Why are some NDBs not displayed on Low Alt Enroute Charts?
Old May 1st 06, 08:21 PM posted to rec.aviation.ifr
Default Why are some NDBs not displayed on Low Alt Enroute Charts?
Subject says it all. For instance, here in Southern California, the NDB
Petis is on the low chart, while ElMonte is not. Anyone know why?
Is it because of monitoring, or lack of? Or is it because one is part
of the enroute structure, and the other one not? Or because one has
approaches involving this NDB, but the other doesn't?
Anyone know for sure?
Cheers,
Addy
Old May 1st 06, 08:56 PM posted to rec.aviation.ifr
I don't know for sure, but if there's an area chart that covers the area,
it's probably on that and therefore not on the enroute chart due to crowding?
Cheers,
Addy
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old May 2nd 06, 01:45 PM posted to rec.aviation.ifr
Cheers,
Addy
Just a guess on my part: PETIS is a federal nav aid. EMT is non-federal
and serves only one IAP.
Old May 2nd 06, 02:07 PM posted to rec.aviation.ifr
A NAVAID is shown on a chart if it has a function on that
chart. Enroute charts don't show NAVAIDS that only serve an
IAP, and IAP charts don't show all the enroute NAVAIDS in an
area.
The NDB in question has some enroute function, perhaps a
bearing or even a route segment.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Sam Spade" wrote in message
newsvI5g.175034$bm6.39610@fed1read04...
California, the NDB
know why?
because one is part
because one has
| Cheers,
| Addy
is non-federal
Old May 2nd 06, 03:54 PM posted to rec.aviation.ifr
area.
Could you be more specific about the case in point? What en route
function does PETIS have?
Old May 2nd 06, 06:34 PM posted to rec.aviation.ifr
Don't know, don't have that chart.
news:VoK5g.175045$bm6.45600@fed1read04...
that
serve an
in an
| area.
en route
Old May 2nd 06, 08:03 PM posted to rec.aviation.ifr
No problem. Go to the following for a PDF file with scans of the Jepp
area and en route charts with PETIS NDB:
http://members.cox.net/aterpster
that
serve an
in an
| area.
en route
Old May 2nd 06, 10:15 PM posted to rec.aviation.ifr
"Jim Macklin" wrote in message
news:hTI5g.6118$8q.1208@dukeread08...
area.
DEPRE LOM appears on enroute charts. It serves only an IAP.
Old May 3rd 06, 03:15 PM posted to rec.aviation.ifr
Sam Spade wrote:
Jim Macklin wrote:
A NAVAID is shown on a chart if it has a function on that chart.
Enroute charts don't show NAVAIDS that only serve an IAP, and IAP
charts don't show all the enroute NAVAIDS in an area.
The NDB in question has some enroute function, perhaps a bearing or
PETIS NDB doesn't seem to have an enroute function, but PETIS reporting point
does. The two are very nearly, but not exactly colocated. Note that PETIS
reporting point is not defined from the NDB, but rather by 4 different methods
using two VORs and 2 localizers.
Navaid identifier: SB
type: NDB
city: SAN BERNADINO
state: CA
latitude: 34-03-23.285N
longitude: 117-21-58.014W
elevation: 0
magnetic variation: -14
Fix identifier: PETIS
state: CA
use: REPORTING POINT
latitude: 34-03-23.290N
longitude: 117-21-58.010W
VOR HDF, radial 317.77
VORTAC PDZ, radial 029.62, DME 11.63
ILS/DME I-ONT, radial E CRS, DME 12.86
ILS I-SBD, radial SW CRS
Old May 3rd 06, 05:08 PM posted to rec.aviation.ifr
point does. The two are very nearly, but not exactly colocated. Note
that PETIS reporting point is not defined from the NDB, but rather by 4
different methods using two VORs and 2 localizers.
type: NDB
city: SAN BERNADINO
state: CA
elevation: 0
state: CA
Spot on. And, I suspect the NDB simply got dragged along to the chart
because it is probably documented on the same fix form as is the PETIS
intersection.
Connecting enroute to approach charts Ron Garret Instrument Flight Rules 13 December 2nd 05 11:12 PM
Ebay Auction Jeppesen VHS (4) tapes collection: Enroute Charts, IFR Emergencies, Departures & Arrivals, Approach Charts Cecil Chapman Products 0 February 9th 05 03:09 AM
RNAV Enroute CHarts John R. Copeland Instrument Flight Rules 0 September 20th 04 03:33 PM
Can US enroute charts be used in Canada? Andrew Sarangan Instrument Flight Rules 0 May 31st 04 09:58 PM
