"David B. Cole" wrote in message
m... Wizard of Draws wrote in message news:BD5BD60A.1F633%jeffbREMOVE@REMOVEwizardofdra ws.com... Solo? Jeff, I have the IR, but this was my first time in actual without an instructor. I think he was referring to the pilot in the right seat. I know he wasn't your instructor or instrument-rated himself, but any sort of pilot who can dial in frequencies and squawk codes is quite a help when flying IMC. My first IMC without an instructor (in July) was with a passenger who doesn't know his ass from his elbow when it comes to planes, but he was still able act as a pen and chart holder! I dropped him off and then got about 2 minutes of truly solo solid IMC while climbing through an overcast layer, but the rest of the flight was in the sunshine on top and the destination was VFR. Jeremy |
Peter,
I understand that, which is why in the original post I stated that he was only checked out in normally asirated planes. When I hear the term "checked out" it usually means being authorized to use the planes of a particular operation. As far as I know the FAA doesn't see any difference between normally aspirated and fuel injected engines, so I thought it was obvious it was an operator restriction. Maybe there is another meaning and if so I will provide more clarity in the future. Dave "Peter Duniho" wrote in message ... "David B. Cole" wrote in message m... Since we wanted to switch seats at the destination, he wouldn't have been able to fly left seat without being checked out. As David said, that would be a club regulation issue. The FAA has no prohibition against you acting as PIC from the right seat, nor against him manipulating the controls from the left. Perhaps you should clarify whose rules you're talking about and what you mean by "checked out". Pete |
Jeff,
I guess the correct phrase would have been sans-CFII instead of solo. It was fun, but served to reinforce my belief that it is to be respected. Dave Wizard of Draws wrote in message news:BD5D2CAB.1F9A9%jeffbREMOVE@REMOVEwizardofdra ws.com... On 9/2/04 10:41 AM, in article , "David B. Cole" wrote: Wizard of Draws wrote in message news:BD5BD60A.1F633%jeffbREMOVE@REMOVEwizardofdra ws.com... On 9/1/04 4:16 PM, in article , "David B. Cole" wrote: On Saturday I had my first opportunity to fly solo in actual since my IR checkride. One of my biggest concerns since getting the rating was how I would make my first entry into actual without the benefit of an instructor at my side. With about ten hours of actual during my training I had always felt comfortable in that environment. But I knew the true test would be doing it alone, or almost alone. Another pilot who had just gotten checked out at my FBO and who had passed his instrument checkride about a week earlier wanted to go up, so I figured it would be a great opportunity to get some simulated instrument time, knock off a little rust , and get an approach or two in for currency. Because the other pilot was only checked-out in planes with normally aspirated engines, we had to use one of the older 172s. Solo? Jeff, I have the IR, but this was my first time in actual without an instructor. Dave Gotcha. I kept waiting for the other guy to leave. g Congrats. It's pretty fun knowing you can get through that stuff by yourself isn't it? |
Yes; I just wanted to verify this is the case because there are common
misapprehensions about the regulatory qualifications needed to fly the plane or act as SP. I suppose your phrase "normally aspirated" as opposed to "fixed gear" or "under 200HP" should have clued me that wasn't what you meant. -- David Brooks "David B. Cole" wrote in message m... Peter, I understand that, which is why in the original post I stated that he was only checked out in normally asirated planes. When I hear the term "checked out" it usually means being authorized to use the planes of a particular operation. As far as I know the FAA doesn't see any difference between normally aspirated and fuel injected engines, so I thought it was obvious it was an operator restriction. Maybe there is another meaning and if so I will provide more clarity in the future. Dave "Peter Duniho" wrote in message ... "David B. Cole" wrote in message m... Since we wanted to switch seats at the destination, he wouldn't have been able to fly left seat without being checked out. As David said, that would be a club regulation issue. The FAA has no prohibition against you acting as PIC from the right seat, nor against him manipulating the controls from the left. Perhaps you should clarify whose rules you're talking about and what you mean by "checked out". Pete |
Dave, along the lines of "clarity" which you mentioned:
"Normally aspirated" contrasts with "Supercharged", while "Carbureted" contrasts with "Fuel Injected". But that's OK -- we all finally understood what you meant. If I were renting out fuel-injected or and/or supercharged airplanes, I'd also want to be sure my renters understood how to operate them. But I see no reason for the FAA to be involved in the matter. ---JRC--- "David B. Cole" wrote in message = m... Peter, =20 I understand that, which is why in the original post I stated that he was only checked out in normally asirated planes. When I hear the term "checked out" it usually means being authorized to use the planes of a particular operation. As far as I know the FAA doesn't see any difference between normally aspirated and fuel injected engines, so I thought it was obvious it was an operator restriction. Maybe there is another meaning and if so I will provide more clarity in the future. =20 Dave =20 |
"John R. Copeland" wrote: If I were renting out fuel-injected or and/or supercharged airplanes, I'd also want to be sure my renters understood how to operate them. But I see no reason for the FAA to be involved in the matter. Other than some quirks in how you start them, I can't think of anything you really need to know about fuel injection to safely fly a fuel injected airplane. Certainly nothing that couldn't be taught in a couple of minutes (i.e. "there's no carb heat"). Supercharging is a bit more complicated. You can get into trouble and/or damage the airplane, if you don't know how the system works. A much steeper learning curve is mastering the current crop of avionics. Somebody who did their instrument training with 2 NAV/COMs and an ADF can get themselves into a world of hurt if they launch into IMC with a modern GPS and think they can figure it out as they go. I guess the FAA figures people are smart enough to not do that. |
Roy Smith wrote: Other than some quirks in how you start them, ....which don't show up until your renter has flown to a distant airport, shut down, and now wants to restart the hot engine. ![]() injected airplane. Certainly nothing that couldn't be taught in a couple of minutes (i.e. "there's no carb heat"). You just made me realize that I should know more about my alternate air than I do... -- Ben Jackson http://www.ben.com/ |
![]() While this flight was certainly a good confidence booster, I realize that flying IMC is a dangerous venture, especially for someone at my experience level. Dan Luke wrote: That was the exact effect my first time flying an approach alone in actual IMC had on me. You realize that you're in a real, no-kidding, life-or-death situation and the outcome is entirely up to you. Of course, this is also true of crossing the street, but in instrument flying you have have a lot more on the ball to avoid the "or death" option. First, fly the airplane. Everything else is secondary. |
In article Sl3_c.96690$9d6.67401@attbi_s54, (Ben Jackson)
wrote: In article , Roy Smith wrote: Other than some quirks in how you start them, ...which don't show up until your renter has flown to a distant airport, shut down, and now wants to restart the hot engine. ![]() Which is certainly inconvenient, but it's really difficult to do any serious damage to the airplane if it's on the ground and you can't get the engine started :-) |
filing IFR plan for VFR flight conditions | Paul Safran | Instrument Flight Rules | 53 | May 11th 04 03:07 AM |
Finally, some real solo IFR practice! | Guy Elden Jr. | Instrument Flight Rules | 0 | April 15th 04 03:55 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
FAR 91.157 Operating in icing conditions | O. Sami Saydjari | Instrument Flight Rules | 98 | December 11th 03 06:58 AM |
IR without actual IMC | Iain Wilson | Instrument Flight Rules | 26 | October 13th 03 11:26 PM |
