#31
"John Gaquin" wrote in message ...
"Jon Woellhaf" wrote in message news:Ayqwc.7120 John, did you ever get to do one for real? Nope. From intro flight to 747, I never had a catastrophic failure of any kind. I'd love to think skill and professionalism had something to do with it, but nobody would buy that song -- particularly the guy in the mirror. Just pure good luck. :-) Had a few system failures, and a few precautionary landings, but nothing officially an emergency. How dull. Well obviously you didn't have a catastrophic failure since your posting here. But no memorable problems with this machine is unbelievable. I flew it for four years and had all kinds of mechanical failures. We had an engine slam into reverse at FL180 and the cowlings and reverser sleave fell into Brooklyn one night. It sounds to me like you were not on the airplane very long. Were you just a flight engineer? Or were you a pilot? Just give a straight answer John. Your postings are very suspicious buddy. pacplyer |
#32
"pacplyer" wrote in message
om... [...] Your postings are very suspicious buddy. Says the guy who posts anonymously. How ironic. |
#33
![]() "Bob Moore" wrote in message ... "Darrell" wrote And in a true aileron roll you pull one negative G to hold the point while inverted. Darrell, how come you Air Force guys define rolls differently than everyone else? http://acro.harvard.edu/ACRO/acro_figures.html#rolls Aileron rolls are flown with the rudder and elevator in the neutral position during the roll. The aileron is fully deflected in the direction of the roll. This is the easiest of the rolls to fly. The aileron roll is started by pulling the nose up to 20 - 30 degrees above the horizon. The elevator is then neutralized and the aileron fully deflected in the direction of the roll. The controls are maintained in that position till the roll is completed. After the roll is completed the nose is usually 20 - 30 degrees below the horizon. Slow rolls have to be flown normally on a straight line. The roll rate has to be constant and the longitudinal axis of the plane has to go straight. This requires constantly changing rudder and elevator control inputs throughout the roll. Hesitation or point rolls include stops at certain roll angles. ------------------------------------------------------------ http://www.sunrise-aviation.com/Ailroll.html As the name implies, the aileron roll is done with "normal" inputs of aileron and rudder (in contrast to snap rolls). At the point this maneuver is introduced to students in the Sunrise Basic syllabus, no attempt is made to maintain altitude during the roll. The result is a steady transition from climb to descent until the aircraft regains upright flight. This simplified approach to rolling is ideal for beginning aerobatic pilots. A further development of basic rolling technique introduces forward elevator (and negative G) to eliminate altitude loss while inverted. The result is a Slow Roll, introduced in the Sunrise Intermediate syllabus. Once mastered, slow rolls completely replace aileron rolls in the repertoires of most pilots. ---------------------------------------------------------------- Bob Moore Although pulling 1 negative g is definitely NOT done in an aileron roll, you will note as well the discrepancy between the two examples you have given to explain aileron rolls. The first calls for a complete neutral rudder throughout the roll and the second calls for rudder and aileron together. The first example is totally incorrect both for aileron rolls AND in the explanation for a slow roll. In a true aileron roll, the nose is pulled and set as explained, but at roll initiation, just enough inside rudder is used with inside aileron to initiate the roll without adverse yaw, THEN the rudder is eliminated as it would pull the nose down as the airplane goes toward knife edge and beyond. Although it's true that you can do an aileron roll without this initial use of inside rudder, it's considered a flaw, and pure aileron will pull the nose to the outside of the roll and alter the normal arc that should take the nose from it's position above the horizon at roll onset, to where it must be below the horizon on recovery. Initiating