Our CAP unit is going to be receiving a new C-182 with a glass cockpit.
In order to give us a taste of it a Cirrus owner came to our CAP meeting and showed us his wonderful aircraft (not the same PDF/MFD but close). I've heard from many sources that it takes about 10 hours to transition. In fact a local FBO has a brand new C-182 (rents for about $200/hr) and requires 15 hours. Although I didn't fly the Cirrus, I sat in the aircraft while the owner spoke with someone else. He said we could push any buttons we wanted to. So, I tried to think of all the things I could normally do on an IFR flight. Amazingly, I had no problems with any of the operations. The display is easy for me because my generation grew up flying flight simulators that use the exact same display. The only hard part is figuring out the 430s (which I've done before). So, I'm wondering if all this talk about a long transition time is mostly for the generation that didn't grow up with computers. Just thinking about the time it takes some people (not necessarily based on age) to get familiar with their computer vs. others, I'm wondering if its the same thing. Perhaps I'm being naive but I felt that I could fly behind that panel today. Has anyone on this list had experience with such a transition? -Robert, CFI |
transition. It depends on two things - how complete a transition do you want, and what is your experience going in. For a novice IFR pilot who wants (or maybe needs) all the automation and functionality the system has to offer, it can actually take longer. For an experienced IFR steam gauge pilot who only wants as much functionality as he is used to having, 15 minutes is closer to the mark. Although I didn't fly the Cirrus, I sat in the aircraft while the owner spoke with someone else. He said we could push any buttons we wanted to. So, I tried to think of all the things I could normally do on an IFR flight. Amazingly, I had no problems with any of the operations. That was my experience as well. The first flight I ever took in the Cirrus, I needed about 15 minutes to come up to speed on how everything worked. 30 minutes into the flight I was teaching the owner how to use his engine analyzer to operate LOP. At the end of that flight, the pilot botched an ILS approach enough to peg the GS needle (in IMC, but with a fly-down indication). By then, I was so comfortable with the plane, I was able to talk him through a recovery to the approach. There is still functionality there that I can't effectively use, but what I can use is way more than what I have available in my Twin Comanche. So, I'm wondering if all this talk about a long transition time is mostly for the generation that didn't grow up with computers. Actually, I think the long transition is for those who are not already experienced steam gauge pilots. Think about this - did you learn how to program the flight plan capabilities of the map display, or were you doing it all in direct-to mode? I do the latter - after all, that's all we ever had flying fix-to-fix with VOR/DME. Can you program the vertical guidance for enroute descent, or do you just figure that at 150 kts you need 5 nm per 1000 ft at 500 fpm, and at 180 kts you need 6 nm? Basically, what I'm saying is that there is probably a lot of automation capability you're not using, but as an experienced IFR pilot you probably don't need it. The all-glass Cirrus has a set of emergency instruments - a card compass, an ASI, altimeter, and AI. It also has dual 430's. If the PFD fails, the factory recommends you couple up the A/P to the 430 and not try to hand-fly it. I would almost certainly screw up trying to do that. On the other hand, I have no doubt I could fly a good GPS approach simply using the 430 map and the available panel. Partial panel with an AI? Luxury! Basically, I think most of the people getting into the Cirrus are NOT experienced steam gauge IFR pilots. They mostly don't have the skills to effectively fly such a fast and slippery airplane IFR in IMC without the automation the system offers. Therefore, they need the long transition to learn how to use the automation. For someone with 100+ hours of actual in Mooney/Bonanza/Comanche or similar airplanes with a steam gauge panel, the complex automation is not at all necessary - thus his transition is quick. Michael |
compass, an ASI, altimeter, and AI. It also has dual 430's. If the PFD fails, the factory recommends you couple up the A/P to the 430 and not try to hand-fly it. I would almost certainly screw up trying to do that. I don't see how. Assuming your 430s have a flight plan and you're following it, all you've got to do is engage GPSS and ALT. Or GPSS and VS and then dial in the vertical speed you want on the autopilot. On the other hand, I have no doubt I could fly a good GPS approach simply using the 430 map and the available panel. Partial panel with an AI? Luxury! |
