When planning a flight against the wind, how to you pick the best
altitude when trying to minimize flight time? If I read my performance charts correctly, my aircraft (Piper Turbo Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of *true* airspeed for every 1000 feet you go up. Firstly, does that sound about right to folks? I assume that this effect is from the decrease in air friction at high altitudes (even though the prop also has less air to "push on"). So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? My experience thus far suggests that most of the time, the winds aloft speed increase far faster then 2 nts per 1000 feet, so, in general, it is unlikely that I will do much better than staying at the absolute minimum altitude. Is that consistent with other folks' experience? -Sami |
when I plan a flight against the wind (like a few days ago comming back from
phoenix) I go with the altitude that gives me the best ground speed. On my way back from phoenix at 8500 ft I had a GS of 130 kts, I had to go to 10500 for terrain and my GS went down to 117 kts., so I jumped back down to 8500 when I had the chance. Turbo airplanes take advantage of the thinner air up high is why they can go faster then normally aspirated planes. you maintain your full 200 HP up to a DA of 12,000 ft. So 12000 ft is where you start to lose horse power but the air is thinner allowing you a better TAS and if you play the winds right, some really good ground speeds. stay low if you have a head wind, get up high when you have a tail wind. Sometimes, the wind down low will be higher then say around 10,000 or 12000 ft or about the same. If there is not much difference in the winds, I would select the higher altitude because of the thinnner air. Also you dont use as much fuel up high. "O. Sami Saydjari" wrote: When planning a flight against the wind, how to you pick the best altitude when trying to minimize flight time? If I read my performance charts correctly, my aircraft (Piper Turbo Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of *true* airspeed for every 1000 feet you go up. Firstly, does that sound about right to folks? I assume that this effect is from the decrease in air friction at high altitudes (even though the prop also has less air to "push on"). So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? My experience thus far suggests that most of the time, the winds aloft speed increase far faster then 2 nts per 1000 feet, so, in general, it is unlikely that I will do much better than staying at the absolute minimum altitude. Is that consistent with other folks' experience? -Sami |
I travel about 8-10 thousand into the wind and 14-20 with the wind. I agree.
Usually the headwind increases faster than TAS with altitude. I travel 8-10 for safety--glide distance. "Jeff" wrote in message ... when I plan a flight against the wind (like a few days ago comming back from phoenix) I go with the altitude that gives me the best ground speed. On my way back from phoenix at 8500 ft I had a GS of 130 kts, I had to go to 10500 for terrain and my GS went down to 117 kts., so I jumped back down to 8500 when I had the chance. Turbo airplanes take advantage of the thinner air up high is why they can go faster then normally aspirated planes. you maintain your full 200 HP up to a DA of 12,000 ft. So 12000 ft is where you start to lose horse power but the air is thinner allowing you a better TAS and if you play the winds right, some really good ground speeds. stay low if you have a head wind, get up high when you have a tail wind. Sometimes, the wind down low will be higher then say around 10,000 or 12000 ft or about the same. If there is not much difference in the winds, I would select the higher altitude because of the thinnner air. Also you dont use as much fuel up high. "O. Sami Saydjari" wrote: When planning a flight against the wind, how to you pick the best altitude when trying to minimize flight time? If I read my performance charts correctly, my aircraft (Piper Turbo Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of *true* airspeed for every 1000 feet you go up. Firstly, does that sound about right to folks? I assume that this effect is from the decrease in air friction at high altitudes (even though the prop also has less air to "push on"). So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? My experience thus far suggests that most of the time, the winds aloft speed increase far faster then 2 nts per 1000 feet, so, in general, it is unlikely that I will do much better than staying at the absolute minimum altitude. Is that consistent with other folks' experience? -Sami |
"O. Sami Saydjari" wrote in message ...
