Can someone explain to a new pilot (who's never used it!) what flight
following is all about and how to actually get it? Thanks! |
In a previous article, " said:
Can someone explain to a new pilot (who's never used it!) what flight following is all about and how to actually get it? Thanks! It means that sort-of like an IFR flight, ATC will provide traffic advisories on a work-load permitting basis (which means that they may point out some traffic but then not point out the one that's actually heading straight for you because they got busy with some IFR traffic), and they may hand you off to another facility as you leave their airspace, or they may just say "frequency change approved, squawk VFR", again depending on workload (and apparently, how much they hate the guys in the next facility). For a VFR-only pilot, it means you have another pair of eyes looking out for you (or half a pair of eyes, sometimes), and it gives you an experience with the system that will help when you get your instrument rating. It does not mean you can fly head down in the cockpit or relax your scan for conflicting traffic. -- Paul Tomblin http://xcski.com/blogs/pt/ "using Outlook to read e-mail is like licking public toilets; using Outlook with a virus checker is like taking antibiotics and then licking public toilets (it might work, but it's hardly optimal" -- David Megginson |
" wrote in message
oups.com... Can someone explain to a new pilot (who's never used it!) what flight following is all about and how to actually get it? Thanks! Flight following is a colloquial term for VFR radar traffic advisories (see the AIM's Pilot/Controller Glossary). The concept is discussed in the AIM section 4.1 (Services Available to Pilots), and the phraseology for requesting it is discussed in section 4.2 (Radio Communications Phraseology and Techniques). You can find the AIM online at http://www.faa.gov/atpubs/AIM/index.htm. --Gary |
Paul Tomblin wrote:
In a previous article, " said: Can someone explain to a new pilot (who's never used it!) what flight following is all about and how to actually get it? Thanks! It means that sort-of like an IFR flight, ATC will provide traffic advisories on a work-load permitting basis (which means that they may point out some traffic but then not point out the one that's actually heading straight for you because they got busy with some IFR traffic), and they may hand you off to another facility as you leave their airspace, or they may just say "frequency change approved, squawk VFR", again depending on workload (and apparently, how much they hate the guys in the next facility). For a VFR-only pilot, it means you have another pair of eyes looking out for you (or half a pair of eyes, sometimes), and it gives you an experience with the system that will help when you get your instrument rating. It does not mean you can fly head down in the cockpit or relax your scan for conflicting traffic. In addition to the above, using Flight Following means that you are in direct contact with ATC should you develop some sort of in-flight emergency. You can therefore communicate that difficulty immediately without having to search for the available and appropriate controlling agency. A follow-up question, however: How do request flight following when you are not actually doing a cross-country? Let's say that my flight intentions are to fly 50 NM away from my home base in order do sight-seeing and photo shooting, turn around (not land), and go back home. Do I simply tell ATC of those intentions of doing nothing more than a round robin flight? Whenever I have ask for FF, the controller always asks for a destination. What are you supposed to say? Arnold Sten |
If you ever departed a class B or class C airport VFR, you had flight
following. I start like this: Me: Bradley Approach - N6480R request. Bradley: N6480R - go ahead. Me: Bradley Approacy - Cherokee 6480R is 5 miles south of Spencer, VFR to Atlantic City at two thousand, climbing to four thousand five hundred. Bradley: N6480R - squawk 5236 and ident. Me: 5236 wait - wait - wait Bradley: N6480R radar contact 6 miles south of Spencer, altimeter 2996. Me: 2996 I now have flight following. Now the tough part is listening for when they call you. You have to be paying attention for your call-sign. At some point they will instruct you to contact someone else on another frequency, or will terminate flight following. I've never been denied flight following, but have been terminated when moving from one center to another. From what I've been told, the controller would rather have me on frequency than not. " wrote in message oups.com... Can someone explain to a new pilot (who's never used it!) what flight following is all about and how to actually get it? Thanks! |
"Greg Farris" wrote in message
... Besides traffic advisories, it also means you are in two-way communication with a facility at all times. Some pilots find this a hassle. It's up to you. Good point. In some ways, that can actually *reduce* the communication hassle. If you're headed for Class C or D airspace while getting flight following, you're already in two-way communication with ATC, so you already have permission to enter the airspace (unless ATC instructs you not to, of course). And if you're headed for Class B, although you still need a clearance there, ATC will often just volunteer the clearance when you're getting flight following. --Gary |
"Arnold Sten" wrote in message ... In addition to the above, using Flight Following means that you are in direct contact with ATC should you develop some sort of in-flight emergency. You can therefore communicate that difficulty immediately without having to search for the available and appropriate controlling agency. A follow-up question, however: How do request flight following when you are not actually doing a cross-country? Let's say that my flight intentions are to fly 50 NM away from my home base in order do sight-seeing and photo shooting, turn around (not land), and go back home. Do I simply tell ATC of those intentions of doing nothing more than a round robin flight? Whenever I have ask for FF, the controller always asks for a destination. What are you supposed to say? Just tell them you'll be taking photos or doing airwork or whatever. |
In article kYEke.5$SV3.2@trnddc03, says...
Me: 5236 wait - wait - wait LOL - that's about it! G Faris |
| Thread Tools | |
| Display Modes | |
| RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 07:31 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 08:13 PM |
| Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 03:54 AM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