I don't see how. Assuming your 430s have a flight plan and you're following it, all you've got to do is engage GPSS and ALT. Or GPSS and VS and then dial in the vertical speed you want on the autopilot. You know, the A/P in my Twin Comanche can do wing level, heading hold, and it can sort of track the LORAN but I don't like how it does that - too much hunting. I put it in because I got it cheap. Altitude hold would be nice, but installingthe pitch servo is a pain so I don't have it. For years, I flew the plane night and hard IFR with no autopilot at all. I still don't use it in IMC - it's for long boring stretches of VFR flight. I have actually flown planes that had GPSS, VS, and similar funtions. GPSS is great when you know exactly how to engage it. I once borrowed a Mooney that had an STEC and GNS430 with GPSS. Took me about 15 minutes to figure out why it wasn't working - silly me, I thought following a GPS meant the A/P should be in nav mode. Nope, heading. Honestly, if the weather had gone foul then, I would have disconnedcted the silly thing and hand flown it instead of figuring in out. I used to instruct a student in an Ovation that had the KFC autopilot. Had to learn how to work it to explain it to him. He kept busting through altitudes with that VS function. Turned out the solution was to press one more button - and then it would say ARM and that meant that when it reached the altitude preset it would level off. I'm not sure I remember how to do it now. Anyway, my point is that without the manual, I would likely not be able to figure out how to press all the buttons to correctly couple up the autopilot to the 430 for an approach. I'd get something wrong, for sure. And all the button-pushing would distract me from doing my job - that is, landing the damn airplane. And I can assure you that with a moving map GPS, an AI, an ASI and an altimeter I can fly an approach and land the plane - it's nothing compared to doing a partial panel VOR with just a TC and compass, never mind an NDB. Michael |
On 16 Sep 2005 11:29:13 -0700, "Michael"
wrote: I've heard from many sources that it takes about 10 hours to transition. It depends on two things - how complete a transition do you want, and what is your experience going in. For a novice IFR pilot who wants (or maybe needs) all the automation I think it's highly unlikely the novice IFR pilot needs any where near the full functionality, at least to begin with and definately does not need it all at once. and functionality the system has to offer, it can actually take longer. If they get the system in incremental doses as needed it should barely be noticeable. For an experienced IFR steam gauge pilot who only wants as much functionality as he is used to having, 15 minutes is closer to the mark. Which is what the novice pilot should be doing instead of a full indoctrination. I speak computereese and in a number of languages. I sure didn't get all that in one shot. Although I didn't fly the Cirrus, I sat in the aircraft while the owner spoke with someone else. He said we could push any buttons we wanted to. So, I tried to think of all the things I could normally do on an IFR flight. Amazingly, I had no problems with any of the operations. That was my experience as well. The first flight I ever took in the Cirrus, I needed about 15 minutes to come up to speed on how everything worked. 30 minutes into the flight I was teaching the owner how to use his engine analyzer to operate LOP. At the end of that flight, the pilot botched an ILS approach enough to peg the GS needle (in IMC, but with a fly-down indication). By then, I was so comfortable with the plane, I was able to talk him through a recovery to the approach. There is still functionality there that I can't effectively use, but what I can use is way more than what I have available in my Twin Comanche. So, I'm wondering if all this talk about a long transition time is mostly for the generation that didn't grow up with computers. Probably, but another problem is people thinking they need to know how to do everything when they first go out such as FBOs and insurrance companies wanting the renter, or owner to be proficient with every thing the units are capable of doing before letting them fly the airplane which is rediculous. These are things that are far easier to use step wise than as a seperate entitie. Having taught computer science at the university level, I'd guess the average indivudual would take on the order of 10 times longer to learn how to use the complete glass panel display the way most teach them compared to learning to use the functions incrementally as needed. I didn't gro up with computers, they didn't have them back then, but I've had my own computer since late 1979 and that first one cost one whale of a lot more than this 3.4 gig, 64 bit monster with 2 Gig of RAM and half a terabyte of HD space plus large LCD monitor, slide/film scanner, flat bed scanner, and printer. Actually it cost more without monitor and keyboard than this one and the 3.2 Gig unit to the right of me with 1.3 terabytes of HD storage including a 400 Gig RAID and large monitors combined. Come to think, it's more like the computers grew up with me:-)) They feel like a natural extension and I find the glass panel flight instruments more natural to use than the old "steam gauges". Actually, I think the long transition is for those who are not already experienced steam gauge pilots. Think about this - did you learn how to program the flight plan capabilities of the map display, or were you doing it all in direct-to mode? I do the latter - after all, that's Do it the simple way first. :-)) all we ever had flying fix-to-fix with VOR/DME. Can you program the vertical guidance for enroute descent, or do you just figure that at 150 kts you need 5 nm per 1000 ft at 500 fpm, and at 180 kts you need 6 nm? Basically, what I'm saying is that there is probably a lot of automation capability you're not using, but as an experienced IFR pilot