I smell an expensive AD coming?
-- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "Orval Fairbairn" wrote in message news
...In article , Orval Fairbairn wrote: This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. It apparently made a lot of racket and bad vibrations right away; they were able to make a 180 and land downwind safely. They even had a hard time taxiing, but all are safe. Both McCauley and the FAA are really interested in this one -- to make sure that proper overhaul procedures were followed and to ascertain whether or not bogus parts were used. The insurance company is paying for the engine teardown/rebuild, as there is a possibility that the front bearing was damaged, due to asymmetric thrust. The fortunate thing is that it happened at 1000 feet, after takeoff from a 4800 ft runway, lightly loaded. Watch this space for possible AD and other stuff hitting the fan. Followup: I talked to the owner of the plane today -- he was present when they opened up the prop hub. The pin at the base of the blade had sheared off. This is about 1/2" diameter and keeps the blade synchronized with the other blades. The pin went off for metallurgical analysis -- it was either too brittle or had improper heat treatment done, so there may be no joy in Mudville after this one is done. I wonder how many accidents have happened where the pin had broken and was dismissed as accident damage, rather than accident cause. |
Orval Fairbairn wrote in message .. .
This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. There is a composite material link between the pitch change mechanism and the blade acutator pin, which is on the circumference of the blade shank. It's about 2" long. This is a reason that McCauley specifically warns against pulling the airplane with the prop while on the ground. If you pull on the back edge of the blade, you can put enough torque on it to threaten the links. Ond does wonder how they were cared for because this is a very rare failure. It would be like a terrible mistrack on a helicopter rotor. Bill Hale BPPP Instructor |
| Thread Tools | |
| Display Modes | |
| McCauley Pucker Factor | Orval Fairbairn | Owning | 12 | May 18th 04 09:57 PM |
| gpa a factor after graduation? | sibersmith | Military Aviation | 28 | November 26th 03 06:06 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Shortened McCauley Propeller on an O-300 | Larry Smith | Home Built | 12 | September 10th 03 02:40 AM |
