I am planning a trip into the Caribbean. My question is: If I have
been given a clearance from a non-radar facility. Because the facility does not have radar they do not give me a transponder code. What should I squawk? The same question applies to coming into a radar-controlled environment from a non-radar environment like approaching San Juan from Bermuda. Again, what should I squawk prior to receiving a transponder code from San Juan? I was thinking that the answer would be 1200 but the AIM says that 1200 is for VFR traffic in the United States. Should you know the answer, I would also like to know from where I can find the answer. Thanks for the help ... Michael |
"Michael" wrote in message om... I am planning a trip into the Caribbean. My question is: If I have been given a clearance from a non-radar facility. Because the facility does not have radar they do not give me a transponder code. What should I squawk? The same question applies to coming into a radar-controlled environment from a non-radar environment like approaching San Juan from Bermuda. Again, what should I squawk prior to receiving a transponder code from San Juan? I was thinking that the answer would be 1200 but the AIM says that 1200 is for VFR traffic in the United States. Should you know the answer, I would also like to know from where I can find the answer. If you're departing from a point in the US you should be assigned a beacon code, even if your departure point is not served by radar. Beacon codes are generated by ARTCC computer based on the equipment suffix you filed. If the suffix indicates you have a transponder, a code is generated. If the suffix indicates you do not have a transponder, or no suffix is entered at all, no code is generated. |
"Michael" wrote...
I am planning a trip into the Caribbean. My question is: If I have been given a clearance from a non-radar facility. Because the facility does not have radar they do not give me a transponder code. What should I squawk? The same question applies to coming into a radar-controlled environment from a non-radar environment like approaching San Juan from Bermuda. Again, what should I squawk prior to receiving a transponder code from San Juan? I was thinking that the answer would be 1200 but the AIM says that 1200 is for VFR traffic in the United States. Should you know the answer, I would also like to know from where I can find the answer. In a non-radar environment over international waters, 2000 is the default squawk for IFR traffic. I don't know if it extends to VFR as well. Generally, though, the ATC controller who provides flight following should tell you what to squawk when radar service is terminated. If he says "Squawk VFR," then squawk 1200. If he doesn't give you a code, ask. Back in the 70s when I flew VFR over Puerto Rico and the USVI, we squawked 1200 when we had no other assigned squawk. If you're approaching Sweden, maybe 7000 (http://aip.lfv.se/7AIC-Sverige/A8-03.pdf, page 11, bottom) Also, look at the International Flight Information Manual at http://www2.faa.gov/ats/aat/ifim/index.htm. At http://www2.faa.gov/ats/aat/ifim/ifim0110.htm, at the bottom, they reference ICAO Document 7030-Flight Rules, Flight Plans, ATC Clearances, Transponder Operation, Communications and Reporting Procedures. You might have to buy it to read it, though ($55 at http://www.ariane-info.com/icao-e.htm). |
"Steven P. McNicoll" wrote: "Michael" wrote in message om... I am planning a trip into the Caribbean. My question is: If I have been given a clearance from a non-radar facility. Because the facility does not have radar they do not give me a transponder code. What should I squawk? The same question applies to coming into a radar-controlled environment from a non-radar environment like approaching San Juan from Bermuda. Again, what should I squawk prior to receiving a transponder code from San Juan? I was thinking that the answer would be 1200 but the AIM says that 1200 is for VFR traffic in the United States. Should you know the answer, I would also like to know from where I can find the answer. If you're departing from a point in the US you should be assigned a beacon code, even if your departure point is not served by radar. Beacon codes are generated by ARTCC computer based on the equipment suffix you filed. If the suffix indicates you have a transponder, a code is generated. If the suffix indicates you do not have a transponder, or no suffix is entered at all, no code is generated. And, once you depart domestic FAA control and are handed off to oceanic you are expected to squawk 2000. That is an ICAO rule. |
om... I am planning a trip into the Caribbean. My question is: If I have been given a clearance from a non-radar facility. Because the facility does not have radar they do not give me a transponder code. What should I squawk? The same question applies to coming into a radar-controlled environment from a non-radar environment like approaching San Juan from Bermuda. Again, what should I squawk prior to receiving a transponder code from San Juan? I was thinking that the answer would be 1200 but the AIM says that 1200 is for VFR traffic in the United States. Should you know the answer, I would also like to know from where I can find the answer. Michael The international rules (besides specifying the usual codes for emergency, radio failure and unlawful interference) say you should squawk: 1) whatever ATC instructs you to squawk or failing that 2) whatever "regional air navigation agreements" prescribe or failing that 3) 2000 Virtually every state except the USA has an Aeronautical Information Publication (AIP) in which, amongst many other useful pieces of info, the procedures which come under the heading of "regional air navigation agreements" are set out. AIPs have a standard format set out by ICAO, and the Radar Services and Procedures are in section ENR 1.6. It might be worth checking the AIPs of the states you intend to visit. Your Aeronautical Information Service (AIS) should keep a library of foreign AIPs. Of course since the US has a one-of-a-kind system, your AIS may do it differently but http://www1.faa.gov/ats/ata/ata100/index.html may be able to help. Most likely, as Steven says, you'll get a discrete squawk even if some of the route is non-radar. FWIW, in many parts of the world including most of Europe, the conspicuity squawk (what you squawk, VFR or IFR, if you're not assigned anything else) is 7000. HTH Julian Scarfe |
TCAS?
