McCauley Pucker Factor
Old May 14th 04, 05:01 AM
Orval Fairbairn
Default McCauley Pucker Factor
This past Monday, a couple of my friends took off in a Bonanza with a
3-blade McCauley prop installed. At about 1000 feet, on power
reduction, one of the blades came unhooked from its pitch change
mechanism and went into "free pitch" mode.
It apparently made a lot of racket and bad vibrations right away; they
were able to make a 180 and land downwind safely. They even had a hard
time taxiing, but all are safe.
Both McCauley and the FAA are really interested in this one -- to make
sure that proper overhaul procedures were followed and to ascertain
whether or not bogus parts were used.
The insurance company is paying for the engine teardown/rebuild, as
there is a possibility that the front bearing was damaged, due to
asymmetric thrust.
The fortunate thing is that it happened at 1000 feet, after takeoff from
a 4800 ft runway, lightly loaded.
Watch this space for possible AD and other stuff hitting the fan.
Old May 14th 04, 05:47 AM
zatatime
On Fri, 14 May 2004 03:01:09 GMT, Orval Fairbairn
asymmetric thrust.
Was it a metal prop, or one of those new composite ones?
z
Old May 14th 04, 10:41 PM
Jay Honeck
Wow -- I can't imagine how a blade could come detached. Those are some
pretty beefy mechanisms.
Glad they're all safe.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 14th 04, 11:22 PM
Orval Fairbairn
In article haapc.2474$qA.269328@attbi_s51,
I saw the prop in a friend's hangar -- you could rotate one blade freely
about its longitudinal axis, while the other two were normal.
Old May 14th 04, 11:29 PM
Orval Fairbairn
asymmetric thrust.
z
Metal -- you could rotate one blade freelt about its longitudinal axis.
I was told that there is a Mickey Mouse setup within the hub that locks
the blades together. I also understand that teardown is Monday, under
FAA supervision.
Old May 15th 04, 03:47 AM
Tom Jackson
What I find hard to believe, is that the insurance co. is willing to pay for
the tear-down.
Don't they only normally pay for incidental damage - i.e., a tear-down after
a prop-strike?
"Orval Fairbairn" wrote in message
news
asymmetric thrust.
Old May 15th 04, 04:22 AM
On Sat, 15 May 2004 01:47:29 GMT, "Tom Jackson"
the tear-down.
a prop-strike?
In the cases that I have been exposed to, the insurance company will
pay for a sudden-stoppage inspection "by-the-book", i.e. they will pay
the mandatory replacement parts and labor to perform the
manufacturer's required inspection.
They will also typically pay to repair internal damage that has
directly resulted from the incident. But any other issues discovered
during the inspection (parts worn beyond limits from normal usage) are
on the owner's dime.
I would expect it would be the same in this case.
TC
Old May 15th 04, 06:12 AM
zatatime
On Fri, 14 May 2004 21:29:38 GMT, Orval Fairbairn
asymmetric thrust.
z
FAA supervision.
Thanks. I know most props aren't overbuilt. I'm very curious to see
what takes place over time with the new prop blades that are being
made.
Hope they find the root cause, and that it doesn't warrant an AD.
z
Old May 16th 04, 04:40 AM
Orval Fairbairn
asymmetric thrust.
z
FAA supervision.
made.
z
Current thinking is that the prop shop that did the O/H did not follow
McCauley procedures -- we will find out more on Monday, when they tear
down the prop. BTW, they could not even taxi the plane -- it had too
much vibration and not enough net thrust.
Old May 16th 04, 09:35 PM
MichaelR
If the insurance company finds that the prop was improperly overhauled, they
might sue the shop that did it to get their money back.
"Tom Jackson" wrote in message
news:REepc.94896$Ik.7314393@attbi_s53...
for
the tear-down.
after
a prop-strike?
McCauley prop blages Cy Galley Aviation Marketplace 0 January 25th 04 10:24 PM
gpa a factor after graduation? sibersmith Military Aviation 28 November 26th 03 06:06 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Shortened McCauley Propeller on an O-300 Larry Smith Home Built 12 September 10th 03 02:40 AM
