Coupled approach?
Old September 28th 04, 11:44 PM
Roy Smith
"James M. Knox" wrote:
The AI provides the "wing leveler" primary input, while the DG and NAV
signals are summed to provide a heading. Amazingly effective, for such
a trivial analog approach, it will (if carefully adjusted) intercept and
track a NAV signal. However, in a strong crosswind, it will do so "off"
the actual courseline (parallel to it).
Not quite parallel, but rather with a constant CDI offset, which for VOR
and LOC signals means a constant angular displacement.
2. Like all such systems, there is no turn anticipation.
I've never let the Century AP's fly anything but the most shallow turns.
I generally disengage the AP approaching the fix, hand-fly the turn,
then give the stick back to Otto for the next straight segment. In
fact, most of the time I just leave it in heading mode.
a) too little, and it will fly S-turns about the desired
course line, and b) too much, and it will wing rock itself until you
toss your cookies. Getting it set "just right" is an inflight specific
adjustment unique to each individual autopilot unit and N# combo.
I once flew a plane that had a *way* underdamped roll-rate. If you
reset the heading bug, it would slam you into a turn, hold that until it
was right up to the desired heading, then slam the wings back level.
IIRC, it didn't use excessive bank angles, just excessive roll rates in
and out of the turns. Not fun.
Old September 29th 04, 02:20 PM
James M. Knox
Roy Smith wrote in
NAV signals are summed to provide a heading. Amazingly effective,
for such a trivial analog approach, it will (if carefully adjusted)
intercept and track a NAV signal. However, in a strong crosswind, it
will do so "off" the actual courseline (parallel to it).
VOR and LOC signals means a constant angular displacement.
Good point... It's a constant voltage offset. I beleive one of the Century
(or old Mitchell) manuals actually uses the word parallel, but you are
right - it's a constant degree offset, only parallel for following
something like a GPS courseline.
Old September 29th 04, 09:46 PM
PaulaJay1
In article , Roy Smith
writes:
Not so. My Garmin 430 when coupled to the Century will anticipate, tho with
the Archer speed,that is not much. I generally let the autopilot do the turn.
At the turn I turn the heading but to the new course and let the 430 trim it
out. If the heading change is large, I sometimes do this in two steps of half
value each.
Chuck
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
