#41
![]() "Casey Wilson" N2310D @ gmail.com wrote in message news:XLMke.66$3u3.38@trnddc07... FWIW, I don't give any destination or route in the request when VFR and have very seldom been asked for it. One time was midway cross-country when I had been handed over to one sector, then made a turn over an intersection and headed for another. Having some idea of where you're going makes it easier for the controller to pass on flight info to the next controller. |
#42
![]() "Matt Whiting" wrote in message ... In addition to the above, using Flight Following means that you are in direct contact with ATC should you develop some sort of in-flight emergency. You can therefore communicate that difficulty immediately without having to search for the available and appropriate controlling agency. The appropriate response in an emergency is to dial up 121.5 and not worry about who answers. :-) Not if you're already receiving flight following. If you're on flight following you're already talking to a controller that knows where you are. There's no point in changing to 121.5. |
#43
![]() "Matt Whiting" wrote in message ... Which was exactly the context in which I gave the response about 121.5. I can't help that Paul gave an answer that was completely out of context. No it wasn't. The context in which you gave the response about 121.5 was one in which the pilot was receiving flight following. |
#44
![]() "Matt Whiting" wrote in message ... Yes, here is the text to which I responded: "In addition to the above, using Flight Following means that you are in direct contact with ATC should you develop some sort of in-flight emergency. You can therefore communicate that difficulty immediately without having to search for the available and appropriate controlling agency." The suggestion is clearly made that if you AREN'T using flight following then your alternative is to "search for the available and appropriate conrolling agency" to call. My comment is that if you AREN'T using flight following, you have a much better alternative to trying to look up a frequency for the ATC in your area - and that is to dial up 121.5. This really isn't that hard to follow. And yet you were unable to follow it. |
#45
"Paul Tomblin" wrote in message
Jot down freqs as you're handed off. It annoys them if they expect you to call and you've forgotten, or mixed up, the freq. It happens. Flip flop radios are a god-send when you go to a new frequency and nobody answers. You can just flip back to the old frequency. Of course, since nothing is perfect and everybody needs a backup, you should still write down frequencies. hehe Wouldn't have mentioned it if it wasn't a common occurrence. I've lost a frequency a couple times when I've left it to contact FSS and had to try a couple different frequencies to find them. Even copying the hand-off frequencies down can result in a kneeboard full of numbers, and temporary confusion, in a flight through busy airspace. Don't forget to cross them off. moo |
#46
Paul Tomblin wrote:
In a previous article, Matt Whiting said: Paul Tomblin wrote: In a previous article, Matt Whiting said: Which was exactly the context in which I gave the response about 121.5. I can't help that Paul gave an answer that was completely out of context. "Completely out of context"? What sort of drugs are you on? You contradicted somebody who was saying that an advantage of flight following is that you're already talking to somebody in the event of emergency to say that the correct thing to do in an emergency is to "dial in 121.5". conrolling agency" to call. My comment is that if you AREN'T using flight following, you have a much better alternative to trying to look up a frequency for the ATC in your area - and that is to dial up 121.5. You didn't say "if you aren't using flight following", you said "the correct response in an emergency". Which, unless you've redefined the english language when I wans't looking, means "an emergency", not "an emergency when you aren't getting flight following". Say what you mean, or don't complain if people correct you. Sorry, it was pretty obvious ... at least to me and most everyone else. I'll try to be more explicit next time so that you can understand as well. Matt |
#47
Steven P. McNicoll wrote:
"Matt Whiting" wrote in message ... In addition to the above, using Flight Following means that you are in direct contact with ATC should you develop some sort of in-flight emergency. You can therefore communicate that difficulty immediately without having to search for the available and appropriate controlling agency. The appropriate response in an emergency is to dial up 121.5 and not worry about who answers. :-) Not if you're already receiving flight following. If you're on flight following you're already talking to a controller that knows where you are. There's no point in changing to 121.5. Agreed. See my reply to Paul. My point is that the alternative to FF isn't trying to look up the "appropriate" frequency during an emergency, it is to dial in 121.5. Obviously, if you are already talking to ATC you don't change frequencies. This seemed so obvious as to not need stating, but I guess at least a couple of people didn't catch that. Matt |
#48
"Matt Whiting" wrote in message ... Which was exactly the context in which I gave the response about 121.5. I can't help that Paul gave an answer that was completely out of context. No it wasn't. The context in which you gave the response about 121.5 was one in which the pilot was receiving flight following. No, read it again. Matt |
#49
Steven P. McNicoll wrote: Not if you're already receiving flight following. If you're on flight following you're already talking to a controller that knows where you are. There's no point in changing to 121.5. Agreed. See my reply to Paul. My point is that the alternative to FF isn't trying to look up the "appropriate" frequency during an emergency, it is to dial in 121.5. Obviously, if you are already talking to ATC you don't change frequencies. This seemed so obvious as to not need stating, but I guess at least a couple of people didn't catch that. What about very busy airspace? Would they ask you to change frequency or everyone else? moo |
#50
![]() "Matt Whiting" wrote in message ... Steven P. McNicoll wrote: "Matt Whiting" wrote in message ... Which was exactly the context in which I gave the response about 121.5. I can't help that Paul gave an answer that was completely out of context. No it wasn't. The context in which you gave the response about 121.5 was one in which the pilot was receiving flight following. Matt: Now we all get your point, but your scenario was not obvious at all (I'm just saying this as you are stating that it was "pretty obvious" to everyone else what your scenario was, but it really wasn't). The point is that flight following is better cause you are already talking to somebody and knows where you are. No radios to change. Your message was easily understood as "you always need to change to 121.5 in an emergency". Use better english next time ![]() |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