you probably don't need it. Nor does the IFR student, at least no all in one dose. The all-glass Cirrus has a set of emergency instruments - a card compass, an ASI, altimeter, and AI. It also has dual 430's. If the PFD fails, the factory recommends you couple up the A/P to the 430 and not try to hand-fly it. I would almost certainly screw up trying to do that. On the other hand, I have no doubt I could fly a good GPS approach simply using the 430 map and the available panel. Partial panel with an AI? Luxury! I think people make things too complicated. Basically, I think most of the people getting into the Cirrus are NOT experienced steam gauge IFR pilots. They mostly don't have the skills to effectively fly such a fast and slippery airplane IFR in IMC without the automation the system offers. Therefore, they need the long transition to learn how to use the automation. For someone with 100+ hours of actual in Mooney/Bonanza/Comanche or similar airplanes with a steam gauge panel, the complex automation is not at all necessary - thus his transition is quick. Although I agree I think this may be a bit of mixing apples and oranges. Most learn to fly instruments in relatively simple and forgiving airplanes. (fixed gear and docile). If they learn to fly the glass panels in 172s or 182s instead of the Cirrus or other high performance aircraft and learn to use the instrument functions as they need them it would be far easier and take less time. (The Cirrus is every bit as complicated to fly as a Bonanza). I'd liken the way it's being done now to doing primary training in a Bo in IMC. They are slipery and you really need a good autopilot to be flying one much in IMC. (It sure reduces the work load) Transitioning to, or learning on a glass panel does not need to be difficult or take hours and hours of training. To do so means some very important steps have been left out of the learning cycle, or the cycle was not taken in logical order. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Michael |
![]() Transitioning to, or learning on a glass panel does not need to be difficult or take hours and hours of training. To do so means some very important steps have been left out of the learning cycle, or the cycle was not taken in logical order. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I don't know that I can agree with you Roger. I recently had a chance to fly a Cessna 421C with the Chelton Synthetic Vision TM installed. I had no previous experience with EFIS and had only a short time to read the basics out of the manual. My flight was about 1 1/2 hours in VFR and I had a safety pilot with me to watch for traffic as I knew I would be head down and locked for a good portion of the time. The system presents an overwhelming amount of information and it is shown in an unfamiliar format. I know it would take me another 5-10 hours of flight time with the system before I would be launching into any IFR flight that required an approach. I have a good amount of time in the Cessna 421C so flying the aircraft is not a problem, interpreting and following the EFIS is. With all that being said the system is wondeful with what it can do and I believe it is the way of the future. The only problem I see is pilots like me who grew up on the gauges switching over to the tubes. The company that owns the aircraft plans on putting it on a FAR 135 certificate. I am going to try to follow it's progress to see if the FAA requires any special training. Allen |
On Sat, 24 Sep 2005 18:37:26 GMT, "A. Smith"
wrote: Transitioning to, or learning on a glass panel does not need to be difficult or take hours and hours of training. To do so means some very important steps have been left out of the learning cycle, or the cycle was not taken in logical order. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I don't know that I can agree with you Roger. I recently had a chance to fly a Cessna 421C with the Chelton Synthetic Vision TM installed. I had no previous experience with EFIS and had only a short time to read the basics out of the manual. My flight was about 1 1/2 hours in VFR and I had a You are pointing out just what I said. The problems come when the transition is attempted to be made in total instead of incrementally. The learning pilot, whether IFR or primary student doesn't have these problems, or shouldn't if the training on the glass panel is done incrementally. I like Michael's use of the Cirrus. It's an oft misunderstood aircraft that is treated like other fixed gear aircraft when it should be treated like high performance retracts without the option of using the gear to slow down. safety pilot with me to watch for traffic as I knew I would be head down and locked for a good portion of the time. The system presents an overwhelming amount of information and it is shown in an unfamiliar format. I know it would take me another 5-10 hours of flight time with the system before I would be launching into any IFR flight that required an approach. I have a good amount of time in the Cessna 421C so flying the aircraft is not a problem, interpreting and following the EFIS is. This is where trying to take in a complex system all at once is a poor way to go. We don't teach computers that way and the glass cockpit should not be taken on in that manner either. As I said earlier, taken in a logical order although the logic might vary some between pilots. Pilots and CFIs are not normally computer people. They have a tendency, or I should say they feel an absolute need to know the entire system before starting out. FBOs and insurance companies tend to be the same. It's the wrong way to go. First, Basic flight and engine instruments with basic radio and nav. (no flight plans) to begin. Then GPS and moving map and on up the chain. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com With all that being said the system is wondeful with what it can do and I believe it is the way of the future. The only problem I see is pilots like me who grew up on the gauges switching over to the tubes. The company that owns the aircraft plans on putting it on a FAR 135 certificate. I am going to try to follow it's progress to see if the FAA requires any special training. Allen |