a pure aileron input without correction for yaw is classified as an error in any competent aerobatic school. That being said, holding in the inside rudder too long after initiation is ALSO classified as an error :-) It should also be noted that it's perfectly acceptable to execute an aileron roll varying the amounts of forward stick and top rudder to allow a more EXACT roll while not crossing the line to a slow roll. Basically, all you're doing in a true aileron roll is allowing the nose to arc naturally from it's position over the horizon back down to a position below the horizon without attempting to PIN IT! Now to slow rolls. A slow roll is NOT executed on a straight line as the description states clearly. No airplane, regardless of it's wing design, (symmetrical or asymmetrical) flies inverted at the same nose attitude as level flight erect. The nose MUST be raised ABOVE the horizon in a slow roll so that the airplane will be level as it passes through it's inverted level flight attitude. You will find that the correct figure for describing a slow roll is a letter D to the right or a reverse letter D if to the left. The vertical line up must be flown before the roll is initiated. The roll itself is done at the top apex of the D. The curve of the D is absolutely mandatory if the airplane is to return to it's beginning level flight attitude erect at the end of the roll. Exactly how high above the horizon the apex of that D is will be a function of individual wing design. For example, you do a slow roll a lot closer to the inverted horizon in an Extra than you do in a P51 Mustang! In other words, a slow roll can't be done on a straight line without losing altitude. You MUST place the airplane at a point where it passes through it's level flight inverted nose attitude and then bring it back down again in the recovery to it's normal level flight attitude. So I would grade the first explanation as incorrect on two counts. The second one is more in line with reality. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
#34
![]() "pacplyer" wrote in message .... It sounds to me like you were not on the airplane very long. Were you just a flight engineer? Or were you a pilot? Just give a straight answer John. Your postings are very suspicious buddy. A touch over three years, pac, about three and a half. As a pilot. And what do you mean by "...just a flight engineer..."? Bet you make a lot of friends among the crews you fly with carrying an attitude like that. Nothing suspicious about my posts. Just a guy who went to work and flew the plane. From 72 to 96 I never had any kind of catastrophic failure in any airplane. Period. OTOH, you seem to have endless tales of horrible events, dangerous circumstances, horrid weather, self-destructing aircraft, incompetent crew members, etc, etc. Many of your posts involve demonstrating how skillful you are and how bumbling someone else is. Denigrating your F/O seems a recurring subject. In point of fact, your posts sound a might suspicious to me. Nothing in your posting sounds like any mature Captain I've ever encountered over the past thirty years. Frankly, you sound to me like someone relatively new to the big leagues who wants everyone to believe you're an old pro. I may be wrong, and hope I am, and I really don't want to get into a debate about this, but that's the way you come across to me. |
#35
"John Gaquin" wrote
I may be wrong, and hope I am, and I really don't want to get into a debate about this, but that's the way you come across to me. I'm with you John. Bob Moore |
#36
![]() "Bob Moore" wrote in message . 8... "John Gaquin" wrote I may be wrong, and hope I am, and I really don't want to get into a debate about this, but that's the way you come across to me. I'm with you John. Bob Moore It is because the poster has never flown the airlines. A while back, another guy said something to the effect, that he knows enough, he could make people believe (fool them), he was really an airline pilot. He is so busted, in my book. Remember saying that, Mr. Fake? I do. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.699 / Virus Database: 456 - Release Date: 6/4/2004 |
#37
Bob Moore wrote in message .8...
