#51
"Dan Thompson" wrote
"I tend to think this IS a sound argument" This is about the flimsiest "argument" I've ever seen written, that additional safety equipment, on balance, makes people less safe because they become more cavalier about taking risks. It assumes that the people involved are not intelligent enough to understand the scope of safety benefit and risk reduction being provided. That is EXACTLY the assumption, and in my experience it's a pretty good one for most people. When ABS came out, many insurance companies would give you a break for having it. This is no longer the case. Turns out the accident rate for ABS-equipped cars is no lower than it is for cars not so equipped. It's not because the system doesn't work - unlike the CAPS installation in the Cirrus, ABS is proven and reliable. However, it causes people to drive more agressively, thus nulling out the benefit. Asessing the safety benefit of a given feature is not trivial, and this is especially true if the feature is high tech. For example, your asessment of the safety benefit of CAPS as a backup to the TKS reveals a lack of understanding of the scope of safety benefit and risk reduction being provided. The TKS system is, in fact, a tremendous safety advantage in icing conditions. The fact that it lacks known ice certification does not mean it offers no protection (or even reduced protection) but that the level of protection it offers is not proven. Nonetheless, the system is well understood, and the Cirrus TKS installation is not much different than what is seen on similar performance airplanes which are KI. The level of protection is not proven, but it can be reasonably estimated. I, too, would be willing to undertake flights with TKS (even if not certified KI) that would ground me in an airplane with no ice capability. However, the parachute is not a player here. If the icing is sufficiently bad that the TKS system is overwhelmed and the parachute system must be used, there are several reasons to believe that the outcome will be less than wonderful. First off, the parachute may fail to deploy properly. If there's enough ice formation on the wings to overwhelm the TKS, how much will there be on the fuselage? The deployment system literally has the risers peeling away thin layers of fiberglass from the fuselage, and the deployment system is sufficiently powerful to do this. Will it still be powerful enough if it has to go through layers of ice as well, or will it remain in trail - causing what skydivers call a bag lock? Will the risers be damaged in the process, only to fail upon opening shock? Nobody knows; the situation has not been tested or even mathematically modeled. If the parachute does deploy, it WILL accumulate ice. Anyone who has ever skydived in the North in Winter will tell you that. In fact, the slow-moving, small-diameter multiple suspension lines are ideal for accumulating ice. Round parachutes really don't flex much unless they are steered - something the Cirrus installation does not allow - and will not be effective in shedding ice. Further, the fuselage will already have accumulated ice, and will simply keep accumulating it. Therefore, you can expect that by the time impact occurs, the plane will be well over gross due to the ice. At gross weight, the descent rate under parachute is already very high. In the overgross condition, it will likely be high enough to injure the passengers (which, at this point, includes everyone in the cabin since the pilot ceases to have any ability to influence the flight once the parachute deploys). I have to wonder what the survival prognosis would be in this case. Michael |
#52
"Gig Giacona" wrote in message
... "G.R. Patterson III" wrote in message ... Sounds a lot like the French argument during WWI to the effect that allowing pilots to wear parachutes would cause them to be more cowardly. That's silly! The French couldn't be more cowardly. Oh, give it up already. You're talking of the nation of, just in our own endeavor, Bleriot and St Expury and his colleagues. The nation that lost more men fighting the German machine to a standstill in WWI, than the US has lost in all wars combined. The nation of the Resistance (whose bravery easily exceeded that of the rebels in 1776). The home nation of Medecins sans frontieres. And that's just free-associating, no googling, and only 20th century. What is it with this France-bashing? Do you need someone to feel superior to, because you can't feel superior on your own? -- David Brooks |
#53
Teacherjh wrote:
I think his point was that if having the chute causes a pilot to have a more cavalier attitude "in general" then this will increase the likelihood of accidents of ALL forms, not just those where the chute might help. I tend to think this IS a sound argument, albeit probably not yet supported by enough data. Attitude and judgment are key to safe piloting. If either is deficient, bad things will tend to result. For data of a related sort, look at how many pilots rely on GPS, and take flights they wouldn't otherwise (because of lack of preparation). (put another way, with GPS some people are more inclined to just get up and go, but without they will do more planning) GPS has given pilots a more cavalier attitude towards flight planning and pilotage (see the planning thread), I would be VERY surprised if it did not turn out that the chute gave pilots a more cavalier attitude towards weather and other conditions, while at the same time admitting to the ranks people who shouldn't even =be= pilots. One thing to remember, coming down on a TKS chute is a VERY UNDESIRABLE OUTCOME. I don't think people fully comprehend this. Yes, with my back condition it could be fatal. However, it is still probably more desirable than coming down without it! I'm not against the chutes at all, but I am against letting their presence change the behavior of the pilot. Matt |