![]() "Roger" wrote in message ... On Sat, 24 Sep 2005 18:37:26 GMT, "A. Smith" wrote: Transitioning to, or learning on a glass panel does not need to be difficult or take hours and hours of training. To do so means some very important steps have been left out of the learning cycle, or the cycle was not taken in logical order. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I don't know that I can agree with you Roger. I recently had a chance to fly a Cessna 421C with the Chelton Synthetic Vision TM installed. I had no previous experience with EFIS and had only a short time to read the basics out of the manual. My flight was about 1 1/2 hours in VFR and I had a You are pointing out just what I said. The problems come when the transition is attempted to be made in total instead of incrementally. The learning pilot, whether IFR or primary student doesn't have these problems, or shouldn't if the training on the glass panel is done incrementally. I see your point. If the glass panel can be learned from the ab initio state it will just be normal procedure. I am looking at it from the viewpoint of someone who has been flying gauges for years. You can't just read the book, file a flightplan and blast-off into 200 and 1/2. Wouldn't be prudent! (:-) Allen |
automation capability you're not using, but as an experienced IFR pilot you probably don't need it. Nor does the IFR student, at least no all in one dose. I agree, but it's not the IFR student who needs the long transition. It's the pilot with an instrument rating but not much IFR experience in a fast, slippery (relatively - I'm talking Bonanza, not BeechJet) airplanes. You're right that the IFR student doesn't need the automation - because he's not trying to fly halfway across the country through busy airspace and scuzzy weather. Most learn to fly instruments in relatively simple and forgiving airplanes. (fixed gear and docile). If they learn to fly the glass panels in 172s or 182s instead of the Cirrus or other high performance aircraft and learn to use the instrument functions as they need them it would be far easier and take less time. (The Cirrus is every bit as complicated to fly as a Bonanza). I agree with all of that. In my opinion, the Cirrus is actually MORE demanding in IMC than a Bonanza, because the Bonanza gives you a very effective option for slowing down (gear speeds are typically around the 150 kt mark), but the Cirrus does not and thus requires more advance planning if you want to avoid being high and hot. Removing two levers doesn't really make up for that. If you take someone who can already fly IMC competently in a steam gauge Skyhawk and put him into a glass Skyhawk, the transition will be 15 minutes or so - he'll get the fucnitonality he needs and can get the rest later. The problem happens when you put him into a Cirrus. Now he doesn't have enough cycles to fly the Cirrus - not because of the glass, but because it's faster, less stable, and requires way more advance planning. The correct solution is to develop his skills - scan, control, and headwork - to where he can keep up with the more demanding airplane. Unfortunately, all too often the 'solution' offered is to substitute automation for skill. Nobody can hand-fly a Bonanza (or similar airplane) SMOOTHLY while copying a clearance, flipping through charts, and generally messing with stuff. There will be minor heading and altitude deviations even with the best of pilots. Also, nobody can hand-fly such an airplane for hours (especially in the soup) without becoming fatigued. That's why an autopilot is nice to have. But there's a difference between minor heading and altitude deviations and loss of control. Someone making the jump from a Skyhawk-class airplane to a 300 hp Bonanza (or Cirrus) will likely lose control when he tries to do several things at once. The solution is discipline and training. Learn to have the approach (including the first segment of the missed) briefed so you never have to do anything but fly once you're inside the marker. Learn to divide attention and perform tasks in short segments. The skills required are no different in the Cirrus than they are in the Skyhawk, it's just that the Skyhawk lets you get by with a lot more sloppiness. That's not a bad thing - it's the reason why it's a whole lot easier to teach someone to fly instruments in a Skyhawk-class airplane and then transition him to a Bonanza or Mooney than it is to start in the fast slippery airplane. I know, I've done it both ways. The problem occurs when the pilot is told that the solution is not skill development but automation. Instead of being told "If you have to fly this