Bill Daniels wrote:
"soarski" wrote in message oups.com... On the other Hand ........I live and take off at 8000 ft. now also going on OX at 14000 ft, used to fly without, at higher altitudes. The Rules, 12500 and 14000 ft are a good measure and most likely have some margin built in. As near as I can determine, these altitudes were determined during WWII using very fit 18 year olds. Out of shape geezers should lower them considerably. Being in the later category, I set the EDS to start O2 flow at ground level especially with difficult to handle expensive gliders. With the EDS consumption isn't a problem. I recently got an oximeter, and was surprised to see my saturation drop to 90 and lower above 11,000'. I now set my EDS for ground level actuation, and put it on at 10,000'. Even with that, it will stay in the 93-94% range, unless I breathe a little more deeply than I tend to. That will push it up to 97-98%. Oxygen is cheap, and very little is used in the 10K to 12K range anyway. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
At 03:12 14 June 2005, Kilo Charlie wrote:
The only way to assure yourself of adequate oxygen delivery to your body is to use a pulse oximeter as OC has pointed out. I highly recommend a pulse oximeter. I wore one in the wave last week to check out my EDS system. I had the EDS set to the standard O2 delivery starting at 10k. At 18k I put on the oximeter - it read 79% under normal nasal breathing. With accelerated breathing I could get it up to 89%. This week I tried the F15 setting (extra O2 volume). I went from 84% to 92% in about a minute at 16k. Under none of these flights did I notice anything unusual in my perceptions or performance - but then again you're not supposed to. 9B |
$200 pulse oximeter for monitoring your oxygen saturation | Eric Greenwell | Soaring | 32 | November 12th 04 03:03 PM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Reprise - Oxygen concerns | Neptune | Soaring | 20 | May 27th 04 03:27 PM |
Need oxygen information | Neptune | Soaring | 3 | May 10th 04 06:06 AM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