"Roy Smith" wrote in message ... In article , wrote: And, once you depart domestic FAA control and are handed off to oceanic you are expected to squawk 2000. That is an ICAO rule. If you're out of radar coverage, why does anybody care what you squawk? |
"Roy Smith" wrote...
If you're out of radar coverage, why does anybody care what you squawk? While you may be out of range of ATC radar, "Big Brother" may be watching with even bigger radars (e.g., Shemya)... |
The answer is: "2000" -- at least for oceanic operations.
I just ran across AC 91-70B -- Oceanic Operations, dated 09/06/94, at http://www1.faa.gov/fsdo/orl/files/advcir/AC9170B.TXT. Chapter 2, OCEANIC OPERATIONS FOR ALL AIRCRAFT IN ALL GEOGRAPHIC AREAS, par 6.e(4) states: (4) ICAO Documents 7030, "Regional Supplementary Procedures" and 8168, "Aircraft Operations Volume I," state that transponders shall be operated as follows: (a) when the aircraft carries serviceable Mode C equipment, the pilot shall continuously operate in this mode, unless otherwise directed by ATC; (b) in NAT airspace, unless otherwise directed by ATC, pilots shall retain the previously assigned transponder code for a period of 30 minutes after entry into the airspace, then operate on code 2000; (c) in oceanic airspace other than the NAT, pilots shall operate the transponder and select modes and codes as directed by the ATC unit with which the pilot is in contact; or (d) in the absence of any ATC directions, pilots shall operate the transponder on Mode A Code 2000. Further, in Chapter 3, par 9.g, discussing non MNPS airspace over the Atlantic: Navigation equipment adequate for operation in accordance with the flight plan and with ATC clearances shall be carried. SSR transponders with Mode 3/A and C are required in Iceland. Pilots shall operate SSR transponders continuously on Mode A, Code 2000. Departing aircraft shall retain the last assigned code for 30 minutes after entry into NAT oceanic airspace unless otherwise instructed by ATC. This procedure does not affect the use of special purpose codes 7500, 7600 or 7700 when required. Chapter 4, par. 4.g (Northern Pacific ops): g. Transponder Codes. When operating west of l64E, transponders should be set to Mode A Code 2000. When east of 164E, a discrete code may be assigned. This code should be maintained unless otherwise advised by ATC. If no discrete code is assigned, transponders should be set to Code 2000. Chapter 11, GENERAL AVIATION SHORT-RANGE AIRCRAFT OCEANIC OPERATIONS, par. 2.j, says this about transiting Iceland: Navigation equipment adequate to navigate in accordance with the flight plan and in accordance with ATC clearances will be carried aboard the aircraft. Secondary surveillance radar (SSR) transponders with Mode 3/A and C are required in Iceland. Pilots shall operate SSR transponders continuously on Mode A, Code 2000, except that departing aircraft shall retain the last assigned code for 30 minutes after entry into NAT oceanic airspace unless otherwise instructed by ATC. |
| Thread Tools | |
| Display Modes | |
| VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 05:29 PM |
| Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 01:18 AM |
| Ham sandwich navigation and radar failure | David Brooks | Instrument Flight Rules | 47 | December 31st 03 01:15 AM |
| transponder check? | Russell Duffy | Home Built | 10 | August 15th 03 12:36 AM |
| Marine Radar in a plane? | Jay Honeck | Home Built | 31 | August 13th 03 07:56 PM |