plane partial panel, it will be more difficult so you need more training and practice" he is told "You can't fly this plane partial panel, so just couple up the autopilot to the GPS and have it fly the approach" - which is, no ****, what glass-panel Cirrus pilots are told. Instead of being told "you need to learn to divide your attention between flying your existing clearance and checking your new one" he is told "you need to learn how to enter your route into the navigation computer and have it autosequence for you, so you can turn the autopilot on at any time and keep it on as long as necessary." Instead of being told "Now that you're flying higher and faster you need to plan your descent" he's told "you need to program your Vnav profile so it can prompt you for a descent and provide guidance." As long as all the automation works, the Skyhawk IFR pilot can be a Cirrus IFR pilot with his existing skill set - but then he needs to learn how to use all the automation to make up for what he can't do. Personally, I think that's a ****-poor way to do things. Michael |
On 24 Sep 2005 11:43:12 -0700, "Michael"
wrote: snip Nobody can hand-fly a Bonanza (or similar airplane) SMOOTHLY while copying a clearance, flipping through charts, and generally messing with stuff. There will be minor heading and altitude deviations even with the best of pilots. Also, nobody can hand-fly such an airplane for hours (especially in the soup) without becoming fatigued. That's why an autopilot is nice to have. It's strange you should have brought up that particular item. My first hour and eight minutes in the Deb were spent in a building storm that was at least moderate turbulence, zero visibility and only my second time in actual. I ended up flying the entire flight on manual. Ask why I know to the minute the time we were solid IMC. GAWD, but I was sick. Lunch bag tucked under my leg for quick access, turbulence tot he point where it was almost impossible to hit the correct switch without many tries, and torrential rain. At least we found no leaks in the Deb. Whipped at the end of the trip would be an understatement. But there's a difference between minor heading and altitude deviations and loss of control. Someone making the jump from a Skyhawk-class airplane to a 300 hp Bonanza (or Cirrus) will likely lose control when he tries to do several things at once. The solution is discipline and training. Learn to have the approach (including the first segment of the missed) briefed so you never have to do anything but fly once you're inside the marker. Learn to divide attention and perform tasks in short segments. The skills required are no different in the Cirrus than they are in the Skyhawk, it's just that the Skyhawk lets you get by with a lot more sloppiness. That's not a bad thing - it's the reason why it's a whole lot easier to teach someone to fly instruments in a Skyhawk-class airplane and then transition him to a Bonanza or Mooney than it is to start in the fast slippery airplane. I know, I've done it both ways. The problem occurs when the pilot is told that the solution is not skill development but automation. Instead of being told "If you have to fly this plane partial panel, it will be more difficult so you need more training and practice" he is told "You can't fly this plane partial panel, so just couple up the autopilot to the GPS and have it fly the approach" - which is, no ****, what glass-panel Cirrus pilots are told. Instead of being told "you need to learn to divide your In that case it's no wonder the insurance rates are so high. attention between flying your existing clearance and checking your new one" he is told "you need to learn how to enter your route into the navigation computer and have it autosequence for you, so you can turn the autopilot on at any time and keep it on as long as necessary." Instead of being told "Now that you're flying higher and faster you need to plan your descent" he's told "you need to program your Vnav profile so it can prompt you for a descent and provide guidance." As long as all the automation works, the Skyhawk IFR pilot can be a Cirrus IFR pilot with his existing skill set - but then he needs to This is no different than telling a VFR pilot to set the auto pilot and let it fly if he/she runs into bad weather, or poor visibility. You have not created a better pilot, you have given him/her a crutch to make up for lack of skill which is a very poor teaching method and dangerous practice. learn how to use all the automation to make up for what he can't do. Personally, I think that's a ****-poor way to do things. It's a very dangerous way to do things. It's great to do one the pilot is proficient in the particular airplane and has become proficient with the systems, , but still the learning of the glass panel needs to be incremental and not a "all-at-once", or know it all before you type of thing. Systems have a way of failing at the most inopportune time. That is not the time to be using the system and autopilot as a crutch. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Michael |
Cambridge 302 learning curve cont. | Tuno | Soaring | 4 | July 5th 04 10:10 AM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
learning curve in fs 2002.. | David Ciemny | Simulators | 5 | December 30th 03 12:18 AM |
18m polar curve | Alan Irving | Soaring | 1 | December 15th 03 11:45 PM |
Lesson in Glass | JimC | Owning | 3 | August 6th 03 01:09 AM |