#54
Dan Thompson wrote:
"I tend to think this IS a sound argument" This is about the flimsiest "argument" I've ever seen written, that additional safety equipment, on balance, makes people less safe because they become more cavalier about taking risks. It assumes that the people involved are not intelligent enough to understand the scope of safety benefit and risk reduction being provided. You must hang around a dumber group of pilots and airplane owners than I do. Sorry to burst your bubble, but this is a documented fact. The insurance companies found this out with antilock brakes. They initially gave discounts for cars so equipped ... until they found that the loss rate was actually higher for ABS equipped cars. A study determined that the issue was that drivers were driving more aggressively in poor weather as they thought the ABS would save them. Now, I tend to think the average pilot is a cut above the average driver, but we're all still human and all too often do crazy things. Just look at the most significant causes of accidents: fuel exhaustion, flight into IMC for VFR pilots, buzzing, etc. Almost all are due to poor judgement and, yes, simple stupidity in many cases. If all pilots were as intelligent as you claim, then accidents in these categories would be near zero, and mechanical failure would be the predominant cause of accidents. Just isn't so my friend. Matt |
#55
Colin Kingsbury wrote:
Dan, et. al, Here's an interesting link: http://www.bikersrights.com/statistics/stats.html It's a comparison of motorcycle accident rates between states that have mandatory helmet laws and those that don't. On balance the rates are lower in states that don't have helmet laws*. Yes, and this is the reason that PA repealed the motorcycle helmet law this year. The data just doesn't support it. Having said that, I still always wear my helmet. The reason being that I believe I don't take extra chances with it and thus actually am safer. However, across the entire population, this just doesn't appear to be the case. Counter intuitive to be sure. Matt |
#56
OK, you win. Cirrus owners are stupid. As dumb as car drivers and bikers.
They would be idiots to try the chute as a last resort in an iced-up airplane. I was stupid to mention it. What was I thinking? It would be better for them to just crash and end their stupid existence. Along with their moronic passengers who flew with them. You guys are brilliant, and much safer, for not choosing planes with chutes. I tip my hat to you. "Michael" wrote in message om... "Dan Thompson" wrote "I tend to think this IS a sound argument" This is about the flimsiest "argument" I've ever seen written, that additional safety equipment, on balance, makes people less safe because they become more cavalier about taking risks. It assumes that the people involved are not intelligent enough to understand the scope of safety benefit and risk reduction being provided. That is EXACTLY the assumption, and in my experience it's a pretty good one for most people. When ABS came out, many insurance companies would give you a break for having it. This is no longer the case. Turns out the accident rate for ABS-equipped cars is no lower than it is for cars not so equipped. It's not because the system doesn't work - unlike the CAPS installation in the Cirrus, ABS is proven and reliable. However, it causes people to drive more agressively, thus nulling out the benefit. Asessing the safety benefit of a given feature is not trivial, and this is especially true if the feature is high tech. For example, your asessment of the safety benefit of CAPS as a backup to the TKS reveals a lack of understanding of the scope of safety benefit and risk reduction being provided. The TKS system is, in fact, a tremendous safety advantage in icing conditions. The fact that it lacks known ice certification does not mean it offers no protection (or even reduced protection) but that the level of protection it offers is not proven. Nonetheless, the system is well understood, and the Cirrus TKS installation is not much different than what is seen on similar performance airplanes which are KI. The level of protection is not proven, but it can be reasonably estimated. I, too, would be willing to undertake flights with TKS (even if not certified KI) that would ground me in an airplane with no ice capability. However, the parachute is not a player here. If the icing is sufficiently bad that the TKS system is overwhelmed and the parachute system must be used, there are several reasons to believe that the outcome will be less than wonderful. First off, the parachute may fail to deploy properly. If there's enough ice formation on the wings to overwhelm the TKS, how much will there be on the fuselage? The deployment system literally has the risers peeling away thin layers of fiberglass from the fuselage, and the deployment system is sufficiently powerful to do this. Will it still be powerful enough if it has to go through layers of ice as well, or will it remain in trail - causing what skydivers call a bag