New gun
Old January 23rd 06, 07:58 PM posted to rec.aviation.piloting
Default New gun
("Big John" wrote)
New super-gun to be tested in Feb
Can you crosspost to multiple newsgroups, instead of starting separate
threads in separate newsgroups?
Many (most?) newsreaders will cancel 'read posts' from one newsgroup to
another.
Thanks
Gun:
Didn't a couple of Mormons, out in Utah back in the late 80's, have a gun
that fired .22 rounds? It was suppose to be able to shoot down a telephone
pole and slice through a moving car - like a knife through warm butter. It
was lightweight and inexpensive because it used .22 shells. Something like
6,000 round per minute. 100/sec.
The story was featured in our daily paper - there might have been a Twin
Cities connection.
Montblack
Old January 23rd 06, 08:02 PM posted to rec.aviation.piloting
Default New gun
The GAU-8's biggest limitation besides ammo supply
is that the recoil slows the A-10 quickly,
The recoil will do no such thing.
Old January 23rd 06, 08:55 PM posted to rec.aviation.piloting
Default New gun
"Stubby" wrote
I really don't understand the "environmental issue." Those rounds are
meant to melt through armor and shatter into pieces which bounce around
inside the tank and function as an anti-personnel weapon. That's fairly
high on the "toxicity" scale compared to DU which is approximately as
radioactive as common rock.
Many (most) of the rounds miss the tank, and are in the surrounding
environment, and in villages, and such.
Jim in NC
  #24
Old January 23rd 06, 09:32 PM posted to rec.aviation.piloting
Default New gun
and gasses from the muzzle get sucked into the engines while firing.
Not true. The engines are mounted where they are, to prevent that.
IIRC from the A-10 show on Military Channel, the engines are mounted
where they are to give the plane better survivability against AAA. That
dictated placement of the engines. One could be blown off the airframe
and the plane could still fly. The trail of spent gas from the gun was
fairly obvious in the airborne footage of the gun firing IIRC. Also
mentioned in the narration. Also mentioned was the recoil slowing the
aircraft. If this is not accurate then the Military Channel has poor
sources.
  #25
Old January 23rd 06, 09:42 PM posted to rec.aviation.piloting
Default New gun
says...
That's compared to 60 rounds per minute in a standard military machine
gun.
BANG...one thousand...BANG...one thousand...BANG...one thou. . . . .
  #26
Old January 23rd 06, 10:38 PM posted to rec.aviation.piloting
Default New gun
"Morgans" writes:
[...] A myth, according to a A-10 driver here, a while back. [...]
A quick visit to Newton's second law indicates a roughly
2 m/s^2 ~ 6.5 ft/s^2
deceleration due to the recoil force (10000 lbf acting on 50000 lb
airplane). From a hypothetical slowish flying speed of 200 mph
(300 ft/s), it would require about **20 seconds** of fire to get
down to the A-10's ~115 mph stall speed.
Whether that's "quick" or "a myth" depends on your point of view (and
on whether I did my estimations correctly).
- FChE
  #27
Old January 23rd 06, 10:58 PM posted to rec.aviation.piloting
Default New gun
"Frank Ch. Eigler" wrote in message
"Morgans" writes:
- FChE
Did your estimation take into account that the Warthogs engines are still
producing power while they shoot?
  #28
Old January 23rd 06, 11:07 PM posted to rec.aviation.piloting
Default New gun
George Patterson wrote:
There's no recoil from a rocket launch.
Thank you George my brain wasn't fully angaged yet when I posted.
The Monk
  #29
Old January 23rd 06, 11:08 PM posted to rec.aviation.piloting
Default New gun
That's alright Steven, my brain wasn't fully angaged yet when I posted.
The Monk
  #30
Old January 23rd 06, 11:41 PM posted to rec.aviation.piloting
Default New gun
What you failed to take into account, is that the engines keep applying
thrust, and will partially negate that issue, and that the gun is nearly
always fired while the airplane is in a rather steep descent (to get guns on
target), so there is more force to keep the airplane from slowing down.
So it appears as though it would take considerably more to slow the airplane
to stall speed, and it the guns fired much longer, they would be a molten
pile of metal, or out of ammo. Anyone remember how many seconds of ammo are
carried?
As to the engines ingesting the gun smoke, consider how much air they take
in. Massive amounts. Most of that is bypassed around the engine, so only a
little is burned. Even if some of the smoke is taken in, I doubt that it is
enough to make the engine even stutter.
Jim in NC