When planning a flight against the wind, how to you pick the best altitude when trying to minimize flight time? If I read my performance charts correctly, my aircraft (Piper Turbo Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of *true* airspeed for every 1000 feet you go up. Firstly, does that sound about right to folks? I assume that this effect is from the decrease in air friction at high altitudes (even though the prop also has less air to "push on"). So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? My experience thus far suggests that most of the time, the winds aloft speed increase far faster then 2 nts per 1000 feet, so, in general, it is unlikely that I will do much better than staying at the absolute minimum altitude. Is that consistent with other folks' experience? The 2 kts per 1000 feet seems about right. The speed increase is due to the fact that the turbo allows the engine to maintain power output at a much higher elevation than a normally aspirated engine. The increased power output coupled with thinner air allows the plane to go faster. Generally speaking, the winds above 10k are out of the west, and can be strong enough to negate the speed advantage of the turbo. On these trips, it makes sense to fly lower. Going Eastbound, you will generally want to fly high to take advantage of both the high TAS and the large tailwinds. There are exceptions however, so you need to look at the forecast and PIREP'ed winds aloft as part of your flightplanning to decide whether or not it makes sense to climb high. However, you will find many times that having a turbo and oxygen are a great advantage no matter what the winds aloft. Just last week, I was on top of a rising cloud layer at 10,000 in my Cherokee, a smooth ride and in the sun. (The clouds were ~9kft thick at my location.) However, as I traveled North, I was to pass a weak cold front, and the temps were already dropping. I considered climbing higher, but had visions of my Cherokee struggling to outclimb iceladen clouds, and of course the hypoxia issues as one continues climb... I ended up descending and flew 2 hrs in bumpy, rainy IMC. Not much fun, but I kept the OAT above zero and made it to my destination no problems. If I had turbo and oxygen, I would have zipped up to 12,14,16, whatever it took to clear the clouds, enjoyed a smooth ride home in the sun, and an easy descent in the better weather at my destination. -Nathan |
![]() "O. Sami Saydjari" wrote in message ... When planning a flight against the wind, how to you pick the best altitude when trying to minimize flight time? You need to run the performance charts against some actual weather. Use ADDS for wind and everything else. Up wind and downwind are completely different exercises. Every day is different but patterns will quickly develop with experience. The turbo changes things a bit. Hit the books with some actual weather. |
In article , "O. Sami Saydjari"
writes: So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? Yes, but it is generally smoother up higher. Chuck |
Lazy people (like me) ask their computer. FlightStar from Jepp has an
"optimize altitude" function that is pretty handy. Once it has downloaded DUATs weather it will display groundspeed and fuel burn for all altitudes and highlight the optimal flight level. "O. Sami Saydjari" wrote in message ... When planning a flight against the wind, how to you pick the best altitude when trying to minimize flight time? If I read my performance charts correctly, my aircraft (Piper Turbo Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of *true* airspeed for every 1000 feet you go up. Firstly, does that sound about right to folks? I assume that this effect is from the decrease in air friction at high altitudes (even though the prop also has less air to "push on"). So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? My experience thus far suggests that most of the time, the winds aloft speed increase far faster then 2 nts per 1000 feet, so, in general, it is unlikely that I will do much better than staying at the absolute minimum altitude. Is that consistent with other folks' experience? -Sami |
I generally run several flight plans at different altitudes, accounting for
the differences in true air speed, wind speeds, and time to climb and descend. More often than not, I find that the extra time to climb uses up the gains in TAS at altitude, and winds are the only factor that make a significant difference. If the flight is long, say 3-4 hours, then the climb can be worth it, but for less than a couple of hours, it usually is not. I fly behind a turbocharged engine and have built-in oxygen, so I can go anywhere up to 18-20K, but usually stay below 12K or so unless there is a net advantage due to wind. I like to stay high enough to keep from having to switch from centers to approach controls all the time and to get above the haze layer for a smoother ride. But sometimes the high winds just force you down into the turbulence and traffic at 3-4K. Stan "O. Sami Saydjari" wrote in message ... When planning a flight against the wind, how to you pick the best altitude when trying to minimize flight time? If I read my performance charts correctly, my aircraft (Piper Turbo Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of *true* airspeed for every 1000 feet you go up. Firstly, does that sound about right to folks? I assume that this effect is from the decrease in air friction at high altitudes (even though the prop also has less air to "push on"). So, unless there is some other factor, I think this means that if the winds increase at anything higher than 2 nts per 1000 feet, I am best off staying at the Minimum Enroute Altitude. Is that right? My experience thus far suggests that most of the time, the winds aloft speed increase far faster then 2 nts per 1000 feet, so, in general, it is unlikely that I will do much better than staying at the absolute minimum altitude. Is that consistent with other folks' experience? -Sami |
McGregor wrote:
: Lazy people (like me) ask their computer. FlightStar from Jepp has an : "optimize altitude" function that is pretty handy. Once it has downloaded : DUATs weather it will display groundspeed and fuel burn for all altitudes : and highlight the optimal flight level. Although I can do it by hand, I find it much more convenient to have DUATS do it for me. Since I fly a non-turbo'd Cherokee, I'm effectively relegated to 10kft or less. A quick check of winds aloft, and maybe two or three altitudes with DUATS flight planner (it corrects for current wind) and see where I end up. On the fly, I pretty much figure I need about 5 kt difference in wind to counteract a 2000' climb/descent. Unfortunately, the nicer the weather (this time of year in particular), the higher the pressure and bigger the headwind for a westly flight is. Even skimming the trees at 1000' AGL doesn't usually help, so I end up climbing for smoothness and happy engine at 6-10k. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Optimal Frequency of Lessons | David B. Cole | Aerobatics | 18 | October 28th 04 12:50 AM |
Sparkplug picking tool | Michael Horowitz | Home Built | 3 | November 1st 03 01:51 PM |
Center vs. Approach Altitudes | Joseph D. Farrell | Instrument Flight Rules | 8 | October 21st 03 08:34 PM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
