"Dan Luke" wrote in message ...
"Chip Jones" wrote: The problem is that these approaches quite literally just show up in a sector's airspace without any advance warning. Believe it or not, there is a great chance that your friendly ZTL controller didn't even *know* that there was a GPS approach into Greenville. FWIW, I looked up the approach in AOPA and it seems to be a new approach, just issued this cycle. I suspected as much. I suppose one should expect to have to "brief" the controller on the approach desired and just how one plans to begin it. I really don't mind, but it kinda seems like the pilot/controller "team" is ad libbing it in this situation. Also FWIW, I've taken to looking up a VOR degree-distance bearing for the GPS IAFs of approaches I think I might fly, if there isn't a charted transition or distance from a ground-based navaid or intersection on the plate. I can describe how I do this but others probably have better methods. Not sure if it's helpful to ATC, hasn't been called for yet. HTH, Sydney |
"Dan Luke" c172rgATbellsouthDOTnet wrote in
: How many here have flown GPS approaches with Center as the approach control? I'd be interested to hear your experiences. It's not just center, approach controllers sometimes have the same problems. Most often, from center I get something like "Maintain [whatever my assigned altitude is] until established on a published sector of the approach, cleared [approach I asked for]", or "Cruise [altitude]". The cruise clearance is easy for everyone, and I get it almost every time offshore, because there isn't any other choice for center out there. -- Regards, Stan |
![]() Dan Luke wrote: How many here have flown GPS approaches with Center as the approach control? I'd be interested to hear your experiences. I needed to fly one yesterday to get into Greenville, AL and the ZTL controller sounded really befuddled about quite how to handle it. Because of another recent experience, I told her 35 miles out just what I wanted to do, including the name of the IAF I wanted to use. Her response was to clear me down to 3,000', but nothing more. After about 10 miles of silence, I asked her to clear me direct to the IAF and told her the heading I would need. She said: "Cessna '87D, cleared...ah...for what you requested. Maintain at or above two thousand one hundred until established on the approach, cleared approach to Greenville, report canceling...etc." Now, the minimum altitude on that segment of the approach is 3,000'. Does her altitude restriction of 2,100' mean she had no way of knowing that, and could only use her MVA? After she cleared me, she came back a couple of minutes later and asked me to spell the IAF waypoint again. I would *highly* recommend you file a NASA ASRS report about the fumbling and clearance below the altitude for the approach segment to which you were being sent. That is your best opportunity to provide some input to hopefully get the system working before someone bites a dirt sandwhich. It seems that the Centers I talk to always fumble a bit when I ask for one of these approaches. What's the problem? The fun part of this was getting to say "UGMUF" several times on the radio. -- Dan C172RG at BFM |
![]() Snowbird wrote: It's generally pretty seamless. They know the fixes and the altitudes, even though our approaches are obnoxious and contain little or no indication of how they relate to the enroute system and the IAFs have nothing to do with airways or intersections on airways or even charted transitions. Any RNAV IAP developed in the past 3 years, or more, has its IAFs anchored on Victor airways unless there are no IAFS (I.e., radar required). |
![]() Stan Gosnell wrote: wrote in : Any RNAV IAP developed in the past 3 years, or more, has its IAFs anchored on Victor airways unless there are no IAFS (I.e., radar required). That's a pretty broad statement. Want me to show you some that aren't? No broader than the policy presently in effect. If you can find any that are less than 3 years old, fire away. In the early days there were a lot of them that weren't anchored to airways. And, of course, RNAV IAPs with TAAs are a different matter. |
![]() wrote in message ... I would *highly* recommend you file a NASA ASRS report about the fumbling and clearance below the altitude for the approach segment to which you were being sent. That is your best opportunity to provide some input to hopefully get the system working before someone bites a dirt sandwhich. He wasn't cleared below the altitude for the approach segment, the clearance was "maintain at or above two thousand one hundred until established on the approach." Nothing required him to descend below any charted altitude. No doubt 2100 is the local MVA, and you're not gonna bite a dirt sandwich at the MVA. |
![]() wrote in message ... Any RNAV IAP developed in the past 3 years, or more, has its IAFs anchored on Victor airways unless there are no IAFS (I.e., radar required). Rubbish. Many RNAV approaches have been established within the last three years that have no connection to Victor airways. |
![]() Stan Gosnell wrote: wrote in : Any RNAV IAP developed in the past 3 years, or more, has its IAFs anchored on Victor airways unless there are no IAFS (I.e., radar required). That's a pretty broad statement. Want me to show you some that aren't? I misspoke, slightly. If the IAF is not on airways then a feeder fix that is on airway will lead to the IAF. That is the case with both GPS approaches for Greenville, AL (KPRN). |
![]() wrote in message ... Stan Gosnell wrote: wrote in : Any RNAV IAP developed in the past 3 years, or more, has its IAFs anchored on Victor airways unless there are no IAFS (I.e., radar required). That's a pretty broad statement. Want me to show you some that aren't? I misspoke, slightly. If the IAF is not on airways then a feeder fix that is on airway will lead to the IAF. That is the case with both GPS approaches for Greenville, AL (KPRN). Which does *nothing* at all to assist ATC unless the feeder fix, the IAF, the FAF and the MAP are plotted and displayed on the sector PVD (ie- radar scope). For example, on the GPS RWY 32 into Greenville, CHAFF intersection helps define the IAF UGMUFF's relationship to the rest of the sector fabric. However, CHAFF is *unknown* to the ARTCC controller. It isn't plotted and displayed on the scope. She has likely *never* even heard of CHAFF in 20 years of working the same piece of airspace, regardless of the fact that the intersection may be established on an airway. Likely, CHAFF only exists on a paper chart somewhere in her Area's overhead displays, maybe not even a chart she can get to, assuming she isn't too busy to even try to get to it. To the controller, assuming that she even knows what CHAFF is, where CHAFF is and that CHAFF is now on the plate for the GPS 32 at PRN, she still doesn't have a lot to work with. The fact that IAF UGMUFF is plotted on the plate 080 degrees at 3.3 miles from CHAFF means nada to the controller because CHAFF is just another one of thousands of named fixes in her airspace. This is a training and procedural support issue that is reaching critical mass at ZTL and other busy, understaffed FAA ATC facilities. Simply put, we are now too busy working airplanes with a skeleton crew at ZTL to squeeze in training on "little" technical things like new IAP's. It's starting to seriously impact our technical services to the user, but at least they're getting maximum customer service efficiency for their tax dollar. Chip, ZTL |
RNAV approaches | Kevin Chandler | Instrument Flight Rules | 3 | September 18th 03 06:00 PM |
"Best forward speed" approaches | Ben Jackson | Instrument Flight Rules | 13 | September 5th 03 03:25 PM |
Logging instrument approaches | Slav Inger | Instrument Flight Rules | 33 | July 27th 03 11:00 PM |
Suppose We Really Do Have Only GPS Approaches | Richard Kaplan | Instrument Flight Rules | 10 | July 20th 03 05:10 PM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
