![]() "Robert M. Gary" wrote in message om... (Paul Tomblin) wrote in message ... I'm going to be flying from ROC to BAF weekend after next. Just plugging the end points into Aeroplanner gives me a nice simple route V2 ALB V146, but I see that BAF has a STAR, SWEDE ONE. It's a bit longer than the simple route, and since I've never flown that direction I don't know if I should file what I want and expect them to reroute me along SWEDE ONE, or should I just admit the inevitable and file SWEDE ONE? If I do that, how do you put it in a flight plan? Is it V2 SYR V433 RKA RKA.SWEDE1? Its pretty rare that a STAR is actually given to a non-jet aircraft though. Usually they want us away from the STAR so we don't get in the way. -Robert We almost always get the BLUBELL 1 STAR going into a variety of airports in the Houston area, from the Northwest, whether we file for it or not. Cheers, John Clonts Temple, Texas N7NZ |
Its pretty common to get the FERNANDO FIVE arrival into Santa Monica coming
in from the north. -Brenor |
I'm still studying for the rating, so I've never done this, but can't you
just say "no SIDS, no STARS" in the remarks, and they can't give it to you. Brad "Paul Tomblin" wrote in message ... I'm going to be flying from ROC to BAF weekend after next. Just plugging the end points into Aeroplanner gives me a nice simple route V2 ALB V146, but I see that BAF has a STAR, SWEDE ONE. It's a bit longer than the simple route, and since I've never flown that direction I don't know if I should file what I want and expect them to reroute me along SWEDE ONE, or should I just admit the inevitable and file SWEDE ONE? If I do that, how do you put it in a flight plan? Is it V2 SYR V433 RKA RKA.SWEDE1? -- Paul Tomblin http://xcski.com/blogs/pt/ So Linus, what are we doing tonight? The same thing we do every night Tux. Try to take over the world! |
In a previous article, "Brad Salai" said:
I'm still studying for the rating, so I've never done this, but can't you just say "no SIDS, no STARS" in the remarks, and they can't give it to you. If they want you along the STAR, then all this will mean is that you will have to copy and read back a full route clearance (which will look suspiciously like the textual description of the STAR) instead of the name of the STAR. I've never understood why anybody would want to say "no SIDS, no STARS" (or more correctly now, "no DPs, no STARS"?) unless they want practice copying and reading back full route clearances. -- Paul Tomblin http://xcski.com/blogs/pt/ "An appointment is an engagement to see someone, while a morningstar is a large lump of metal used for viciously crushing skulls. It is important not to confuse the two, isn't it, Mr. --?" - Terry Pratchett |
"Brad Salai" wrote:
I'm still studying for the rating, so I've never done this, but can't you just say "no SIDS, no STARS" in the remarks, and they can't give it to you. That's a bit of sillyness left over from long ago. Assuming anybody even notices the comment, they'll just assign you the full STAR route, but instead of giving it to you as a STAR, they'll spell out each individual waypoint and altitude. End result: more work for you, more work for the controller, more radio bandwidth wasted, same clearance to fly. |
I think it's because they have a misconception that they won't be
given the DP/STAR if they put "No DP/No STAR" in the comments section. I think if they realized they were going to get it anyway, they wouldn't do it. "Paul Tomblin" wrote in message ... In a previous article, "Brad Salai" said: I'm still studying for the rating, so I've never done this, but can't you just say "no SIDS, no STARS" in the remarks, and they can't give it to you. If they want you along the STAR, then all this will mean is that you will have to copy and read back a full route clearance (which will look suspiciously like the textual description of the STAR) instead of the name of the STAR. I've never understood why anybody would want to say "no SIDS, no STARS" (or more correctly now, "no DPs, no STARS"?) unless they want practice copying and reading back full route clearances. -- Paul Tomblin http://xcski.com/blogs/pt/ "An appointment is an engagement to see someone, while a morningstar is a large lump of metal used for viciously crushing skulls. It is important not to confuse the two, isn't it, Mr. --?" - Terry Pratchett |
On Tue, 12 Oct 2004 10:40:29 +0000 (UTC),
(Paul Tomblin) wrote: I've never understood why anybody would want to say "no SIDS, no STARS" Before they were incorporated into the approach plates you had to buy a separate SID/STAR book. Some people didn't do it because it cost more (which is silly), and my home base didn't carry them. HTH. z |
"Brad Salai" wrote in message ...
I'm still studying for the rating, so I've never done this, but can't you just say "no SIDS, no STARS" in the remarks, and they can't give it to you. I did that on a recent trip to KLUK Cincinnati and the clearance included a STAR anyway. I think sometimes this is for lost commm purposes: about half way en route they cleared me direct to LUK and finished with vectors. |
![]() That's a bit of sillyness left over from long ago. Assuming anybody even notices the comment, they'll just assign you the full STAR route, one reason we would put "no sids or stars" is because of the high alt. they required which would be a problem for oxygen (for example here in Utah the jammn four arrival puts you up at 16,000), performance wise we couldn't do it as well as regs for o2 for crew. usually when we did this they would clear us direct to the points or (if I can remember) they would say "stay clear of terrain" which is basically vectoring you and you're responsible for what's below.. (it's been awhile) basically it's a good thing to put in if you cannot fly at those altitudes. Matthew |
Robert M. Gary ) wrote:
Its pretty rare that a STAR is actually given to a non-jet aircraft though. Usually they want us away from the STAR so we don't get in the way. Fly into Boston's Logan Airport from the west and you will always receive the Gardner Three arrival. Well, perhaps in the wee hours of the morning prior to sunrise you might not, but during sunlight and into the evening you will. -- Peter |
Helicopters: Lone Star Sport Helicopter | Jim | Home Built | 0 | September 16th 04 05:40 AM |
STAR to neighboring airport | Viperdoc | Instrument Flight Rules | 2 | May 23rd 04 07:10 PM |
STAR to nearby airport | Viperdoc | Instrument Flight Rules | 33 | May 13th 04 10:48 PM |
Deburring sheet metal and filing edges? | DL152279546231 | Home Built | 1 | April 25th 04 12:47 AM |
Filing direct | John Harper | Instrument Flight Rules | 10 | October 9th 03 10:23 AM |
