#21
"You can't fly this plane
partial panel, so just couple up the autopilot to the GPS and have it fly the approach" - which is, no ****, what glass-panel Cirrus pilots are told. In that case it's no wonder the insurance rates are so high. In one sense, no. I don't believe there is a single accident attributed to lack of partial panel proficiency in a Cirrus, with the possible exception of the guy who launched into 800 ft ceilings on the first flight after major panel work and wound up pulling the chute. The airplane is quite reliable. People are not crashing because they are depending on systems that fail. But in another sense you are right. People are crasing because their skill level is not up to the airplane, and this basic problem is not being addressed. Limited panel flying has intrinsic value over and above coping with the particular failure being simulated - it forces the pilot to become sharper, to get more out of the instruments, and to become smoother. It improves all aspects of his flying. As long as all the automation works, the Skyhawk IFR pilot can be a Cirrus IFR pilot with his existing skill set This is no different than telling a VFR pilot to set the auto pilot and let it fly if he/she runs into bad weather, or poor visibility. Let's say it's a difference in degree only, and not in kind. On my first flight in the glass panel Cirrus I asked the owner why there was no CDI other than in the PFD. He didn't see my point. I explained that if the PFD went out, the only approach we could shoot would be a GPS or GPS overlay (using the Garmin display) since there were 2 GNS-430's but no external CDI for either. I felt this was acceptable (what are the odds of PFD failure in conditions where GPS approach conditions are not in range?) but suboptimal. He then explained that the factory recommends not shooting a manual approach with a failed PFD at all - just couple up the autopilot and let it do the job. This despite the fact that altimeter, ASI, compass, and AI are all available. But at least part of the problem must be laid squarely at the feet of the people doing the teaching and testing. This pilot took his IFR checkride in his Cirrus, and the DE insisted he do a manual LOC approach with the PFD off. Of course the GPS is NOT as accurate as a LOC close in, but the DE didn't want to hear it. Thus I am reluctant to blame the peope who are not being properly trained - what chance do they have if even the DE's have no clue? You have not created a better pilot, you have given him/her a crutch to make up for lack of skill which is a very poor teaching method and dangerous practice. Like I said, Personally, I think that's a ****-poor way to do things. The real hazard, though, is not that the system that the pilot is depending on will fail. These are fairly new airplanes, and those systems are reliable. They're not failing a lot. The real problem is that the system only does what it's built to do. Training makes a pilot better overall. Substitute systems for training, and you better hope you have systems to do EVERYTHING the pilot does, because without the training, you will have an inferior pilot. Michael |
![]() "Michael" wrote in message ups.com... The real hazard, though, is not that the system that the pilot is depending on will fail. These are fairly new airplanes, and those systems are reliable. They're not failing a lot. The real problem is that the system only does what it's built to do. Training makes a pilot better overall. Substitute systems for training, and you better hope you have systems to do EVERYTHING the pilot does, because without the training, you will have an inferior pilot. Michael I have kept out of this debate but the above raises a significant opportunity. I don't know what exists yet in the US, but in Oz there is some classroom training associated with flying the Cirrus however I am unaware of any "glass cockpit" course per se. Our regulator has kept the syllabus to the days of rag and string and pommie motors, with a lot of emphasis on technical matters of no real use. What is needed is a part of the syllabus / course / book on the management and use of the glass cockpit, based around the current Avidyne/Garmin gear. It's the way of the future and training should respond accordingly to assist pilots to make the transition. Particularly us "matures" as the next generation will be flying these cockpits as the norm. Brian |
![]() Thomas Borchert wrote: Robert, So, I'm wondering if all this talk about a long transition time is mostly for the generation that didn't grow up with computers. After reading the articles and spending 30 minutes flying the Entegra system on a clear VFR day, I tend to agree with your view. I tend to agree. Guys who are used to computers seem to pick it up pretty fast. The user interface on these new systems is more intuitive and people are less afraid of doing something wrong. It is the guys who insist on trying to memorize every key and menu setting before they will touch the thing that run into trouble. |
#24
I'm a computer guy but I got lost on the Garmin 430 a couple times when I first flew behind one (at the time it was just a stupid box to me, I really didn't need to turn it on). When in map mode if you turn the little knob and the big knob a couple times you can quickly get lost. The GX GPS has a "map" button to get you back to the map when you get lost, the 430 could really use a "main menu" type button to get you unstuck. I've power cycled them before. -Robert |
#25
![]() Robert M. Gary wrote: Guys who are used to computers seem to pick it up pretty fast. I'm a computer guy but I got lost on the Garmin 430 a couple times when I first flew behind one (at the time it was just a stupid box to me, I really didn't need to turn it on). When in map mode if you turn the little knob and the big knob a couple times you can quickly get lost. The GX GPS has a "map" button to get you back to the map when you get lost, the 430 could really use a "main menu" type button to get you unstuck. I've power cycled them before. Yes, it certainly could use a button like that. I like the 430, but I think the buttons are too small and the menus are a mess. Simple things like switching radios or navaids can be a real problem if you are not familiar with it. The nearest competitor, the KLN 89B, shares many of the same problems. Both units also need a dedicated missed approach button, IMHO. |
#26
On 29 Sep 2005 10:57:55 -0700, "Robert M. Gary"
wrote: Guys who are used to computers seem to pick it up pretty fast. I'm a computer guy but I got lost on the Garmin 430 a couple times when I first flew behind one (at the time it was just a stupid box to me, I really didn't need to turn it on). When in map mode if you turn the little knob and the big knob a couple times you can quickly get lost. The GX GPS has a "map" button to get you back to the map when you get lost, the 430 could really use a "main menu" type button to get you unstuck. I've power cycled them before. 1. Learn how to turn on. 2. Learn hot to get to, or back to the default menu. #2 may be more important than #1. If the default menu doesn't contain the basic flight instruments, boycott the manufacturer. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com -Robert |
Cambridge 302 learning curve cont. | Tuno | Soaring | 4 | July 5th 04 10:10 AM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
learning curve in fs 2002.. | David Ciemny | Simulators | 5 | December 30th 03 12:18 AM |
18m polar curve | Alan Irving | Soaring | 1 | December 15th 03 11:45 PM |
Lesson in Glass | JimC | Owning | 3 | August 6th 03 01:09 AM |
