#51
"Greg Copeland" wrote in message
news ![]() On Tue, 20 Apr 2004 16:35:03 -0500, FUji wrote: Huh? Maximum output of most handheld cell phones is 0.6 watts with the old in-car and bag phones going up to 3 watts. The radius of interference from 0.6 watt phones transmitting from inside an aluminum can would be rather small. I'm not sure how far you could even transmit on 0.6 of watt. From London, on the 144MHz band, under the right conditions, I once talked to a guy in Germany through a repeater in Belgium on my 1W handheld. I then switched down to 150mW and could still talk to him clearly. This was from the 12th floor of a building. It's amazing how far 0.6W will go from a plane...if not for a good quality phone call, at least to cause some interference. People forget that cell switching is not magical. And it's certainly is not zero cost. I must admit I do not fully understand everything that goes on, but I am sure it's not as simple as you imply. Everytime a call switches cells, it creates lots of work for the cell network to make sure only a single tower handles that call. So, while it may take a fraction of a second from a given phone and a given tower, there is lots going on behind the scenes. Worse, instead of it going on with one, two or maybe three towers, now it's causing a flurry of on twenty or more (highest estimates I've read) towers. Let's also not forget that each tower can only process and multiplex n-number of signals at a given time. DSPs, just like your CPU, does have finite capacity. During cell switching, as I understand it, this finite resource is being used on each tower in contact with the phone. So, to say, "it causes all sorts of problems on the cell network", does seem like a spot on statement to me. Not only does it cause these problems with signalling in the network, it also causes interference in other ways. With analogue, it will render the frequency used unusable for the same frequency, repeated through the 7 or 21 cell re-use pattern over the transmitted area. With TDMA (D-AMPS or GSM), you'd wipe out that time slot on that frequency. Greater than about 20 miles away, the time delay on the transmitted signal would mean you'd also wipe out the adjacent time slot. You could be decreasing capacity significantly over a wide area. With CDMA I'm not sure about the interference potential, though it's bound to increase the noise. I took our test gear up in the plane over Newbury one day to see what I could receive. I got well over 20 cells and it was adding, deleting and replacing radio links like mad. Absolute chaos on the network. Note that this network had not yet been launched to the public (Vodafone UMTS - 3G). It's not so much the "tower"s processing capacity, but that of the BSC/MSC (or RNC on CDMA) controlling the base stations, and also the capacity of the signalling links. All this is finite. Someone said something (I've heard it said a few times) that the phone "locks on" to the nearest cell. In laymans terms, yes. In actual terms, you're transmitting, just like any other transmitter. The cell used for communication will be the one receiving you the strongest. Note that the neighbouring cells will be on different frequencies, so your phone will tune to one of the frequencies used by the strongest cell. There is then a re-use pattern, and the same frequencies will be re-used somewhere a certain distance away, depending on the cell size. The cell size depends on whether you're in an urban or rural environment...in an urban environment they use a smaller cell size - lower power, more obstructions, so the next cell using the same frequencies will be closer. They're banking on the other cells not being able to pick you up due to your low power and the buildings, hills,. trees and so on blocking the signal. (note that the frequency thing doesn't apply to CDMA) If conditions are right (wrong?) you may be picked up by other cells on the same frequency...this is interference. If this is above a certain level, this same frequency on the other cell will be rendered unusable. (or that time slot on that frequency...and maybe the adjacent one, as mentioned above). If you use a phone in the air over an urban environment, you will cause a large amount of interference. If you're down low over a rural area, you may not cause any at all. Paul |
#52
![]() "Ash Wyllie" wrote in message ... Cirrus 1234A: I need to phone home. "SHUT UP AND FLY!!!" : My instrument instructor is also a real estate agent. Her cell phone rang during runup yesterday and she confirmed a closed sale, but not without difficulty. -c |
#53
![]() gatt wrote: My instrument instructor is also a real estate agent. Her cell phone rang during runup yesterday and she confirmed a closed sale, but not without difficulty. My wife forwarded me an Andy Cap cartoon yesterday. Some dude is chatting on the phone at the pub trying to set up a business deal. He asks Andy if he has the time. Andy says "Yes, it's exactly two minutes before that phone goes through the window." Love it. George Patterson None of us is as dumb as all of us. |
FS: 1989 "War Planes" (Of The World) Cards with Box | J.R. Sinclair | Aviation Marketplace | 0 | December 30th 04 11:16 AM |
FS: 1989 "War Planes" (Of The World) Cards with Box | J.R. Sinclair | Aviation Marketplace | 0 | April 15th 04 06:17 AM |
Cell phones with GPS | Roger Halstead | Piloting | 0 | December 24th 03 03:04 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
FS: 1989 "War Planes" (Of The World) Cards with Box | Jim Sinclair | Aviation Marketplace | 0 | August 23rd 03 04:43 AM |
