Boosting ICOM IC-A23 Handheld Aviation Radio
Old June 6th 04, 05:23 PM
Teacherjh
Were you really "talking" to these stations? The 108-136 MHz
band(s) is(are) for /air/ mobile operations. Talking to LA
Center while driving on I5 would seem to be illegal.
What if you're jumping up and down, and only transmit when you're in the air?
Jose
Old June 6th 04, 07:28 PM
Jerry Kurata
Where are located when you are using this radio. I am 7 miles from the
airport and I can hear aircraft in the pattern, but cannot hear the tower or
ATIS. The problem is these frequencies are line of sight. If you have
buildings and such in between the antenna and the source, the reception will
be poor regardless of antenna.
jerry
"CHANGE USERNAME TO westes" wrote in
message ...
I recently purchased an ICOM IC-A23 radio, and I'm disappointed in its
pickup. It gets the weather channels fine, but the reception for both
airport and airplane radios is poor. Aside from standing next to the
airport or being right under the airplane, do I have any options for
improving gain and the quality of reception? Is there some third party
antenna that I could attach to this radio? It looks like it takes a
standard BNC type connector for the antenna that comes with it.
Will
westes AT earthbroadcast.com
Old June 6th 04, 10:03 PM
How tall was that telescoping antenna?
Does anyone sell an off the shelf 5/8 wave telescoping antenna with a strong
magnetic base?
Will
"EDR" wrote in message
In article , CHANGE USERNAME TO
westes wrote:
If you are on the ground, outside the airplane, you can purchase a
metal, 5/8 wave, telescoping antenna to replace the standard rubber
duckie.
Old June 7th 04, 08:13 PM
EDR
I do not remember how long it extends to.
IIRC, the formula is 468/f(MHz) gives the wavelength. Multiply by 5/8
to get the antenna length in feet. For 123.0 MHz (middle of the band),
the length is 28.5 inches.
magnetic base?
Just purchase a standard ham 2m mag mount antenna and cut a piece of
stainless steel rod that fits the mag mount to the above calculated
length.
Old June 7th 04, 10:30 PM
Max T, CFI
I disagree with the method described below for calculating a 5/8 wavelenth antenna.
As I recall, the formula you have below gives you the length in feet of
a half wave length antenna (not the full wavelength as you suggest). So a 5/8 ths
wave antenna would be twice as long as you calculated. Also, if you took a 2 meter
5/8's wave antenna, you'd need to lengthen it (not cut it down) to use it as a 5/8 wave
antenna on 123 MHz.
You probably could take a 5/8 wave 2 meter ham antenna and cut it down to a 1/4 wavelength
antenna for use on 123 MHz. The length for that would be somewhere around 22.89 inches.
Max T, CFI (and ham radio operator)
EDR wrote in message ...
magnetic base?
length.
Old June 7th 04, 11:07 PM
Teacherjh
wavelength
There's more to it than that. The impedance has to match. For a 1/4 wave
antenna, all you need is 1/4 wave worth of metal. But for a 5/8 wave, you need
a coil at the bottom too, so that the antenna looks like 1/4 wave to the
transmitter, and works like a 5/8 wave to the ether. A ham band (or any other
band) 5/8 wave antenna will already have the appropriate coil, but if you
change the length significantly, the coil will no longer be the right value.
For 123 MHz the difference is probably not all that much, but it might be
enough, depending on your transmitter.
Jose
Old June 8th 04, 10:23 AM
magnetic base?
Whatever 5/8 of an RF wavelength of 128.0 MHz is; somewhere around 3 1/2 feet,
or so.
No one sells them off the shelf, because they can cut one for you in about two
minutes. Any decend ham radio store has all the stuff.
Old June 8th 04, 10:26 AM
antenna on 123 MHz.
magnetic base?
length.
I had mine cut for 128.0 MHz to optimize the VHF voice band. The nav frequencies are less
important. Ham Radio Specialists in San Diego cut it, and had stock to do 5/8 wave length at
that frequency. The whip is much longer than 28.5 inches; somewhere around 40 inches, or so.
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) Barnyard BOb - Home Built 5 September 8th 04 07:27 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 11:55 AM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
Marine Radio using Aviation Antennae Jim Weir Home Built 13 August 12th 03 10:05 PM