lock? Will the risers be damaged in the process, only to fail upon opening shock? Nobody knows; the situation has not been tested or even mathematically modeled. If the parachute does deploy, it WILL accumulate ice. Anyone who has ever skydived in the North in Winter will tell you that. In fact, the slow-moving, small-diameter multiple suspension lines are ideal for accumulating ice. Round parachutes really don't flex much unless they are steered - something the Cirrus installation does not allow - and will not be effective in shedding ice. Further, the fuselage will already have accumulated ice, and will simply keep accumulating it. Therefore, you can expect that by the time impact occurs, the plane will be well over gross due to the ice. At gross weight, the descent rate under parachute is already very high. In the overgross condition, it will likely be high enough to injure the passengers (which, at this point, includes everyone in the cabin since the pilot ceases to have any ability to influence the flight once the parachute deploys). I have to wonder what the survival prognosis would be in this case. Michael |
#57
![]() "Michael" wrote in message om... ABS is proven and reliable. However, it causes people to drive more agressively, thus nulling out the benefit. While the rest of the post was extremely well constructed, and strikingly similar to some thoughts I had on the issue (I had images of the ice laden tangled chute having a terminal velocity exceeding that of the aircraft that had the effect of pulling the plane tail first into the ground), I have to point out one nuance of difference on the point quoted. My experience with ABS is that most people are neither TRAINED properly, nor do they take the time to understand how it works, to use ABS correctly (when needed and when not). The situation concerning insurance discounts is not a function of more aggressive driving, imho. I would further argue that this is currently the issue facing the chute on the Cirrus - there is no way (AFAIK) to train on the proper use of the system, both in terms of function and in the decisionmaking process, that fully demonstrates the experience of what will occur leading up to deployment and through the outcome to its inevitable conclusion. Just as it takes a considerably different mindset for a panicked driver with ABS to be prepared to steer around an obstruction during an event that requires maximum braking, and actually do it, it takes a considerably different mindset for a pilot to abdicate control of the aircraft when all of the training is oriented toward maintaining and recovering control of the aircraft. That mindset is a function of training, and until there is a simulator that can emulate the experience and provide that training, I think there will be accidents like the one in NY in which the question cannot be conclusively answered about whether or not the pilot activated the CAPS system. Of course, it would be nice if the design of the activation system were able to provide an indication that deployment was attempted. That said, I will ONLY buy vehicles with ABS, and I really like the Cirrus. Bob |
#58
![]() "Matthew S. Whiting" wrote in message ... Dan Thompson wrote: They initially gave discounts for cars so equipped ... until they found that the loss rate was actually higher for ABS equipped cars. A study determined that the issue was that drivers were driving more aggressively in poor weather as they thought the ABS would save them. I still contend the root cause here is the misinformation created from a lack of proper training. In addition, the ABS may have been able to effect a different outcome, even despite the reckless behavior, if the driver actually knew how to use it. To me, drivers treat ABS like airbags: 'I know I have it, but I don't need to know how to use it because it functions on its own for my safety.' As such, perhaps we should conclude that it's not the ABS or the parachute, it's the a priori behavior that creates the situation in the first place (including proper training in addition to good, up-to-the-moment ADM) that deserves the attention. |
#59
![]() "Matthew S. Whiting" wrote in message ... Dan Thompson wrote: "I tend to think this IS a sound argument" This is about the flimsiest "argument" I've ever seen written, that additional safety equipment, on balance, makes people less safe because they become more cavalier about taking risks. It assumes that the people involved are not intelligent enough to understand the scope of safety benefit and risk reduction being provided. You must hang around a dumber group of pilots and airplane owners than I do. Sorry to burst your bubble, but this is a documented fact. If this is a "documented fact" you wouldn't mind providing links to the documents then? Dashi |
#60
Dan Thompson wrote:
OK, you win. Cirrus owners are stupid. As dumb as car drivers and bikers. They would be idiots to try the chute as a last resort in an iced-up airplane. I was stupid to mention it. What was I thinking? It would be better for them to just crash and end their stupid existence. Along with their moronic passengers who flew with them. You guys are brilliant, and much safer, for not choosing planes with chutes. I tip my hat to you. Have you always had this problem with reading comprehension? We said none of the above ... OK, maybe implied that some car drivers aren't real bright. Then again, that is hardly a revelation to anyone who has driven recently. Matt |