"John Gaquin" wrote I may be wrong, and hope I am, and I really don't want to get into a debate about this, but that's the way you come across to me. I'm with you John. A nice little toy to look at turn rates here http://www.csgnetwork.com/aircraftturninfocalc.html should keep the pundits smiling |
#38
"pacplyer" wrote in message .... It sounds to me like you were not on the airplane very long. Were you just a flight engineer? Or were you a pilot? Just give a straight answer John. Your postings are very suspicious buddy. A touch over three years, pac, about three and a half. As a pilot. And what do you mean by "...just a flight engineer..."? Bet you make a lot of friends among the crews you fly with carrying an attitude like that. Were you Captain, First Officer, or Flight Engineer hired on the basis of having a Comm pilot lic? My guess it that you were in the non-flying seat. The reason I suspect this is you have this constant need to sign your posts with B747 at the bottom. I've never seen a 747 driver feel the need to do this all the time. I have seen S/O's go to the bar and pretend that they physically fly the airplane since people don't understand the difference. Nothing suspicious about my posts. Just a guy who went to work and flew the plane. From 72 to 96 I never had any kind of catastrophic failure in any airplane. Period. OTOH, you seem to have endless tales of horrible events, dangerous circumstances, horrid weather, self-destructing aircraft, incompetent crew members, etc, etc. I do believe you were a crewmember on the airplane John. You must have worked for a better outfit than I did if nothing ever went wrong. But things do fall off airplanes and sometimes they are lost; I guess you never read AW&ST. Since I got hired we had six hull losses, and killed four people. Many others were injured. International/MAC/supplemental freight flying is statisically much more dangerous than any other type. Many of your posts involve demonstrating how skillful you are and how bumbling someone else is. Denigrating your F/O seems a recurring subject. In point of fact, your posts sound a might suspicious to me. Nothing in your posting sounds like any mature Captain I've ever encountered over the past thirty years. Frankly, you sound to me like someone relatively new to the big leagues who wants everyone to believe you're an old pro. I may be wrong, and hope I am, and I really don't want to get into a debate about this, but that's the way you come across to me. Fair enough John. It's clear you don't like my writing style. I just use these forums as practice for writing. I use a certain amount of literary creative licence in my stories, otherwise they would be dull. I include memorable things that happened to me in my career which started in 82'. Best Regards, pacplyer |
#39
Good point, Bob. I said to "hold the point" which is really a roll on a
point which is not necessary and seldom done in plain aileron rolls. To roll on a point you do need to use top rudder at each 90 degree point and 1 negative G while inverted but... that's not what was asked. Another "senior moment". Sorry. -- B-58 Hustler History: http://members.cox.net/dschmidt1/ - "Bob Moore" wrote in message ... "Darrell" wrote And in a true aileron roll you pull one negative G to hold the point while inverted. Darrell, how come you Air Force guys define rolls differently than everyone else? http://acro.harvard.edu/ACRO/acro_figures.html#rolls Aileron rolls are flown with the rudder and elevator in the neutral position during the roll. The aileron is fully deflected in the direction of the roll. This is the easiest of the rolls to fly. The aileron roll is started by pulling the nose up to 20 - 30 degrees above the horizon. The elevator is then neutralized and the aileron fully deflected in the direction of the roll. The controls are maintained in that position till the roll is completed. After the roll is completed the nose is usually 20 - 30 degrees below the horizon. Slow rolls have to be flown normally on a straight line. The roll rate has to be constant and the longitudinal axis of the plane has to go straight. This requires constantly changing rudder and elevator control inputs throughout the roll. Hesitation or point rolls include stops at certain roll angles. ------------------------------------------------------------ http://www.sunrise-aviation.com/Ailroll.html As the name implies, the aileron roll is done with "normal" inputs of aileron and rudder (in contrast to snap rolls). At the point this maneuver is introduced to students in the Sunrise Basic syllabus, no attempt is made to maintain altitude during the roll. The result is a steady transition from climb to descent until the aircraft regains upright flight. This simplified approach to rolling is ideal for beginning aerobatic pilots. A further development of basic rolling technique introduces forward elevator (and negative G) to eliminate altitude loss while inverted. The result is a Slow Roll, introduced in the Sunrise Intermediate syllabus. Once mastered, slow rolls completely replace aileron rolls in the repertoires of most pilots. ---------------------------------------------------------------- Bob Moore |
#40
EDR wrote in message ...
In article , Paul Tomblin wrote: As for what they're capable of, remember Tex Johnson(sp?) barrel rolled the 707 prototype (the "Dash-80"). If you don't care if the plane is usable again after the maneuver, I'm sure you could do a lot more abrupt maneuvers than that. Not necessarily... +1-G is +1-G. The airplane doesn't know what attitude it's in as long as the proper g-loading is maintained throughout the maneuver. The only variable is the pilot's level of skill. But that's just the cabin. The wing tips receive much higher G forces in a roll. It depends how fast the roll is. -Robert |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Boeing 757 turn rate? | Garyurbach | Aerobatics | 6 | June 14th 04 04:43 PM |
Boeing 757 turn rate? | Garyurbach | Military Aviation | 1 | June 7th 04 05:48 PM |
763 Cruising Speed. | [email protected] | General Aviation | 24 | February 9th 04 09:30 PM |
