Reprise - Oxygen concerns
Old May 19th 04, 04:31 AM
Neptune
Default Reprise - Oxygen concerns
BlankThanks to all who have replied to my previous messages. I admit I may not have
been clear in why I am asking for feedback/information on flight testing of oxygen
delivery systems. Apologies. Let me explain and ask for HELPFUL feedback.
My concern is with the lack of scientifically-valid information available on
the performance of light aircraft/glider oxygen systems. As an anesthesia doc (and former USAF
fighter jock) I feel have some background in this area. In addition I have done significant medical literature research, been to CAMI to speak with the honchos there, had contact with the Brits, in-person chats with several New Zealanders at Omarama, etc.
When I started to fly gliders out of Boulder several years ago I was
surprised at the masks that pilots were taking up into the wave. Having had
a cardiac bypass operation myself perhaps I was unusually concerned. I began
to do National Library of Medicine research and found no published studies
that dealt with the use of nasal cannulae or masks performance at altitude.
I then got access (with permission from the CEO as long as I didn't mention the
name) to company data that had to do with a flight to 18,000 during which 6
subjects using an A4 had pulse-ox readings taken at FAA-mandated flow rates.
In the process the Oxymizer was compared with the "regular" cannula. At each
altitude from 13,000 to 18,000 at least one subject was hypoxic with one subject,
at 18,000, saturating at 78% on an Oxymizer at the FAA rate of 1.46. All six were
supposedly all fit and healthy people. One had a bypass operation, but he was never
one of the hypoxic ones. No physician had been involved.
I then discovered that FAA mandates oxygen flow rates only - not oxygen
saturations. The mandates, so I discovered, are at least 40 years out of
date and relate to tracheal oxygen measurements - two levels of medical
monitoring sophistication out of date (arterial blood gases, pulse
oximetry). Of course the modern "pulse" systems are not mentioned.
I then discovered that there are no FAA mandates requiring an oxygen
delivery system to meet any specific performance requirements as long as it
is "portable".
I noticed that manufacturers were making remarkable claims for the
oxygen-saving abilities of their systems but - as I discussed above - not
based on any form of objective peer-reviewed published study. It seemed to
me that I could show that the A4 at FAA rates probably produced some
hypoxia, and the Oxymizer probably did not have the characteristics claimed
for it, but how about "pulsed" systems and mask performance over 18,000?
Please note - I am not saying they are wrong - but before trusting my pink body
and those of my passengers to a strange-looking system I'd like some objective
and verifiable proof.
I use a D1 and I think the modern pulse systems are magnificent - probably -
at least as far as their use up to 18,000 with cannulae are concerned (but I
cannot prove this - no releasable data). They have been in use for many years with no
apparent untoward events. I am more concerned, however, at how the pulsed
systems perform with mask systems above 18,000. Several of the mask systems
I have seen in use appear to me to be dangerous regardless of the system
used to deliver the oxygen. Again - no data.
It doesn't make sense to me that a pulsed system should work with the sorts of
reservoir-style masks that should be used at altitude. But I may be wrong, that is
why I am asking if anyone out there has any information/data (preferable data)
that could answer these questions. I have asked several other companies but they
(rightly) regard what they have done (or possibly not done)as proprietary information.
So - no objective information.
I agree - pulse oximetry should solve the problem, IF one doesn't consider
the realities of what pilots are ACTUALLY liable to do as far as non-use. Will every
pilot who might go over 14,000 buy a pulse ox just in case? Probably not. Is it
realistic for an FBO to rent out a pulse ox? Probably not. It seems more sensible
to me to make sure the claims manufacturers make are objectively valid, then use
the pulse-ox (if you have one, didn't leave it at home, didn't realize how good the
thermals/wave were so didn't bring it along, its battery is OK, the ambient temp
isn't frigid, you have a glove over your finger, etc., etc.) to make sure.
In summary - In my opinion FAA mandates are way, way out of date and should
be brought up to modern standards reflecting pulse oximetry. Studies need to
be done in an open published manner documenting that manufactured equipment
will produce non-hypoxic saturation levels in every day use for "most"
pilots. In my opinion it isn't enough for a manufacturer to say "yep, we
haven't flight-tested the gadget because we don't have to, but trust me - it is OK".
Please let me know what you think in a helpful manner - after all I am only trying
to make flying safer for all of us and I have no hidden agendas.
David Reed M.D, Boulder CO
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 08:35 PM
Need oxygen information Neptune Soaring 3 May 10th 04 07:06 AM
Need oxygen information Neptune Soaring 4 May 6th 04 09:11 PM
hi alt oxygen Arquebus257WeaMag Military Aviation 62 March 28th 04 05:57 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 09:52 PM
